Question about LG Refrigerators
Water is dirty - LG Refrigerators
Scooba 390 empty dirty tank
it is trash do to the fact that it is not receiving suction to pull the dirty water to the dirty resavore
Mar 24, 2014 | Eureka Atlantis 2590A Wet/Dry Vacuum
Why is my ice dirty
There are two ways to get dirty ice - dirty water or a dirty machine.
If the water that the machine is processing is dirty, you'll get dirty ice. Check that your water filter is working properly, and that the filter core is in good condition. If the water supply to your machine is really dirty, consider a double filter.
Also, check inside your machine for deposits of silt, minerals or other undesirable materials. Clean out the inside of the machine thoroughly, but don't use any household cleaning products or acids - they will damage your machine or leave an undesirable perfume which will contaminate the ice - Just use water. Also don't use anything abrasive on the internal surfaces. If there are mineral deposits, you can dissolve them with household vinegar by soaking them or spraying them continuously, and then rubbing with a non-abrasive sponge. There are also commercial solvents especially for icemakers. Rinse the machine thoroughly to remove any odours, and throw away the first harvest of ice.
Nov 05, 2013 | Kitchen Appliances - Others
What setting do I need to have the machine on to **** up the excess water? I want to download the manual but can't seem to find a link to do so, how would I do that?
You should have the vacuum set to Wash/Rinse for all steps in cleaning. Press the trigger to release the cleaning solution and push the vacuum forward. With the trigger still pressed, bring the vacuum back towards you). Then release the trigger and again move the vacuum forward and then back. Repeat the "dry" strokes until the dirty water enters the dirty water tank. Watch the water going through the dirty water tank lid. Empty the dirty water tank if the suction fails or the tone changes. Do more dry strokes after cleaning the entire surface until you do not see more water entering the dirty water tank.
The manual is available from Hoover at the product site: http://hoover.com/products/details/f7411900/max-extract-dual-v-widepath-carpet-cleaner/ . The direct link is here: http://hoover.com/file/592/ .
I hope this helps.
Aug 08, 2011 | Hoover SteamVac F7411-900 Upright Vacuum
Dirty water in my iron
The dirty water coming out of your iron steam holes is caused by the accumulation of 'dirty' tap water: if you look inside an eletric kettle, you will see the same 'dirty' muddy brown mineral residue on the inside. In addition, if your iron is old, it can also be rust. It is a pretty common problem that can be minimized by using distilled water. You can get commercial steam iron cleaning fluid to clean the inside of your steam iron or you an simply use vinegar: 1) with a cold iron, fill the reservoir with straight vinegar 2) Place your iron on top of a metal kitchen rack above your kitchen sink, turn iron on and let it steam out all the vinegar: it should spit out the whitish mineral and muddy brown deposity. 3) Refill iron reservoir with clean water and repeat as of step 2. 4) Refill iron reservoir with clean water, wipe any dirty from the sole plate and this time on full steam, iron on clean layers of Kitchen paper to ensure that all dirt has been removed from the inside of the iron reservoir, if not, repeat from step 1 again.
In the future, try to use distilled or at least filtered water.
Hope it helps: let me know how you go!
Feb 24, 2010 | Bosch TDA8340 Iron
I have never used a shampooer before when I use it it says to empty out dirty water. I don't have any left. My tank is empty. Am I doing something wrong.
Suggest that you do the following.
Remove the TOP ("Clean water") tank. Fill it 1/2 full of water. Put the top on the clean water tank and place it back on the machine.
Release the machine handle and remove the cover of the "dirty" water tank. Inspect the back of the tank to be sure that the vacuum adapter in located in the rear of the dirty water tank. If not-that is your problem. If yes, restore the top to the dirty water tank.
Power the machine on.
On a kitchen floor, power the machine on. Pull the trigger and hold it for about 30 seconds. You should see water gathering around the brushes. If not, that is a problem.
With water around the brushes, release and lower the handle and and move the machine over the water. It should vacuum the water into the dirty water tank.
Is all of that happening?
Nov 25, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
Mar 22, 2009 | Hoover H3030 FloorMate SpinScrub 500...
DIRTY WATER
remove the dirty water tank and see if the front nozzle is fitted correctly, also see if the filter is clean on the dirty water tank
Nov 19, 2007 | Bissell 1770 Quicksteamer II Upright...
Dirty ice
Did you change the water filter recently? If so, you may have some air in the lines which can be purged with a few minutes of dispensing water through the front.
Nov 02, 2007 | Amana ARS9265B Side by Side Refrigerator
Refrigerators Logo
53 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
