Question about GE WSLS1500JWW 26" Top Loader Washer with 2.7 cu. ft. Capacity WSLS150
Whirlpool how to clean
Never been drained and cleaned. Dirty shreds now coming out of holes and covering washing. 1995 model. Don't know how to clean filter
    Top Expert:
  • GE Master
  • 37,998 Answers
If your washer was new in 1995 and has never been "drained and cleaned", it may be disintegrating from age.
Posted on Jan 01, 2014
5 Suggested Answers
rpbuice
  • 161 Answers
SOURCE: waont drain
I would check the pump.
Follow the drain hose back to the pump, disconnect the outlet hose from the pump and disconnect the inlet hose from the pump. Look inside both hoses and the pump for pillow pieces.
The pump may have to be removed for cleaning, you should be able to turn the pump by hand, if not, replace the pump.
Inner tub.
Run some water in the washer with the inlet hose disconnected from the pump. You'll need a pan or bucket for the water to run into and look for pillow pieces.
Posted on Dec 21, 2008
blueextc3221
  • 15935 Answers
SOURCE: mine as the front cover to access the filter.I
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%#@
Posted on Sep 28, 2010
FitzOriginal
  • 842 Answers
SOURCE: GE front loading washing machine
The filter is hidden below the lower front panel (3 screws hold this in place) Turn the pump cleanout knob counterclockwise about 2 turns and be ready to mop up any water that leaks out as you remove it. To avoid spillage, you can pull the machine out and tip it backwards 45 degrees.
Posted on Jul 12, 2011
Testimonial: "Thank you so much! This washer has not been used because of not draining for over 6 months. Your advice solved the problem perfectly. THANKS SO MUCH!"
  • 46 Answers
SOURCE: cleaned the filter on the washing machine but
check drain pump
Posted on Sep 27, 2011
The machine says clean pump during the drain phase, I have done this it is clean the block is in the hose, how do I access the pump to clean/remove the hose!! Whirlpool awo/r 5406 thank you
the manual sez there is a cover over the pump-the back may come off so you can see everthing-locate the clean out it should be between the tub and the pump-this is a messy job have plenty of old or dirty towels to soak up spilled water-cheers Denny
Oct 18, 2013 | Washing Machines
Whirlpool Washing Machine won't drain after pump is cleaned and there are no blockages
see the causes and remedies:God bless you
Drain Pump Filter
This is the most common problem. Some have a small cover in the lower front put a screwdriver in the hole and turn counterclockwise to remove. There will be a cover to remove, water will come out so be prepared with a towel or wet vac. Clean this out. Other Machines will need to access the drain pump to get to the filter. This can be done by removing the back panel on some washers. On others you will need to remove the lower panel or complete front panel depending on model. The filter is located inside the large hose from the tub to the pump. Remove the hose and clean filter.
Drain Pump
The drain pump may have failed. If you hear it making noises you will need to remove the drain pump and check for obstructions, broken impeller, or not spinning freely. Remove obstructions if it does not spin freely replace the drain pump. If you hear it hum replace the pump if nothing is found inside. If no noise is heard check the pump for power. To do this remove the wire connectors and connect a voltmeter turn to a drain cycle, refer to tech sheet or service manual for proper voltage reading, usually any voltage would probally indicate a faulty pump. If no voltage to the pump replace the main control board.
Hoses
Check the hoses from the pump by disconnecting them and make sure there are no obstructions. Check your hoes drain, if it is a slow drain this can cause your washer to not properly drain.
Jul 18, 2012 | Whirlpool Washing Machines
After running a full cycle the dishes have a film left on them. Sometimes soap is not rinsred off the dishes. Tried different soaps for dish washers. It seems the only thing to take the film off of the...
Film on dishes post cycle is caused by 2 things.... Poor water flow during the wash / rinse cycle.... i.e clogged sump inlets or restricted drains. Clean the drain hose first. Start at the cink connection and clean EVERY connection and in-line componenet from the port hole at the sink connection all the way back to the drain hise connection port at the dishwasher.
