Question about KitchenAid Superba 21.6 cu. ft. Top Freezer Refrigerator w/Factory Installed Icemaker
No water dispensing to the icemaker. Water does dispense through the door dispenser. KitchenAid ksbs25fkbl00
Ater does dispense through the door dispenser.
  • 1 more comment
  • Anonymous Jun 15, 2008
    ice maker was working before we moved the refrigerator to a new location. On plugging it in, now the water dispenser works, but the icemaker doesnt get any water - and hence: no ice
  • Anonymous Mar 14, 2014
    it pours water but wont drop ice.
  • Anonymous Mar 29, 2014
    inside front side wall of fridge is very HOT to the touch. water dispenser in door, hot water comes out first, then cooler water follows and icemaker is not working.
  • 1,010 Answers
After you left open the door for two hours and still not working check the solenoid valve (at the back, where the water line is).
You can power the solenoid directly, if you are familiar with electricity, if not, then please DO NOT TOUCH IT.
Posted on Mar 06, 2013
Unplug your refrigerator and leave the freezer door open for 2 hours (The food in the freezer will only partially thaw).
The line supplying the water to the ice maker has frozen...this will un-thaw it.
Posted on Jul 01, 2008
The water isnt getting thru to the icemaker, i have used a hairdryer on the water valve and still nothing , i even changed out the water valve but alas no water is being pumped thru to the icemaker, what...
Does water dispense through the dispenser ok in the door dispenser??
If yes wate r dispenses through the door ok the problem is going to be with the icemaker itself and its not sending power to the water valve when its supposed to fill so it could make the ice
If water doesnt dispense through the door check that water pressure into valve is sufficent..even if water does dispense what seems to be ok check first that thier is good water pressure into the valve before replacing icemaker
GENE
Sep 11, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Icemaker works but water doesn't dispense. I have
I think our water will dispense but our tab(arm) came off track and we don't know how to put it back on. Our icemaker works fine but can't see how the arm should be on. Let me know if you have any advice. Thanks, Shelby ~ Ohio
Feb 14, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kitchen Aid Fridge KSRIZ6DSALYO Water no longer dispensing from door. Can a filter get too old and get clogged or should Iook at something else?
the filter can become clogged and restrict the water flow to the water dispenser and icemaker (i.e. water dispenses slow or small/hollow ice cubes). if the filter doesn't fix it then you either have a water supply problem or a faulty water valve. take the filter out and see if the water pressure increases out of the dispenser. if it does, you know its the filter. hope this helps.
Oct 22, 2009 | KitchenAid Refrigerators
Icemaker not working, but water dispenser is
Water valve has separate coils for water to door and to icemaker. If icemaker is cycling the valve is likely the problem.
May 19, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Water will dispense from the door but will not fill the icemaker
Me too, same issue. Just changed water filter prior to problem
Mar 17, 2009 | KitchenAid KSBP25FKSS Side by Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
In door water/ice dispenser not working
check the connect part, see if the gears in the right position.
Jun 17, 2008 | KitchenAid KSRS25IL Side by Side...
Water dispenser starts running when freezer door closed
if you wich to disable the despenser for water in the door just unplug the electrial connector on the water valve it has 2 selenoids on it one is for water in the door it has the largest plastic line under the selenoid
just unplug the connector to that selenoid
you will still have ice and it will despense through the door
Apr 20, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Ice won't dispense, no power to water light
I would check hte wire harness leadngto the door under hte freezer hinge. itll be wrapped in a black web like covering. Just under hte unit itself follow ht ewire and unplug hte harness. then carfully cut hte black webbing and inspect wires. there tends ot be apinch point there and the wires will sheer from one another, . if so there is no replcing hte harness, the door would have to be replaced at a cost of nealry $600. not enough room for a wire nut, but hav had sucess using stright inline bullet style connector, or others have sucessfully soldered connections back in place
Mar 21, 2008 | KitchenAid (KSRD22FKST) Side by Side...
No Water in Ice Maker
before u call a repair man i would unplug the fridge for 12 hours about depending on weather to let ur line unfreeze if thats the problem the dispenser in the door and the one to the icemaker are two different lines so just because the door works with water dispensing doesnt mean the freezer line isnt froze over
Mar 20, 2007 | KitchenAid KSRS25IL Side by Side...
Refrigerators Logo
718 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
