Question about Ovens
Oven keeps turning off
Oven turns off for no reason
Oven was on and all of a sudden I saw flashes of light coming from oven? turned off oven and now oven randomly turns itself on
Does not sound good,
does it give you a error code at all?
the flashes of light sound like a heating element problem, and as far as it turning on itself thats a control issue, I would leave it unplugged for safety reasons.
I am trying to see if I can find some information online about this particular oven.
Aug 23, 2013 | GE Profile JTP18 Electric Single Oven
Electrolux oven wont turn up
Based on the model number you have listed, there are multiple reasons for why your unit may not be turning up the temperature. One of the reasons is most likely the ignitor. Because it may be other multiple possibilities it is recommended that you contact a Service Specialist that can identify that the part that is malfunctioning.
Dec 30, 2012 | Electrolux EOG6330 Gas Single Oven
Electric fan oven
Sounds like the oven thermostat stuck, for whatever reason and then the oven overheat thermostat kicked in. At the very least, I think you will need a new oven thermostat and possibly an overheat one as well. On the 720 there are two, one for each oven, so when you take the oven to bits, check both out.
Dec 17, 2011 | Stoves Ovens
My new oven electrolux EUEE63CS WILL NOT TURN OFF. display lights turn off but oven still going
My oven seems to turn off but the fan keeps working! Takes about 1hr for the fan to turn off after l have turned oven off. Is this normal? Im quite concerned. Will be calling help line monday morning......
Jul 28, 2011 | Electrolux 30" Built-In Double Electric...
Oven light (surface heating) won't turn off
it is normal for it to stay on until the glass gets below 110 degrees it is for safety reason
Oct 05, 2009 | Whirlpool RBS275PD Electric Single Oven
Lost my manual for chef condor integra oven - need to check auto functions and how to set them
For TOuch Control oven:
1. Press Finish Time touch pad
2.press ^ touch pad until clock displays the required am or pm finish time.
3. Press Cook Period touch pad.
4. Adjust the cooking time as in step 2, using up and down arrow touch pads. (hours and minutes needed to cook food)
5. Press Automatic touch pad.
Press Fan touch pad to select fan speed. Red indicating light shows normal speed.
7. Turn oven thermostat to desired setting.
8. Press Keep Warm touch pad if keep warm function is required at end of cooking. 9. At end of cooking time a buzzer will sound for 1 minute and the KEEP WARM cycle will now operate until the meal is ready to be served.
10. To cancel the Automatic cycle, press Manual touch pad and turn oven thermostat off.
For Multifunction oven:
1. Set time of day.
2. Turn Function switch to Finish. 0.00 will be displayed.
3. Turn display switch + to give the required am or pm finish time. (an illuminated bar in the bottom left corner indicates when the clock display is pm).
4. Turn Function switch to Cook then turn Display switch to + till desired cooking period is displayed (hours and minutes needed to cook food)
5. Turn Function switch to Auto. The automatic programme is now ready to use.
Turn upper oven thermostat to desired setting.
If keep warm function is required, turn function switch to Cook (optional)
Happy cooking!
Jun 14, 2009 | Ovens
Oven Light does not turn off
The problem is due to a faulty door switch, this is part of the door lock mechanism. The reason is that the oven thinks the door is open , this puts on the light and stops some of the oven functions ie the fan the fan element and probably the bottom element.
The answer is to fit a new door lock mechanism.
Mar 08, 2008 | De Dietrich DOP390 Pyrolytic Electric...
Jmw8527AAb Jenn Air Electric Wall Oven
Has anyone done any repairs to the oven lately? It sounds like it's working in reverse. The fan is supposed to come on about 10 minutes after the oven is turned on. The reason I ask this question is if someone did work on it they could have wired the fan relay wrong. If not you have a problem with the oven fan relay. They occasionally short and it wll cause them to run the opposite way they are supposed to.
Dec 21, 2007 | Jenn-Air JMW8527C Electric Double Oven
Ovens Logo
121 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
