My ISP has provided me with an username and password. I need my 2100ap to provide connections for 3 of my PC,s. How this can be done. Where can I put the username and password in router so that all 3 PC,s can be connected at same time. Please help? My router is dlink 2100 ap. LAN connection comes to me which I have inserted in the router so all 3 pcs can be used simultaneously. My ISP allows multiple users
SOURCE: setup!!
Add your isp's DNS in your Dlink Router
Posted on Mar 15, 2008
Mark_Webber
  • 472 Answers
SOURCE: Lost contact between PCs connected via AP
Set all the PC's to have a manual IP rather then using the DHCP from the router.
Also set the Gateway and Preferred DNS on the network cards to the routers IP (IE 192.168.0.1)
Posted on Apr 18, 2008
  • 4 Answers
SOURCE: Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Posted on Dec 01, 2008
patemi
  • 366 Answers
SOURCE: Connecting a wireless router to Tiscalli broadband connection
  1. USB modem is connecting a PC USB port with a DSL phone line: CANNOT be connected to a ROUTER LAN (ethernet NOT USB port).
  2. Wireless ROUTER is NOT a modem and it CANNOT connect the Internet (or WAN) LAN port to any "phone line"
  3. Connect the Router Internet (WAN) port to Modem (you need a LAN MODEM = a modem with a LAN/ETHERNET port)
  4. Be sure your internet is running before strting ROUTER configuration with Router Company CD
Posted on Jan 06, 2009
SOURCE: dlink dap 1522
I think I was having a similar problem with my DAP-1522 ... FW Version 1.10 being used as an access point. I recently discovered that I was not able to connect to the configuration pages using a web browser by typing in it's IP address (192.168.0.50). When I originally set this up device up on my network, it worked just fine, but at some point in time, it stopped working. My solution to this problem was to set the switch on the back of the 1522 from Auto to AP, then re-boot the DAP-1522 by removing power, waiting 10 seconds, then plugging power back in. Once the AP re-booted, I was then able to access the configuration login page by typing 192.168.0.50 into my browser. My DAP-1522 access point is connected via port 1 to my D-link router, a DGL-4100, via a DGS-2208, 8 port gigabit switch. Hope this helps!
Posted on Aug 31, 2009
Can't get my router to connect to ISP with username and password
It is not done at the router but at each device. The router supplies connections via a local sub-masked address. It is typically assigned an IP address via the ISP's DHCP server. Typically usernames are used for e-mail and Usenet. Your connection is validated by the MAC address on the router. Your ISP can not look beyond your router. You can have 1 device or dozens. It matters not.
Jan 01, 2014 | D-Link Dlink Airplus Xtreme Dwl-2100ap...
I cannot reset my password
Im presuming its your internet connection password ?
Your Internet service provider (ISP) requires a username and password to access service features, including Internet and email.
Your ISP should provide this information when you set up your Internet service.
Typically, once you complete the setup and save the information, your router or modem transmits it behind the scenes when you try to access the Internet.
As a result, the username and password can be easily forgotten because they are not used daily.
If you reset your router or simply forget the password, gaining access to network resources and the Internet becomes a challenge.
Call your ISP's technical support department.
Many ISPs set a default username and password for their routers.
If you didn't change the username and password, your ISP can provide the original information.
Before you hang up, make sure the information is correct by entering it and trying to connect to the Internet.
If the information is incorrect and you still cannot get a connection, keep the information for later reference.
Call your router's manufacturer.
The manufacturer of your router sets a username and password prior to shipping the device to your ISP.
Look at the router for the contact information of the manufacturer.
Call their customer service or technical support department and ask for the default information.
Reset your router.
If you changed your router's username and password and cannot remember what you entered, you may have to reset the router.
Insert the resource CD into your computer's CD drive.
When the software installation program starts, search the screen for "Resources" or "Documentation" or "User Manual."
Click the documentation link and search the table of contents for resetting the router.
When you reset the router, the username and password return to the default set by your ISP or manufacturer.
Enter the information provided by your ISP or manufacturer.
