Question about Plumbing
Air conditioner Cool breeze
Replacing the air conditioner float
  • 161 Answers
SOURCE: central air conditioner doesn't cool
Usually when a unit isn't cooling it is because one there isn't enough freon in the unit. Second there could be a compressor gone bad. Third there could be a circuit short out. It can be very simple and it can be costly. It just needs to be checked out by someone who has understanding in this area.Look for an affordable service man or company in your area whom most people may be using to come out and check it out for you. They would be glad to. They can let you know about what it might cost also. If you have understanding in this area you might do it yourself. I do most everything myself and it keeps alot of money in my wallet. But I have to take the time to do it.
Posted on Aug 08, 2007
  • 263 Answers
SOURCE: Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Posted on Dec 31, 2007
  • 230 Answers
SOURCE: Frigidaire air conditioner - no cool air coming out.
if you used it alot, i would check it for freon.
checkthe air filter, make sure it's not dirty.
check the front panel, make sure there's no "ice/frost" in the unit.
Posted on Jun 30, 2008
  • 400 Answers
SOURCE: Water level float switch error
You do not mention the model, I presume that it is a cassette, in which case the float switch is located in the indoor unit. You have to remove the cover which is 4 screws. First make sure all power supply is turned off. Then remove the drain pan which surrounds the fan blade. You will see in one corner of the unit a slightly deeper part of the drainpan, this is the corner where both the condensate pump as well as float switch is located. Before you do any of this, give a serious blow into the drain pipe from outside and this may dislodge any sludge which may be causing the floatswitch to stick. You can also pull out a rubber plug which is under the pump on the drainpan.
Posted on Mar 05, 2009
p_murfy
  • 63 Answers
SOURCE: My air conditioner is not working on my 2002 BMW X-5. The air is cool it just won't blow out.
If there is air moving through the vents most likely the final stage transistor(blower resistor) has failed. It controls blower speed from a signal from the ihka (a/c control panel). the final stage receives the signal from the ihka of the drivers preference blower speed. the final stage pwm (pulse width modulates) the blower motor. which means it turns it off and on very quickly to speed up or slow down the blower motor speed. It isn't the easiest part to replace. Usually at a dealership i would expect to pay somewhere around $600 (including diagnosis)but don't hold me to it. bmw dealerships stand behind their repairs and usually include a warranty with the part of 2 years unlimited mileage.
Posted on May 10, 2009
Where can I purchase a filter for the cool breeze air conditioning?
Patiocomforts.com has filters, pumps and water lines. Great to deal with.
May 29, 2014 | Cool Top Air Conditioner for Golf Cart...
Cool Breeze ducted evaporative air conditioner is only blowing hot air when in the "cool" mode. HELP !
your water pump may not be working check this also make sure the water is on
Jan 09, 2011 | Heating & Cooling
Units runs but cool air will stop even thou blower continues to run after several minutes cool air starts again
Check the theremostat probe to see if it may be too close to the evaporator fins behind filter if touching fins it will feel evaporator being cold before room air and send model number too, Sea Breeze
May 21, 2010 | LG Electronic Window Air Conditioner
No longer blows cold air and the unit is only 15 months old
First please clean the air filter and ensure that there is no dust settled on the filter which could chock the circulation of air.
To throw cool air the unit got to **** the air from the room and in case the air filter is blocked with dust then there will be no cooling at all.
Please ensure the thermostat knob is turned to the desired cooling level and try running the unit.
Ensure there is no escape route for the cool breeze.
Minimize the frequency of the door or window opening in the area to retain cooling efficiency.
I am sure your unit will work on taking the above precautions before operating it.
Jul 08, 2009 | Haier CPRD12XH7 Air Conditioner
My air conditioner won't turn on. When thermostat is set to cool, the furnace blower kicks on but the compressor and outdoor fan do not.
sounds like your not getting a low voltage signal to the condenser, if your Air handler is in the attic check your secondary drain pan it might be off on the float switch, if your air handler is in a closet you need to check your float switch, it will have some wires coming out of it. Hope that helps you get started.
Apr 26, 2009 | Goodman CKL42AR42 Air Conditioner
Plumbing Logo
26 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
