Question about Konica Minolta Office Equipment & Supplies
Report code sc23-01
This report code comes up whenever I power up my Konica 7165
  • 3 Answers
This is an empty toner condition. Check your toner bottle has toner in it. It occurs when the bottle motor has turned for 7 seconds but no toner has been detected. If your bottle is ok, it could be a motor/drive/blown icp, issue.
Posted on May 25, 2009
Fix the Error Code Sc 34-02
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Dec 16, 2015 | Konica Minolta 7155/7165/7255/7272/FORCE...
CODE 02-01 SC23-04
Sir/Mam, please check the model and the code looking at service manual for the Konica Series 7255 not such code per what model you currently have this problem with
Feb 08, 2013 | Konica Minolta TN601K Toner for 7155,...
CODE 02-01 SC23-04
PCL connection area. Mite want to check all connections to the print control board. And Memory sticks, also have the firmware re-flashed.
How can I correct SC29-04 on Konica 7255?
The sensor is located on the left side of the drum cartridge it is a sensor that is covered with a white cover to the rear of the drum you must remove the drum to see it clean with cloth not a vacuum cleaner Static from vacuum can destroy it. The clear glass sensor is for paper jams! Located in the middle of the cartridge. Mite also want to know when the last 250K copies PM was done?
Nov 28, 2012 | Konica Minolta TN601K Toner for 7155,...
SCANNING PROBLEM KNOICA 7165
contact whit the engineer probably u have to instal new firmware
Jun 23, 2009 | Konica Minolta Office Equipment & Supplies
What is the code to manually clean the corona wire Konica 7165
47 mode output 046 p00p for charge 47 mode output 047 p00p for transfer
Apr 03, 2009 | Konica Minolta Office Equipment & Supplies
KONICA 7165
There may be problem with the harddrive as it will store some information on it then it will forward the information on to the email server.
Mar 03, 2009 | OCE 3140 Copier
Konica 7255 diaplays a F56-04 code when IP is installed
That is correct. The IP511A is for the 7255 / 7272, and the IP511 is for the 7155 / 7165.
This is probably due to these machines using different image processing boards.
I am actually surprised it lets you get as far as you did with it.
Feb 08, 2008 | Office Equipment & Supplies
164 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
