Question about Spy Optics 2013 Spy Targa Mini Goggles-Motocross Gear
Targa lx moped runs for 5-10 sec then dies - Spy Optics 2013 Spy Targa Mini Goggles-Motocross Gear
Would like to buy new decals for Targa lx
You can find them basically anywhere.
Start at 1977mopeds.com
Sep 27, 2013 | 2005 Tomos LX
What is the gas oil ratio for a 2001 Honda Elite SR moped
Hi, Anonymous for this scenario you will need your service manual, parts fiche, and owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $15 you can download another one.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Honda Elite SR LX SA50 Motor Scooter Guide
Oil Ratio 49ccScoot com Scooter Forums
SA50 ELITE 50 LX 1988 HONDA SERVICE REPAIR MANUAL Download Manuals $15
https://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 SA50P Elite Owner Manual
Sep 23, 2012 | Honda Elite Motorcycles
I was driving my 2001 tomos targa lx moped when it just died
sounds like its running out of gas check for a restricted fuel line or partially plugged filter
Jun 19, 2012 | Motorcycles
Moped won't stay running on low throttle, it will
Your IDLING JET IS CLOGGED or the settings on the SLOW speed on the idling screw is not correct. Sometimes dirt can cause issues and so it might need an overhauling of the carburater.
Jul 28, 2011 | 2007 Generic XOR 50
1995 Targa LX- starts with full choke, runs fast for 10+ seconds and then stalls but can easily be restarted by using the choke with the same results. Gas is flowing freely from tank.
Had same problem,if you take the carb off,take the nylon bushing out, look into manifold side of carb,there should be a very small hole there,that is a fuel passage(idle jet),more than likely it is clogged,use a bread tie and clean it,while carb is off you may want to clean and rebuild carb,hope that helps you out.
Feb 07, 2011 | 2005 Tomos Se 125 F
Moped engine will start, but will die when given gas
It sounds like you have answered your own question automatic chokes are designed to keep the motor runnning at Idle until the machine is warmed up while I dont think they are a good thing on motor cycles particularly in warmer climates. the one question I must ask how many k's has this little beast travelled if its alot being two stroke it is probably due for a decoke & a new set of rings if not A rebore new piston &rings all the best
Mar 02, 2010 | Qianjiang QJ100-2 Motorcycles
96 ford t bird 3.8 starts run about 30 sec and dies after setting for awhile it will do it agion. fule pump wont stay running
two things you can check . look in the trunk on the passenger rear side behind the carpet there is a fuel pump shut off switch make sure the harness wasn't bumped , also there is a fuel pump relay that might be getting hot under the hood near the Fuses on the inner finder well . Good luck
Sep 04, 2009 | 1996 Ford Thunderbird LX
Spy Optics 2013 Spy Targa Mini Goggles-Motocross Gear Logo
Top Spy Optics Motorsports Experts
chuck ringwood
chuck ringwood
Jim Rus
Jim Rus
rapboy 55
rapboy 55
Level 1 Expert
Are you a Spy Optics Motorsport Expert? Answer questions, earn points and help others
