Question about RCA D52W19 52" Rear Projection Television
When power it'll blink three times and shuts off
You go to the tv press the power on blinks three times makes a cherping or hissing sound and it shuts off. i can't get any more detailed then that.what detail do you need and i'll try to provide you with it. thank you.
  • 451 Answers
It is probably the power board. When the capacitors on the board fail they can make a hissing noise. If you look at the board and the small cylindrical things on the board ( which are the capacitors) are bulged on top instead of flat this indicates a failed capacitor. The board should then be replaced. Hope this helps.
Posted on Jan 01, 2014
4 Suggested Answers
ladywinn
  • 5138 Answers
SOURCE: RCA D52W27D The Three Blinks of Death
Check 3 capacitors on deflection board cp150,cp111,cp114 most of the time this is the problem 2200uf16v /330 uf 35v /220uf 35v.
Posted on Oct 17, 2008
  • 18 Answers
SOURCE: rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
Posted on Feb 25, 2009
Slinteriors
  • 8617 Answers
SOURCE: Describe your D52W20 52 in.
That could be caused by the CP150, CP120 and CP114 capacitors on the deflection board. Very famous issue. You can get the RCA repair kit by that same name from www.tvrepairworld.com which has the capacitors and the CD with repair instructions
Posted on Aug 28, 2011
Rca truflat tv
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Aug 24, 2014 | RCA TruFlat 27F520T 27" TV
What would cause the power light to blink red and the tv will not turn on
three times red light blink mean DC Alert which is related to system in internally & some time sound ic problum
Jul 12, 2014 | Sony KDL Televison & Video
Panasonic tv power button blinks 5 times
Probably the power supply is failing.
Jun 30, 2017 | Panasonic Televison & Video
My toshiba 42HL167 won't turn on
Try this fix from the toshiba website. Q. I have no picture or sound, but I have a blinking power light?
Models: LCD-2007
REF:FAQLCD00090
1. Try resetting the TV by disconnecting the power for 30 seconds and then plugging it back in. If this has no
effect, try moving the TV to a different power outlet that has been tested and is known to be good.
2. If your unit continues to fail, please contact our Customer Solutions Department at 1-800-631-3811 Monday
through Friday, from 8 a.m. until 7 pm CST for a local Toshiba Authorize Service Station Hope this helps you with your problem.
Feb 27, 2009 | Toshiba 42HL167 42 in. LCD Television
I have a RCA D56D20 tv will not power up it blinks three times
You have 2 more caps in same circuit you need to replace cp114---cp120 both are 220uf 35v. Also chirping nosie means Shorted hori output NTE 2324 .On second ribbon on deflection board make sure it is connect good or it will make a squealing noise and TV will not come on. Happy New Year.
Dec 29, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Tv acts like its going to turn on, but then shuts back off
sounds like high volt arcing. i would get it checked out pronto could do much more damage if it is hv arcing.
Dec 13, 2008 | Sony FD Trinitron WEGA KD-36FS130 36" TV
Fujitsu Plasmavision PDS-4233
HI, I haHe a Fujitsu Plasma HDTV Model PDS4233. The TV won't power ON, When i turn on the master power button the light starts flashing a red light repeatedly. I also observed that the Fans power up for about three seconds immediatly after i press the master power button, after the three seconds the fans shut OFF and the light continues to blink.. I haven't observed the light to see if there is a pattern with the blinking..
Aug 30, 2008 | Fujitsu Televison & Video
RCA D52W19 52" Rear Projection Television Logo
391 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
