Question about Maytag PAV2300 Top Load Washer
LAT9604AAE No agitation but drum spins and drains water
Maytag washer model LAT9604AAE will not agitate clothes but the drum spins and drains water and goes through all of the cycles.
    Champion:
  • 219 Answers
Cold possibly be just the agaitor but odds are u need a transmisson not worth repair
Posted on May 21, 2009
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
Apr 07, 2017 | Maytag Neptune MAH5500B Front Load Washer
My washer''s agitator spins but not the drum during spin cycle.
If you see the agitator moving, but not the tub..I guess, you have a defective transmission..this is tough without knowing a little more info.
May 20, 2010 | Maytag Legacy Series Top Load Washer
Maytag PAV2000AWW will not drain or spin in 2 of the 3 wash cycle
It won't drain
If your washer won't drain, check these:
It spins, but doesn't pump
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump.
It doesn't spin or pump
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns
If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Nov 27, 2009 | Maytag Washing Machines
Old maytag A208 will not spin
I would say, there is something holding the inner drum from rotating. Possibly an item of clothing that has slipped between the drums.. When washing only the agitator(pulsator) moves, when spinning, the complete drum rotates as well. Remove obstruction.
Sep 21, 2009 | Maytag PAV2300 Top Load Washer
Full of water, won't drain past the agitation stage, just goes dead
It won't drain If your washer won't drain, check these:
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems:
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
May 04, 2009 | Washing Machines
MAYTAG MAH6500AWW-WASHER WILL NOT AGITATE/SPIN
This is a frontload Neptune. I think you will find that the motor control located in the bottom right front of the cabinet is bad.
Feb 07, 2009 | Compaq Presario 5000 PC Desktop
Machine fills and agitates, but won't drain
Please empty your machine and run the machine empty. If the washer goes through the whole cycle without any clothes. Please let me know
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Machine dosent seem to drain model #lat8840b maytag
my machine had a pair of kids underware stopping the water from entering the draij pump,you may have clothes inbetween the drum and outer wall stopping the normal rotation
Aug 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Rinse cycle spinning... clothes still soaked
It sounds like your washer is not going through it's neutral drain. After agitation, your washer should pause and drain for around 90 seconds to pump out the water before spin. Check this out by starting a wash with a small screw driver holding the lid switch down. This will allow you to observe whether or not it's going through it's neutral drain. If not, it's a transmission problem. The trans is covered under warranty for 5 years. You may also want to check the pump to see if it's gunked up. Catriver..post back.
Dec 04, 2006 | Kenmore 24982 Top Load Washer
Maytag PAV2300 Top Load Washer Logo
447 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