If you still have dirty dishes post cycle after drain cleaning... then remove the lower wash arm support and clean the accumulator / sump area thoroughly. See this link: (items 1 and 4) http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5140844&diagram_id=28222738#d28222738
Test again.
If the problem persists you will have to gain access to the pump impeller. Inspect the impeller, and pump housing for damage. UNDER the dishwasher. Item 22 of the above link.
This should get your diswasher performing properly again.
I used this model number as a reference: GU2400XTPB1
Thanks for choosing FixYa,
Kelly
Jun 03, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
Want to know how to get sour, musty smell out of Whirlpool Duet washer.
Thanks for using FixYa!!
Nov 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Clean pump
If this is a Whirlpool Duet model washer, the following link explains step-by-step, how to access and clean the drain pump:
http://www.fixya.com/support/r3574284-checking_the_drain_pump_on_a_front_loade
If this is not the model washer you have, or if you require additional assistance, please post back and let me know. I hope this is helpful to you.
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Wash machine won't drain. I tried to clean a very old dirty rug and when I opened the door, it was shredded. I cleaned it out but, it wont' drain the water out.
your pump / drain in the bottom is clogged up turn the machine over after taking out all the water and then !! remove the pump and clean it and the drain hose
Jan 19, 2010 | Washing Machines
Dishes don't come out clean grit feel to them
Not knowing the make and model of your dishwasher makes it hard to be specific. But, depending on its age, your problem may be debris blocking both the holes in the wash arms and the filter that is beneath the lower wash arm.
Inspect the wash arm holes and get them all cleaned out.
Remove the screws that hold what ever filter assembly that lives beneath the lower wash arm. Use a flashlight to inspect the entire sump area, looking for debris. Inspect the impeller down there, making sure it can spin freely and is not damaged
Reassemble and test. Run a short cycle empty and wait for the dishwasher to fill and begin to wash. Open the door and pour in up to 2 cups of white vinegar. When the DW drains, inspect the inside and see if you want to add more vinegar the next cycle _after_ the washer refills and begins to wash or rinse.
Run a load of dirty dishes and check for cleaning improvement. If you still have problems, the wash pump/motor assembly will need to be replaced.
Good Luck!
May 09, 2009 | Dishwashers
WHIRLPOOL DUET MODEL GHW9150PW1 doesnt complete wash cycles
FO2 is the code for long drain. The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully.
Apr 04, 2009 | Whirlpool Washing Machines
Draining
Plug off the mains. First drain out all your water by lowering the exit hose into a bucket or drain. You have to look for screws below the front kick-panel, the panel comes down & out. The pump is on the right side. Be prepared for dirty water. Inside the big flexible tube (coming from the tub bottom) is the filter, be prepared to find all sorts of junk here, clean out. Examine your pump also, clean out the impeller. Carefully refit all. Your machine would be fine. Don’t wait for the machine to jam to look into your filter.
Mar 30, 2009 | Whirlpool Washing Machines
Remove the sheet metal panel from Whirlpool refridge
the rear panel is not removable. you need to clean the drain from inside the freezer compartment.
  • 1 remove food from freezer
  • 2 remove shelving and icemaker if equipped
  • 3 remover rear access cover in freezer usually 2 or 3 screw
  • 4 clean ice out from underneath the coil you will uncover the drain hole
  • 5 force hot water thru drain hole i use a turkey baster or large syringe
  • 6 reassemble in reverse order.
if you have any further questions please ask here and I'll be glad to assist any way I can. thanks Peyton
Mar 05, 2009 | Kenmore 73262 / 73264 / 73269 Top Freezer...
GE WSLS1500JWW 26" Top Loader Washer with 2.7 cu. ft. Capacity WSLS150 Logo
212 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
