Kenmore oasis recall - Washing Machines
5 Suggested Answers
SOURCE: recall on kenmore oasis
I have one of the first kenmore oasis and I get the F1 and off balance error all the time I called the recall number line is 1 (800) 659 7026 they said that they are doing a free upgrade to replace the control board the only problem is the board is on a back order and it may take a week to get the part in.
Posted on May 05, 2009
blueextc3221
  • 15935 Answers
SOURCE: F1 code on Kenmore Elite Oasis. Is there a recall?
The F1 error code on this washer indicates a Primary Control Board failure.
It is likely that the machine control board will need to be replaced to correct this problem.
The part number for the machine control board is undetermineable because you have not provided me with the exact model # of your washer.
The procedure for replacing the machine control board is provided HERE
LINK: http://media.fotki.com/1_p,wfgstgtftbtkrrdxgtqsskgwtqkq,vi/gfsfgfsgqxgfqtqtgwf/1/1303472/5961857/image55806img-or.gif
NOTE: Be sure to unplug the washer to disconnect electrical power before accessing internal components.
There is a slight possibility that a problem with the pressure switch hose could be causing this problem.
A pinched or twisted air hose can cause this fault code.
When you open the console, check the air hose connected to the pressure switch on the machine control board.
If it is pinched or crimped, I recommend rerouting the hose to resolve this problem.
This may fix your problem without replacing the control board.
NOTE: You may want to check for this condition before ordering the control board. Most electronic control boards cannot be returned for a refund or credit.
If you find no apparent problems with the air hose on the pressure switch, then replacing the machine control board on this washer should correct your problem. There is a risk involved in replacing this part yourself.
As noted above, you could have a problem with the air pressure hose that is not apparent upon your initial inspection. A service technician would normally need to properly and thoroughly diagnose this problem before replacing the control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question!!!!!
Posted on Sep 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite Oasis HE 27072 water temp changes
It appears your dual inlet water valve has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: Is the Kenmore Elite Oasis top load washing
No recall that I am aware of.
Posted on Sep 30, 2010
Kenmore dryer recall
Any recalls on Kenmore Elite Oasis Electric dryer?
it seems many people had problems with the control board
Jan 11, 2014 | Kenmore 63102 Electric Dryer
Has my Kenmore Elite Model 110.27082603 been recalled?
I am trying to find out if my Kenmore Elite Oasis HE model # 11027062603 has been recalled. Thanks
Mar 28, 2013 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite Oasis dryer has a CF code and continuously beeps. Running or not.
The CF error is a communication failure between the main computer and the touch panel...you may have a bad or weak connection or a bad computer..I wold recommend that you contact your local Sears and ask them about recalls, and for service should this happen again.
May 07, 2012 | Kenmore Elite Oasis 6808 Electric Dryer
KENMORE OASIS WASHER DISPLAYS Ld CODE AND WILL NOT DRAIN WARER FROM TUB
I have the kenmoe Oasis he and out of no where this machine wont work. You push the start button and select and that is it 'Nothing" you have to unplug it and start over again but the same thing will happen "nothing" and plus the water wont drain! I feel this is a rip off machine. house wife
Dec 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
What does F1 code mean
Call 800-659-7026, which is Sears Recall Department. Give them your model and serial number and they will check to see if your machine is one that is being "upgraded'.
There has been an recall issued for this model of kenmore washer.
Aug 27, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Machine cycles through heavy to light loads continually
I have the Oasis HE 27082604 and have been having the same problem as everyone else is. I called Sears and other numbers and they said it was beyond their control and this washer wasnt recalled. So they wouldnt honor it. Does anyone have a recall number. They say there is no recall on these washers.
Mar 08, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Hi! Can you help me decide if the Kenmore oasis 3.8pc is a good washing machine.
The Kenmore Oasis is made by Whirlpool for Sears. It is the same as the Whirlpool Cabrio. The Cabrio and the Oasis had a problem with the computer board. Whirlpool has been replacing the computer boards under a recall(mine was replaced recently). But I believe it is the model with no agitator in it. The one your talking about I believe is the one with the agitator. Whirlpool makes a good product. I would stay away from Maytag. Besides the recall problem I have had mine for over 2 years and it has worked fine. But I did get the extended warranty with it due to all the sensors and computer board can make repairs expensive.I have not had to use the extended warranty yet. My previous Kenmore washer was 12 years old and stopped working due to a rat chewed thru all the wiring and hoses. It would have cost me more to repair than what it was worth so I purchased the Cabrio.
Sep 27, 2009 | Kenmore 24032\24036 Top Load Washer
Is the Kenmore Elite Oasis top load washing machine being recalled as I've heard
Jun 03, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Recall on kenmore oasis
Jul 19, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Washing Machines Logo
447 people viewed this question
Top Washing Machines Experts
