Godrej semi automatic washing machine circuit diagram
Godrej washing machine curcit diegram
  • 11 Answers
SOURCE: circuit board on candy washing machine
you must specif the model of the machine and getme more information
Posted on May 12, 2009
SOURCE: washing machine circuit diagram requested
you all need help
Posted on May 18, 2009
  • 343 Answers
SOURCE: my lg washing machine is a semi automatic model
Sounds like a pump or drain hose blockage.. Check filter. Could also be the pump motor. The more resent synchronous pump motors get detritus inside them and gradually 'gunk up'. You may be able to drain the machine by lowering the drain hose and allowing gravity to help. this won't work if the drain hose is mounted high at rear of machine......Nomess
Posted on Apr 18, 2010
caroldon
  • 17129 Answers
SOURCE: water gets drain cannot remain
The drain is pull the knob which will pull up the drain valve. So if this is not working then the connecting bowden is broken and is not connecting the link to the bottom drain valve.
Look at the bottom and connect. Clean the drain valve, if choked.
Posted on Sep 14, 2010
SOURCE: i want circuit daigrame for aeg washing machine
I have an AEG öko Lavamat 64600 washing maschine and I need a circuit diagram. Can you help me?
Thanks,
Bridget
Posted on Nov 22, 2010
When stachi do, not move clothes.
Godrej front load washing machine model no GWI5511 RES. Error e 5
Apr 20, 2017 | Washing Machines
Godrej eon washing machine e2 problem.
eco wash fault this can be down to hard water areas, the switch for the water intake is stuck can be opening but not all the way so it shuts it back off and you get this code.
May 09, 2014 | Washing Machines
I have godrej gda 902 water is not getting drain after its first cycle of process can any one tell me what might be the problem
The drainage pipe is blocked up. this is a common problem amongst washing machines. People forget to check the pockets before a wash and dirt and fibers start to get stuck inside of the pipes and soon it is blocked and will not drain or drains very slowly.
Solution is to take the machine outside and unhook the drainage pipe. most of the time the blockage is there and is easily removed.
If not, hook the machine up outside and when the drainage cycle is suppose to start try to see if the blockage can be removed by spraying high pressure water up where the pipe has been disconnected. The resulting push of water from both sides may be enough to breakup the materials blocking the pipe.
Apr 24, 2014 | Washing Machines
Ac voltage become hihg or low when start ifb washing machine
We got a IFB front loading washing machine last week only after 3 time wash 4 th day it is showing AC-LOW message . the service people came and went but nothing is done what is the next solution?
Same point top loading Godrej 6.5 kgs working fine but water consumption is more in that compared to front loading machine so pls sugeest good solution at the earliest.
Sep 30, 2012 | IFB Washing Machines
I have a godrej top loading washing machine for 4 years. Recently the bucket started sinking. Today i bought new suspensions. The suspension has a air piston, do i have to apply GREECE on the piston....
If it did not come with oil none is necessary. They are pre-loaded with pressurized air.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 07, 2009 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
