Question about Dell Optiplex 755 Desktop Desktop Computer
Will not load programs
Ecs amd motherboard 3200 processor 512 memory. When i load a program it says not enough memory so i added another 512 memory stick but i still get the same message.
  • frogger396 May 20, 2009
    not really .. i just formatted and i still have the same problem and it does recognize the memory sticks
  • Chris
    Chris May 11, 2010
    How much ram is showing up in windows? What programs are you trying to install that are giving the error?
    Chris
  • 53 Answers
Hi, First make sure your new stick of RAM is being recognized. If you dont get it seated well, it could not really be recognized. Also important is how full your Hard Drive is. This can effect you system speed. Get rid of uneccessary programs and junk files. Also check for background processes and programs that may be using up available memory.
Char S.
Posted on May 20, 2009
Maximum Ram can the Elite K755A Motherboard take?
The specifics for that motherboard can be found at the ECS website below which will detail the hardware limits for your motherboard.
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=420&CategoryID=1&MenuID=22&LanID=0
May 17, 2014 | AMD Computers & Internet
Memory settings for ddr
http://www.motherboards.org/mobot/motherboards_d/ECS/K7AMA/
Since the Processor Front Side Bus (FSB) support is 200 or 266MegaHertz (MHz), the ram memory will be DDR Sdram at either 100Megahertz or 266MHz.
That is PC1600 and PC2100, respectively.
2GB's maximum TOTAL amount for motherboard.
1GB per ram memory slot - Maximum
If you have a Socket A (Socket 462) AMD processor with a 200MHz FSB, I suggest DDR Sdram at 100MHz. (PC1600)
AMD processor with 266MHz Front Side Bus = either PC1600, or PC2100. I would go with PC2100.
Voltage in BIOS Setup is 2.5 Volts. That is is the JEDEC standard voltage, for DDR Sdram.
Ram timings will be dependent upon what the ram memory supports.
IF you have just ONE ram memory module ('Stick'), it goes in Slot 1.
(DIMM 1)
This is the ram memory slot the Processor reads first.
http://www.cpu-upgrade.com/mb-ECS/K7AMA%28V1.5%29.html
http://www.ocinside.de/go_e.html?http://www.ocinside.de/html/workshop/ecs_k7s6a_vcore.html
http://8000.hillbillyhardware.com:8000/Reviews/ecs_945gcd-m/ecs_945gcd-m.html
"When it comes to innovative motherboards ECS is not a company that first comes to mind. Not since the days of the K7AMA that offered DDR266 and PC133 memory options for AMD's K7 line of processors has ECS released a motherboard that has filled a gapping hole in the PC hardware market space. Lets just hope that the failure rate of the 945GCD-M is nothing like the failure prone K7AMA."
Hmmmmm,
Not doing it for you? Then post more details in a Comment.
Regards,
joecoolvette
Jan 03, 2013 | EliteGroup K7AMA Motherboard
Upgrade the 1.6GHz CPU on L7VMM2 Motherboard
ECS Support > L7VMM2 motherboard > Main Support page,
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=419&CategoryID=1&MenuID=50&LanID=0
Click on the CPU tab.
(Features / Specification / Download / Support / FAQ / CPU / etc)
Will support Up To an AMD Athlon XP 2600+,
http://en.wikipedia.org/wiki/List_of_AMD_Athlon_XP_microprocessors
Maximum Front Side Bus support is 266Megahertz.
(Max FSB = 266MHz)
(Motherboard manual states 133MHz.
Note that AMD processors are 'Double-pumped'.
This = 266MHz )
Supports AMD Athlon, AMD Athlon XP, and AMD Duron, processors.
Note in the CPU Support chart where it states -
Socket 462 > AMD Athlon XP > 2600+ (.13u)
The .13u stands for 130nm core architecture technology.
(nm = NanoMeter.
1 Billionth of a Meter )
NOTE*
For the Socket 462 (Socket A) processors, the AMD Athlon XP models are the top of the line.
'Sempy', or Sempron processors are at the bottom.
Low L2 processor memory cache compared to Athlon XP or Duron models.
http://en.wikipedia.org/wiki/List_of_AMD_Duron_microprocessors
http://en.wikipedia.org/wiki/List_of_AMD_Sempron_microprocessors
http://www.cpu-world.com/
http://www.cpu-world.com/CPUs/K7/TYPE-Athlon%20XP.html
Regards,
joecoolvette
Oct 13, 2012 | EliteGroup L7VMM2 Motherboard
Will windows xp supported in amd sempron 145?
No it should not.
However your post does have one confusing detail - XP when installed does not reside on the motherboard but on a Hard Disk Drive. Parts of it will be loaded into memory when you boot up the PC.
If you mean that you are also installing a new Gigabyte MB under an existing installation of XP, you will probably still need the XP system disk for a reinstall of XP as it may not recognise the new MB.
If you are newly installing XP in an existing PC with the specs you mention, it should be ideal. It is best to have enough memory on board, at least 1 Gb.
Nov 20, 2011 | AMD Sempron 145, 2.8 GHz
My system is based on amd athlon 64 bit 3200 processor ... i reinstalled the os and i lost my motherboard cd. bt i need to install my drivers for xp.... give me the link to download d drivers.... thank you
You will need to find the model of your motherboard. It is usually printed on the board itself. Or you can try to use programs to find the information you need. The you can search for the drivers in the manufacturer's support site.
Apr 03, 2010 | AMD Athlon 64 3200+, 2.0 GHz...
Conflict adding RAM memory
you can deselect from BIOS - CAS LATENCY TIMER to value 2, or better (2,5)
Jun 26, 2009 | AMD Athlon XP 2000+, 1.67 GHz Retail...
Can cpu multiplier be set on ecs 6100sm-m mo bo?
Yes, I use AMD's program called Overdrive.
Be warned that increasing the mulipler also increase the voltage, don't go to high or you will have a smoked processor.
Apr 17, 2009 | EliteGroup GeForce 6100SM-M Motherboard
LATE BOOTING OF PC
I would back up all my data and reload a fresh operating system if I were you. Also You could really use more memory. These days 2 gig is light.
Hope this was helpful,
George
Jul 15, 2008 | Intel Motherboard
Dell Optiplex 755 Desktop Desktop Computer  Logo
69 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
