Question about Tunturi Exercise & Fitness
T80 - leg cable got disconnected from console cable - they are all white wires without a plug - need to know which white wires connect to colour wires in leg cable.
    Top Expert:
  • Tunturi Master
  • 36,418 Answers
Turturi may be able to supply the information you need.
Posted on Jan 01, 2014
I have problem in the bt incoming socket in my house. it seems to be between the bt test socket and the customer outlet can you supply info on this wired connection super hub works on test socket but
Modern wiring, if you have broadband, only uses two wires.
They consist of the A leg and the B leg. The A leg is connected to connexion 2; the B leg to connexion 5.
Other connexions are concerned with earth (usually for party lines) and ringing (for telephones not on an ADSL line--telephones on ADSL get their ringing current derived from the flter). These other two wires should now be disconnected as they can cause noise.
The wires are in pairs, the blue on white has a pair, which has a little white on blue; the orange on white's pair is white on orange.
It sounds as though the blue pair are the A and B leg, and should be connected to 2 and 5.
Check on another telephone socket (it should be wired exactly the same).
Feb 05, 2015 | Lands Phones
Wiring connection diagram
Sorry but i do not know of any tv that uses ground wires,
if you mean rca cables these have coloured plugs either red,white and yellow or red blue and green,if you look into the sockets on the back of the tv you will see the matching colours
Sep 03, 2014 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
2008 Jetta upstream O2 sensor
Right do you mean the wires to the O2 sensor from the loom or the wires from the plug to the sensor ,So i will explain what i know here and thats all i can do for you.On our europeon motors their is a 4 and 3 wire O2 sensor type,now on the sensor side of the plug their will be two wires the same colour normally white or gray ,these two wires are the heater circuit so should show a resistance with a meter ,now the coresponding two wires in the loom plug should read 12v with the plug disconnected ignition on .Now the other two wires are for the readings so push a pin through each cable and then with engine running plug connected you should read 0-point something which varies with engine speed somewhere between point 7 to point 2 varying with speed .if it stays around the point 4 mark then replace as its not working correctly ,you should be able to read the voltages with a code reader though
Jun 05, 2013 | Cars & Trucks
I need a wiring diagram for a 274A Light switch/ plug in. Everything we try, we are not getting anywhere.
There are more than a few ways to wire this device. The switch box where the device is installed _must_ have a neutral wire for the receptacle to work. This is usually a white wire.
The switch box should have at least 2 cables in it. One cable is the incoming HOT(black) and neutral(white) from the circuit breaker panel (or source). The second cable is the outgoing switch leg(black) and neutral(white) to the light. Each cable should have a bare equipment grounding wire.
The most common way to install this device is to connect the hot wire to one of the black screws, pick one. ( I'm assuming that you have _not_ removed the brass tab between the 2 black screws.)
The 2 neutral (white) wires are twisted together under a wirenut along with a pigtail which connects to the silver screw on the device.
The black wire that goes to the light (switch leg) is then connected to the brass or gold screw.
The bare ground wires are twisted together under a wirenut along with a pigtail which is connected to the green screw.
Aug 28, 2010 | Cooper Industries Cooper Wiring 274W...
Electrical hookup
Tie all the black wires together and connect to the black power wire coming from the switch. Tie all the white wires together and connect to the white wire coming from the switch. If this does not work then what you have is a switch leg going to the light. This will be just a white and black wire coming from the switch with another power wire going in. Look at the switch and see if you have a white and black wire connected to the 2 screws. if so this is a switch leg. You will have to disconnect all the black wires in the light mount and find which one is carrying power in. Let me know what you find and we will proceed.
May 23, 2010 | Home
Im fitting a new light fitting i have 3 cables from the ceiling the orginal power cable , the switch cable and another cable to feed another light in my light fitting i have live neutral and loop what...
The grounds go together and perhaps to the fixture.
The white/ neutrals are also all tied together and one goes to the light. Note that one neutral may not actually be that, but is simply one of the pair of wires going down to the switch.
Then you need power connected to one leg going down to the switch (maybe a white one) and the return leg from the switch goes to the light.
Hope this helps. Let me know if not
Nov 06, 2009 | Hardware & Accessories
Black and white picture only - ps2 slimline
The cable isprobably faulty or damaged. Try replacing it with another one. The socket on the back marked network is a ethernet port which allows players to connect to the PSN or Playstation Network allowing you to game other people around the world with supported games
Jan 27, 2009 | Sony PlayStation Portable (PSP) Console
Hd connection for wii
The red and white ones, that should be linked or the same are sound.
Dec 26, 2008 | Nintendo Wii Console
Wii component cable - how to connect it?
on your tv, there should be color coded ports that tell you which cords go where but im almost 100% sure that the red and white cords are for sound and the blue and green cables are for hd video hookups.
Oct 14, 2008 | Nintendo Wii Console
BadColour
switch the av cable to hd setting
Mar 25, 2008 | Microsoft Xbox 360 Console
Exercise & Fitness Logo
27 people viewed this question
Top Tunturi Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Tunturi Exercise and Fitnes Expert? Answer questions, earn points and help others
