Question about Seiko Watches
Should be change the battery in Seiko kinetic 7d48 and when. Approximately after how many years?Thanks
After how many years should change the battery of Seiko kinetic 7d48? Thanks
SOURCE: Seiko Kinetic that doesn't work
This watch does not have a battery, but has a capacitor which is rechargable. It is not taking a charge, and needs to be replaced. You should take it to a store with a watchmaker ON THE PREMISES. Or you could send it to: www.bscwatchrepair.com
Posted on Jul 10, 2007
  • 8 Answers
SOURCE: seiko watch band
very tightly
Posted on Jan 02, 2008
Techjoel
  • 79 Answers
SOURCE: I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Posted on Jun 05, 2009
SOURCE: seiko kinetic
Had the same problem on my Seiko kinetic a good few years back and I had to get a part replaced in it
Posted on Dec 02, 2009
  • 2501 Answers
SOURCE: SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Posted on Feb 20, 2011
Seiko 7d48 battery
i would say when the watch stops, to save battery power pull the winder out when not in use the watch will stop.
Jan 01, 2014 | Seiko Watches
My kenetic battery ( i think) operated watch ,N0, on the back plate-
First, does it say "Kinetic" on the face of the watch? If not, it is not a Seiko Kinetic. (You did not mention if it was a Kinetic or not.)
Second, the Serial number is not like any Seiko Kinetic I know, which is 2 4 digit numbers.
Third: The number you gave itself may indicate the type of button battery you need.
Good luck.
Mar 02, 2013 | Seiko Kinetic watch
Feb 20, 2011 | Seiko Kinetic watch
My Seiko Kinetic winds down in one week after weaking a years and is not recharging to run after one day of wearing.
It sounds like that it is time to replace the capacitor with a new Lithium Ion battery. Send it to Timelywatchrepair.com. Go to this web sight
Dec 29, 2009 | Seiko Kinetic watch
SEIKO 7D48.... WATCHING SHOWING CORRECT TIME(WORKING PROPERLY).. BUT SECOND HAND NOT MOVING.
Second hand could be stuck against the crystal inside or it is slipping on the shaft. Both of these conditions can be fixed but the case back would have to be removed and the movement removed to fix this problem
Nov 05, 2009 | Seiko Kinetic watch
Can I use an ordinary button cell in a seiko kinetic
I have been trained by a Master watch maker and I have worked on many Seiko Kinetic watches. Yes the original watches came with a capacitor that is charged by your arm movement. But unfortunately, they seem to only last a few years. All replacements are now done with a Lithium Ion battery that is much better and lasts longer than the original capacitor. This is the correct solution and don't try to use a battery type that is used in other quartz watches.
Oct 01, 2009 | Seiko Kinetic watch
My seiko kenetic watch stopped, and will not say wound
I thing required cleaning for the movement and new capacitor.
AmFix Jewelry & Watch Repair
203 N. LaSalle Street,
Chicago, IL 60601
Ph: 312 641 7000
Email: info@goamfix.com
Web: www.goamfix.com
Sep 24, 2009 | Seiko Kinetic watch
Seiko Kinetic Watch model 8D0557
For sure it is time to replace that old capacitor and replace it with the latest solution that uses a Lithium Ion battery. Find a good experienced repair person to do this for you. I do this daily and I am a Certified Master Horologist/watch repairman.. Ron at TimelyWatchRepair.com
Oct 20, 2008 | Seiko Kinetic watch
Seiko kinetic
I habe seiko kinetic work and stop work
Feb 07, 2008 | Watches
Jun 27, 2007 | Seiko SKA192 Wrist Watch
Watches Logo
44 people viewed this question
Top Seiko Watches Experts
Vernon Taylor
Are you a Seiko Watch Expert? Answer questions, earn points and help others
