Question about Cisco SR224 24-Port Ethernet Switch
My cisco sr224 24-port suddenly turn the power off during the operations can u help me to fix it?
36 hrs of continous use on my cisco sr224 and suddenly the power turn off. and now the cisco doesnt work at all can u help me fix the problem?
The power devices that Cisco Catalyst 2960 Series Support?
The Cisco Catalyst 2960-48PST-L can support 48 PoE ports with total PoE power output capacity at 370W. Taking advantage of Cisco Catalyst Intelligent Power Management, the Cisco Catalyst 2960-48PST-L configuration can deliver the necessary power to support 24 ports at 15.4W, 48 ports at 7.7W, or any combination in between.
The Cisco Catalyst 2960-24PC-L can support 24 simultaneous full-powered PoE devices at 15.4W for maximum powered-device support.
The Cisco Catalyst 2960-24LT-L can support eight PoE devices at 15.4W
Cisco Catalyst 2960 Switches for the details
Aug 15, 2014 | Computers & Internet
Tip
Cisco 1800 Series, Business Router for Small to Medium Sized Business/Enterprise
Cisco 1800 Series Integrated Services Routers, the next evolution of the award-winning Cisco 1700 Series modular access routers, own more advantages than the formers. Cisco 1800 series, ideal for small to medium-sized businesses and small enterprise branch offices, enable businesses to reduce costs by deploying a single, resilient system for fast, secure, delivery of multiple mission-critical business services, including data, security, unified communications, wireless.<br /><br /><a href="http://www.router-switch.com/Price-cisco-routers-cisco-router-1800-series_c17">Cisco 1800 series router</a> has several models including 1801, 1802, 1803, 1811, 1812, 1841(most popular), 1861, all of them have some common features: a. Designed for small businesses or branch offices and to offer secure wireless networking; b. Multiple performance options based on local, remote, or broadband connections; c. Integrated security including encryption and protection against hackers; d. Virtual private networks for linking to partners, suppliers, and remote offices; e. Multiple options for adding reliability and option for reduced costs by using power from network cabling; f. Software upgrades to add new features and functions, and integrated switching capabilities.<br /><br /><a href="http://www.router-switch.com/Price-cisco-routers-cisco-router-1800-series_c17">Cisco 1800 series</a> router has several models including 1801, 1802, 1803, 1811, 1812, <a href="http://www.router-switch.com/cisco1841-p-97.html">1841</a>(most popular), 1861. You can check details of every type as follows:<br />The fixed platform models (1801, 1802, 1803, 1811, 1812) include multiple WAN interface options, plus:<br />Up to broadband speeds<br />Eight 10/100 Mbps built-in switch ports with optional Power over Ethernet (PoE), for providing DC power to network devices such as IP phones<br />Up to 50 VPN tunnels<br />Support for wireless local-area network (LAN) standards 802.11a/b/g<br /><br />The 1841 is a modular platform with a wide range of interface options, plus:<br />Up to T1/E1speeds<br />Up to four 10/100 Mbps built-in switch ports<br />Up to 800 VPN tunnels<br />Support for wireless local-area network (LAN) standards 802.11a/b/g<br /><br />The 1861 is a modular platform built on a fixed base with a wide range of WAN interface options, plus: <br />Integrated Cisco Unified Communications Manager Express or Cisco Unified Survivable Remote Site Telephony for call processing<br />Cisco Unity Express, for voice messaging and automated attendant<br />Integrated LAN switching with Power over Ethernet (PoE) expandable through Cisco Catalyst Switches<br />Onboard voice ports for PSTN, PBX, and key system connections<br /><br />With Cisco 1800 Series integrated services routers; you can lay the foundation for future growth and prepare for voice, video, wireless, and security solutions tomorrow. <br /><br />If you want to know more about e about the certain type of Cisco 1800 series, you can visit the list of Cisco 1800 router series, prices also offered.<br /><br />
on Jun 30, 2011 | Computers & Internet
Default password for a Cisco SG200-26? cisco, cisco do not work .. ??