Hope this helps.
Nov 15, 2012 | Computers & Internet
My router light is orange an will not allow me to connect to the Internet. Normally it is green.
i think you need to configure it by putting proper username and password given by our isp internet provider. please check the manual to know how to login to your router and how to configure it if you have username and password provide by your ISP
Oct 15, 2012 | Computers & Internet
My ps3 wont pick up my wireless noden signal woint let me sign in gives me error code 80028e02
Hi and Welcome to Fixya
Error means there was an issue connecting to your Internet service provider. This happens when your ISP requires you to put in your username and password from the internet browser. Try to browse using your PS3 ans see if you have a message from your ISP or a login page will show up. Follow the instructions and enter the username and password of your ISP. This is not you PSN account login credentials. Contact you ISP you are not aware of you username and password
Thank you for using Fixya!
Feb 21, 2011 | Sony Playstation 3 (PS3) Console
My cable internet provider has provided me with an Ethernet cable which connects directly to my PC. My PC's MAC address is registered with the ISP. I use a PPPoE connection to access the internet with a...
put another lan card in pc
share your connection using ICS from network properties from first one
put a straight cable from pc to router
give the gateway of router to laptop
remember!! the class of ip's should be the same
you are done
Feb 04, 2011 | D-Link DIR-600 Router
How do I find out my password if it isn't the one sent through on the email?
Hi there what password do you want to get? The router password or your Account password for your ISP?
If it's a router password the default username and password are the list below.
1. username: admin password: password
2. username: admin password: admin
3. username: admin password: <blank> -> (just hit enter on your keyboard)
2. If it's a account password you need to call your ISP (Internet Service Provider)
Jan 08, 2011 | NetGear Computers & Internet
My Netgear adsl router is not getting connected to Internet in pppOe mode ..
POPE configuration is logs into your ADSL system and connects to your ISP provider server to link , so one of the reason why it dosent is due to either password and username not correct. Log unto IP address of your Router and go to WAN configuration , Check your username and password and reset to the initial password and username your ISP provider gave you , when you signed up with them. Then apply changes , off your router for 1 min and then power it , then wait for the ADSL light on the router to be stable , connect to the IP address of your router again and "Volla" , it should be fine , if not , contact your ISP provider....
Oct 07, 2010 | NetGear DG834G 802.11G Wireless ADSL...
How to hook up the Linksys Wireless-N WRT150N Router to DSL?
Connect the dsl modem to port on the router that says Internet
connect 1 pc to any available port on the router(1,2,3,4).
Open your browser and type 192.168.1.1 in the address bar
It will prompt for a username/password window. leave username blank,password admin. Press enter
Normally if you have dsl, you need to set the internet connection type to pppoe and put in your username and password that your ISP provided you. then save the settings.
Oct 04, 2010 | Linksys Wireless-N WRT150N Router
How to do a PPPoE connection?
You have not mentioned OS you are using, i am assuming that you have windows xp or later. Go to properties of my network places and click on create a new connection > Connect to Internet > connect to broadband that requires user name and password .. follow next steps as appears it will install PPPoe protocol and will make a connection also
Jun 26, 2010 | D-Link DFE-530TX+ Fast Ethernet PCI...
I dont know haow to connect Linksys Wireless-G Broadband Router with SpeedBooster WRT54GS - wireless router
  1. Connect your modem to the Internet port of the router. Your computer needs to be connected to one of the 4 Ethernet ports at the back of the router.
  2. Access the router's setup page by launching Internet explorer and typing 192.168.1.1.
  3. It will ask for a username and password. Leave the username blank and password is admin.
  4. Once your in the setup page, set "Internet connection type" with what your ISP requires you to have.
  5. If you have cable ISP, usually it is "Automatic Configuration-DHCP."
  6. But if you have DSL ISP, then it will be PPPoE. You need to know your username and password from your ISP.
  7. Better yet, verify your Internet connection type from your Internet service provider.
Hope this helps!
Nov 09, 2008 | Computers & Internet
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
