Question about Toshiba Televison & Video
How to retune toshiba tv - Toshiba Televison & Video
How to retune tv programmes tv telling me to retune but i cannot access instructions on tv?
Depending on the TV model, if you do not have the instructions for the TV/remote, you may just have to play around with the options via the remote and find the choice for retuning the stations.
Sep 18, 2014 | Televison & Video
How do I set up channels on my toshiba TV
Go to the autosearch function and initiate programming. Be sure your antenna is properly connected and placed before doing this.
Aug 09, 2014 | Televison & Video
Toshiba regza
You may have power supply trouble
May 14, 2013 | Televison & Video
How do I retune My toshiba ct 90240 hd tv
Just download the user manual to your tV from internet. It will have all the details. Get into 'toshiba.com/download/manual' site.
Apr 09, 2012 | Televison & Video
How to retrieve lost channels on digital tv
To restore missing channels, you need to retune your digital receiver (box or TV).
The retuning process runs a scan and finds all the available channels. Your box may have an Add New Channels option that you can use, but this may not pick up other changes such as channels being moved to a different multiplex or removed altogether.
How to retune
  1. Switch on your digital box and/or TV.
  2. Press Menu on the remote control.
  3. Select the Setup or Installation option.
  4. Select the 'First time installation' option (sometimes called 'Factory reset', 'Full retune' or 'Default settings').
  5. Press OK if your equipment asks if you want to delete all your channels. Don't worry, this is normal.
  6. If you are prompted for a code, try 0000 or 1234.
  7. Channels will be automatically installed. This may take a few minutes and your equipment may shut down and restart.
  8. After retuning, you will have to redo your Favourites list and other settings. If you retune a digital TV recorder, you also should reset future recordings.
Feb 27, 2012 | Toshiba Televison & Video
How do I retune a Toshiba 1450TB TV
long push on TUNE at the tv set
Dec 29, 2009 | Televison & Video
I have retuned my parents tv but now the digital (freeview) channels do not have the correct channel numbers and I cannot find anything in the manual as to how to change them. For example, freeview channel...
It sounds like the TV has re-mapped the channels incorrectly. You possibly can contact Toshiba to see if there is a firmware/software upgrade that will fix this issue. If there is you may be able to download the software off of their website and install yourself. Just make sure if that is the case follow the directions carefully. Please take a few moments to rate my answer. Thanks..
Nov 19, 2009 | Toshiba 32WLT58 32 in. LCD Television
Since retuning Novemder 2009 cannot receive BBC1, BBC2 or BBC3
sounds like power surge. try unplugging unit from wall. wait 2 minutes. this reset the microprocessor in the tv. plug back in and enjoy!
Nov 09, 2009 | Toshiba 50H81 50" Rear Projection...
Retune for channel 5
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit
http://tvretune.co.uk/productmanuals
Sep 30, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Seeking manual or tuning instruction for a 32
For specific model information visit http://tvretune.co.uk/productmanuals/
May 23, 2008 | Toshiba 32A33 32" TV
Televison & Video Logo
180 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
