Question about Saeco Royal Professional Espresso Machine
Coffee grinder in machine not working - Saeco Royal Professional Espresso Machine
  • 8 Answers
SOURCE: Coffee beans will not grind
If the grinder is blocked try changing the grinder setting up to the coarsest setting (I think it is numbered 16 on this model) and then vacuum or fill with beans and push them through. Be sure that any damp coffee has gone as you don't want the grinder blades to be left wet.
Never freeze or refrigerate your coffee beans as the condensation from doing this can also block your grinder. Also never use coffees that have been flavoured during the roasting process as they are often too sticky or oily and will block your grinder. These coffees should be ground using a grinder that can be easily pulled apart for cleaning...which is not the case in the Saeco automatic machines.
After you have finished clearing your grinder you will want to turn it back down to a finer setting ( a setting of 6 or 7 works well on this model) however you should only turn the grinder setting finer while the machine is actaully grinding. Otherwise you may find the coffee beans jam between the blades.
If you are unable to clear the blockage it might need to go to a technician.
Posted on Dec 09, 2007
  • 74 Answers
SOURCE: Grinder says no coffee beans after grinding, why?
does it realease the grinded coffe beans in the dregdraw with out using it?
if that is the case it a very small electricboard on the grinder that has stoped working or the connecter has fallen of from it.
Posted on Jul 11, 2008
mirran
  • 515 Answers
SOURCE: coffee grnder not working
Try to cantact Saeco Australia ( www.saeco.au), or Saeco Italy (www.saeco.it).
They should know where you can get spare parts.
Best regards
/Mirran
Posted on Jan 29, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: How do you take apart the grinder on Saeco Spidem Villa Household Coffee Machine
There should be screws on the side or the bottom of the unit that will allow you to pull it apart. The problem seems to be that the two grinding wheels have gone bad and needs to be replaced. On this unit you cannot adjust the grinding as far as would need to be to fix the problem when the teeth get to small
Posted on Jun 03, 2009
  • 60 Answers
SOURCE: Machine has major problem with grinding beans.
Try removing all beans from bean holder - then use a vacumn machine to remove the bits down amongst the grinder "teeth'. You may have had a small stone in your coffee and if so it may have jammed the grinder.
Once it looks clean, try making a cup of coffee without the beans in the hopper - you should be able to see and hear the grinder revolving and also hear the brew unit moving between the grinder outlet and the water inlet. If it all seems ok now, then add a small amount of beans back into the beans hopper and try making a coffee. If it still will not work, get it serviced. There's not much the average person can do inside these units other than to do more serious damage or kill themselves with an electric shock.
Posted on Nov 07, 2009
What is problem of coffee grinder not working
if the machine is ready to go and the grinder not start check to see if is not block the grinder blade and if not block change the grinder with the same voltage one 120V or 220V
Feb 18, 2015 | Saeco Primea Cappuccino Touch Plus Coffee...
Why does no brewed coffee comes out? bypass preground does work
- coffee-channel is stuck.
check google for calibrating/cleaning your gaggia.
Aug 27, 2014 | Gaggia Titanium Espresso Machine
Hi - I have a miele cva5060 coffee machine. The grinder has stopped working, any ideas or solutions?
Sounds like grinder, over heated or got jammed by foriegn item (stone, pebble, etc...). If it over heated, then wait a few minutes, and then try again. Grinder also has a heat fuse that may have burnt out. If grinder doesn't work, after waiting 15 minutes, then a technician may have to replace grinder.
Nov 06, 2010 | Miele Coffee System
Miele grind cycle not working on miele coffee maching
hi,
if you move the grinder level across to the left in one action it can jam up the grinder and even damage the grinder. if adjusted is required you should move it one mark, make a coffee and then move it another mark and make a coffee.
if you can't hear the grinder operating when you make a coffee then it sounds like it could be damaged.
Dec 10, 2009 | Miele CVA615 Espresso Machine
Nov 05, 2009 | Saeco Magic De Luxe Espresso Machine
Grinder is not working
http://www.delonghi.com If your machine is still under warrenty they will tell you by numbers on the bottom. If you have receipt, even better. They will send you a new machine for shipping costs only. If machine is out of warrenty they will tell you where to get repaired. Very easy to deal with.
Jun 07, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Fill beans message keeps coming up on jura capresso impressa s9
You need to open the grinder, it`s probably packed with old fine powdered coffee that blocks the outlet. Clean this out and try again. Since it works normal when you use pre-ground coffee, there shouldn`t be any problems with any other parts.
Let me know if you want a description for have to open and clean the grinder.
Jun 01, 2009 | Jura Capresso Impressa S9 Coffee...
Jun 26, 2008 | Saeco Talea Touch 14-Cup Coffee Maker
The Coffee bean holder
You may have accidentally dropped water into the grinders. Email me your email address and I'll send you grinder cleaning instructions.
If the grinder cleaning does not work.. You may have to have to machine serviced.
Please include the model of machine and that you would like the grinder cleaning instructions.
Email: support@cerinicoffee.com
Oct 06, 2007 | Saeco Magic De Luxe Espresso Machine
Saeco Royal Professional Espresso Machine Logo
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