I had the same issue after what I thought was a succesful reset. It turns out I hadn't reset the switch completely. There is a reset pin hole next to the power switch. Hold it in with a paper clip for at least 30 seconds. ( I was holding in the power button for 30 seconds.)Then you can use the cisco admin and cisco for password defaults. Hope this helps someone in the future since I spent WAY TOO MUCH TIME on it :)
Oct 27, 2012 | Cisco SG200-26 24 10/100/1000 Ports,...
I am trying to add an additional PoE device, put it will not power up. How can I tell the switch to power up a specific port, or put the switch into automatic mode?
Are you within the power budget?
Power feeding of Ethernet is limited for fixed 10BASE-T/100BASE-TX ports. The solution can provide maximum output power per PoE port up to 15.4W on 12 ports or 7.5W on 24 ports simultaneously. The Switch provides independent overload and short-circuit protection for each port, LED indicators for power status per PoE port, and supports IEEE802.3af MIB for Power over Ethernet functionality.
For each attached 802.3af-compliant device, the Switch automatically senses the load and dynamically supplies the required power. The Switch delivers power to a device using the two data wire pairs in the twisted-pair cable. Each port can provide up to 15.4W of power at the standard -48 VDC voltage.
Source: http://www.cisco.com/en/US/products/ps9967/products_qanda_item09186a0080a36afb.shtml
Mar 19, 2011 | Cisco Systems 24-Port SF 300-24P 10/100...
Hi Dear, My Name is sajid. I am facing problem in catalyst 3550 switch. in which ports already kept going up/down continously
Can you post the contents of your running config to this post?
Telnet into your switch, and use the command show run - copy and paste the output
Jan 21, 2011 | Cisco Catalyst 3550-24 24-Port Ethernet...
No wireless connection for laptop. Linksys router - model #wrt160n v2
you can run a direct line to that router and go to the cisco web site and get the information you need to run that router. its a pdf format and is 2.56 Meg. Try this
SecureEasySetup (Orange/White) The Cisco logo is the Router's SecureEasySetup button. It
lights up and will stay orange when the Router is powered on. The color orange indicates that
the Router is not using the SecureEasySetup feature, while the color white indicates that the
Router is using the SecureEasySetup feature. When the Router enters SecureEasySetup
mode, the Cisco logo will turn white and start flashing. After the Router has generated
the SSID and WPA Personal key, the Cisco logo will stop flashing and stay white.
To clear the SSID and WPA Personal key, press and hold down the Cisco logo for five seconds.
The Cisco logo will flash slowly as the Router resets itself. The Cisco logo will turn orange to
indicate a successful reset.NOTE: SecureEasySetup is a feature that makes
it easy to set up your wireless network. If you have SecureEasySetup devices, run the Router's
Setup Wizard CD-ROM and follow the onscreen instructions to use SecureEasySetup.
Power (Green) The Power LED lights up and will stay on while the Router is powered
on. When the Router goes through its selfdiagnostic mode during every boot-up, this
LED will flash. When the diagnostic is complete, the LED will be solidly lit.
DMZ (Green) The DMZ LED indicates when the DMZ function is being used. This LED will
remain lit as long as DMZ is enabled. WLAN (Green) The WLAN LED lights up when
the wireless feature is enabled. If the LED is flashing, the Router is actively sending or
receiving data over the network. 1, 2, 3, 4 (Green) These numbered LEDs, corresponding with the numbered ports on the Router's back panel, serve two purposes. If the LED is continuously lit, the Router is successfully connected to a device through that port. A flashing LED indicates network activity over that port.
Internet (Green) The Internet LED lights up when there is a connection made through the
Internet port. A flashing LED indicates network activity over the Internet port.
Good luck
Nov 26, 2010 | Computers & Internet
HP DX2400 causes Cisco 3560 ports to be err-disabled
Get a Dell? Nope or put some pci/pcie ethernet cards in them and see if that fixes it :)
Aug 20, 2009 | HP Compaq Business Desktop dx2400
Cisco 2960 power supply
The Cisco 2960 has a life time warranty. Contact the seller and they should be able to get the switch exchanged at no cost.
Jul 31, 2008 | Cisco Rf Catalyst 2960 24-PORT 10/10
Avaya to Cisco TG
Is this problem solved yet?
Jun 02, 2008 | Avaya 4610
Cisco SR224 24-Port Ethernet Switch Logo
29 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
