Question about Lenovo IdeaPad Computers & Internet
Down arrow key not working - IdeaPad Lenovo Computers & Internet
Want to lighten screen
Most laptops use a function+key combination to change the screen brightness. The icon is usally something obvious like a sun with up and down arrows or a level symbol. On my laptop my up arrow has a picture of a sun with an arrow up and the down arrow has a sun with an arrow down. I control it by holding the function button down, labeled Fn, then pressing the up arrow or the down arrow depending on which way I want it to go. Many laptops also use the function keys across the top instead of the arrow keys but they are used the same way, hold the function key down and press the key for the direction you want to go with the brightness. If you can send me your laptop model then I can get the exact way it can be done.
Jul 27, 2011 | Computers & Internet
Dell mouse not responding; diagnostics results says test passed. mouse works on other PC
There is a very good chance it's one of two problems. First, while theoretically you can connect tons of USB products, sometimes USB ports can be kind of hinky... Try unplugging something else USB based and plugging in the mouse or try several different ports. Also be sure it's not plugged into a USB hub and is going directly into your computer. If this works play with the arrangement of your USB devices until you find a configuration that works, maybe you'll have to switch out a printer or external drive while using your USB mouse...
If this doesn't provide a solution the next thing to do is to uninstall the pointer device driver in device manager and allow it to re-install.
If you don't have an alternate mouse to complete the task, here is the keyboard shortcuts for Windows although depending on your version of Windows it may be slightly different.
-First hold the windows key and hit the r key (win+r)
this will bring up the run menu
-Next type mmc this will bring up a management console
-Next press the ALT key and hit the down arrow key
(this should drop down the file menu, if it doesn't please try ALT+F)
-Use the arrow key to scroll down to Add/Remove snap in and hit enter.
-Use the arrow key to scroll down to Device Manager and hit ALT+A to add the device manager to the console. Hit enter.
-Make sure local computer is selected if this menu comes up and hit enter.
-Hit enter one more time bringing you back to the console with the device manager added.
-Hit tab to get to the center console and scroll down to mouse.
(If tab isn't doing anything please hit the ALT key once.)
-Hit enter to open the tree if it isn't already
-Scroll down to mice and other pointing devices (or something along these lines) and hit the right arrow key to expand the tree again.
-Select the USB mouse with arrow keys
-Hit the alt key again then the down arrow (not together) and then the right arrow key until you get to the action menu and use the arrow key to go down to uninstall and hit enter.
-Wait a moment and then go back to the action menu (you may have to hit tab just keep trying tab and the down key (not together) until a menu opens. Go over to the action menu again and choose scan for hardware changes. The computer should recognize the mouse and now work.
I hope this helps you. Thank you.
Jan 04, 2011 | Dell U0636 Mouse
Ringer off on line 2
To turn the ringer off (or on)
press the conf/ function key,
scroll to "ringer volume" using the up and down arrow keysand press the forward arrow key
press the down arrow key for line 1 and the up arrow key for line 2
select the desired ringer volume by pressing the up and down arrow keys or press the down arrow repeatedly till the screen says "ringer off?"
press the save key (right soft key) you will recieve a conformation beep.
you can exit programming mode by pressing the off key.
Jul 20, 2010 | Panasonic KX-TG2740 Cordless Phone
Olevia not searching channels
try the following..
Q. Why are the menu settings that I changed not being saved? A. The TV is in Showroom mode. The following steps will help you switch to Home mode.
  1. Press Menu button from the remote,
  2. Press Down arrow key until you see the word Picture, then press the Right arrow key,
  3. Press Down arrow key until you see Mode, then press the Right arrow key,
  4. Press Down arrow key until you see Power Up, then press the Right arrow key,
  5. Press Down arrow key until you see Home, then press the Enter key,
  6. Press Menu button four times to exit out from the OSD Menu.
***Showroom mode is designed for retailers to display the TV and to protect from shoppers changing the settings that are predetermined for shelf display environment.***.
Q. Why does my TV display "No Signal" or "Channel not in List"? A. Channel search needs to run the very first time of use or after the default settings are loaded from the OSD menu. The following steps will guide you through the process.
  1. Press Source button until Tuner is visible on the upper right corner,
  2. Press Menu button from the remote,
  3. Press Down arrow key until you see Setup, then press the Right arrow key,
  4. Press Down arrow key until you see TV, then press the Right arrow key,
  5. Press Down arrow key until you see Auto Channel Search, then press the Right arrow key,
  6. Press Down arrow key until you see Air (for antenna; select Cable if you have cable service), then press the Right arrow key. The scan process will start.
  7. Wait until the process is complete then you will be able to select the channel you like to watch.
Jul 29, 2009 | Televison & Video
Tv is in showroom mode cant change it
Jun 19, 2009 | Olevia 227-S11 27 in. LCD TV
I've been a geek since the late 80s. I've been seeing my Yahoo email database is not working right. I press the down arrow, it goes up. I press the up arrow it goes down. Anything I can do about it?
It sounds like the arrows are in the worng places. Have you checked to make sure that the up arrow is on the up key and the down arrow is on the down key. If not I suggest you do this and either get a replacement keyboard or replace you keys. Either way it is your choice. Let me know if these help.
Jun 13, 2009 | Gateway MT6451 Notebook
I can't turn closed-captioning off
hope this solves the problem
giv feed back
Apr 02, 2009 | Olevia 227-S11 27 in. LCD TV
My EEE PC 4G webcam is not working
Go into the BIOS Setup (press F2 when the screen lites up).
Right arrow key to Advanced
Down Arrow key to Onboard Devices Configuration
Enter
Arrow key down to Onboard Camera
Enter
Arrow key to Enable
Enter key
F10
Enter
Hopefully that takes care of it. :)
Oct 28, 2008 | ASUS Eee 4G Notebook
Tv signal locked
A: The TV is in Showroom mode. The following steps will help you switch to Home mode. 1) Press Menu button from the remote,
2) Press Down arrow key until you see the word Picture, then press the Right arrow key,
3) Press Down arrow key until you see Mode, then press the Right arrow key,
4) Press Down arrow key until you see Power Up, then press the Right arrow key,
5) Press Down arrow key until you see Home, then press the Enter key,
6) Press Menu button four times to exit out from the OSD Menu.
Dec 10, 2007 | Olevia LT27HVX 27 in. LCD Television
27 INCH OLEVIA LCD FLATSCREEN
I had the same problem....
The CC button should work now.
Sep 07, 2007 | Olevia LT32HVE 32 in. LCD Television
Computers & Internet Logo
77 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
rey francis basa
rey francis basa
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
