Question about Cisco Pix-4fe-66 Pn: 74-3188-01 Pix 64-bit/66-mhz 4-port Fast Ethernet Int
Lookiing for driver
Looking for driver of cisco pix 4fe 66 pn 74-3188-01 kindly help
I have an older Cisco PIX 506 with two VPN connections. One links two offices (PIX-PIX VPN) together, another is for staff to access email & files. The file server on the local LAN the PIX is on are...
It could be a missing route... are the file server and email server on the same subnet? If they are then it is possibly not a routing issue.
Also it would be worth checking the tunneling settings for the VPNs... if you have specifed either only the fileserver subnet or specifically the file server address, then this could be the reason they can get to nothing else.
Hope that this has helped a little :)
Apr 09, 2010 | Cisco PIX 506E 3DES/AES bundle (chassis,...
Cisco pix 515 workstations cant get outside pix can
You have to create a route statement to allow workstations to get online.
Below is the command:
route interface_name ip_address netmask gateway_ip
Example:
route outside 0.0.0.0 0.0.0.0 200.200.200.1
or
route outside 0 0 200.200.200.1
When there is already a route statement but still cannot get online, check the DNS settings.
Oct 08, 2009 | Cisco PIX 515E Firewall
How ti block the orkut in cisco firewall pix515E
you can only block orkut sites that you know by IP but the Pix alone cannot do it since it requires an application like websense to do URL filtering. If you have the IPs and need help creating the ACLs, feel free to let me know
Apr 11, 2009 | Cisco PIX 515E Firewall
Installation of cisco asa 5510 firewall
Hello kuniksh,
Look at the below link for all configurations
http://www.akadia.com/services/cisco_router_firewall.html
Do rate this solution!!!!
Mar 21, 2009 | Cisco ASA 5510 Firewall
I need a L2TP configuration for my PIX 515 and ASA 5505
You can do this, For your ref i hv given you a link
http://channel9.msdn.com/forums/9GuyAroundTheWorld/251722-Cisco-Pix-to-Windows-Vista-Native-Client-Using-L2TP-IPSec/
Mar 01, 2009 | Cisco ASA 5500 Firewall
How do I set up a VPN connection with PIX 501?
No worries. Just give it a try then let us know should you get any problems or follow-up questions.
Oct 15, 2008 | Cisco PIX 501 Firewall
ASA 5510 sec - bun k9
Basic Commands pixfirewall(config)#hostname PIX !--- Naming the PIX is optional. PIX(config)#nameif ethernet2 fo security20 !--- Naming the interface is optional. It is recommended that you !--- hardcode the speed/duplex. PIX(config)#interface ethernet2 100full !--- Bring up the interface. PIX(config)#ip address fo 192.168.1.1 255.255.255.0 !--- Assign an IP address. Failover Commands PIX(config)#failover ip address fo 192.168.1.2 !--- IP address for the failover link. PIX(config)#failover lan unit primary !--- This unit is primary . PIX(config)#failover lan interface fo !--- The 'fo' interface is used for LAN failover. PIX(config)#failover lan key cisco !--- The Pre-shared key. PIX(config)#failover lan enable !--- Enables failover. PIX(config)#failover !--- Start the failover process. This message appears on the console:
LAN-based Failover: trying to contact peer failover_01.gifLAN-based Failover: Send hello msg and start failover monitoring
Nov 27, 2007 | Cisco ASA 5510 Firewall
Upgrade firmware on a cisco ASA 5500 firewall
This is for the pixes, I haven't upgraded an asa yet...should be close or the same
* find latest version of code, these are usually *.bin files located on http://www.cisco.com/cgi-bin/tablebuild.pl/pix
* confirm the flash and RAM requirements of the PIX OS software versus what the PIX has (”sho ver”)
* make sure you have a backup of the old PIX OS and PDM to the tftp server (or at least confirm the software is there)
Note: You cannot back them up from the PIX, so you will need to download them and put them on the tftp server * put in a change control form
* once change controls confirms date/time do the upgrade:
wri mem*** only if you save your configs via tftp wri net conf t ca save all copy tftp://your tftp server ip/pix635.bin flash:imageskip this if you don't use pdm copy tftp://your tftp server ip/pdm-304.bin flash:pdm *** if this is a failover pair, upgrade the other pair reboot
Sep 06, 2007 | Cisco ASA 5500 Firewall
Cisco Pix-4fe-66 Pn: 74-3188-01 Pix 64-bit/66-mhz 4-port Fast Ethernet Int Logo
46 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
