Question about 1998-2002 Park Avenue Door Lock & Alarm Interface
Horn switch is not getting power, 1994 Buick Park Ave Ultra
Can't find horn wiring diagram for 1994 Buick Park Ave Ultra, horn switch is not getting power at all.
    President:
  • 676 Answers
Have you checked the fuses? ON a buick, under the steering column there will be a set of wires. When depressing on the horm there will be 12 volt ground to the black wire. The black wire is the wire that goes to the horn relay. If you can trace ground through the wire to the relay, then the problem could be your relay. You can also put +12 volt to the horn to be sure the horn is good. If the horn sounds when putting a +12 volts the the problem again could be the relay.
Posted on May 20, 2009
1994 buick park ave ultra wont charge battery
sounds like a bad connection or corroded wire
Jan 23, 2013 | 1994 Buick Park Avenue
Can't get headlights to work on 1991 Buick Park AVE Ultra. All parking lights work fine.
So you have tested nothing.
Headlights don't usually have relays,just a circuit breaker in the light switch.
As I suggested,no one knows your problem,you need to actually start to do something. Get to the light switch and do some testing with a meter. It is either working or it isn't. If it is good then you could use a wiring diagram to continue on,or have a shop do this for you.
Oct 05, 2010 | 1991 Buick Park Avenue
I can't find a diagram of the belt installation for my 97 Buick Park Avenue. Can you help?
I can help, a belt diagram for a 1997 park ave, some of these cars come with a super charger, heres a diagram that list both the regular belt and then the charger belt, use what is needed, hope this helps.cfccfd3.gif
Sep 09, 2010 | Buick Park Avenue Cars & Trucks
I have a 1995 Buick Park Ave Ultra. The car has power but will not turn over. I was told by one shop that it might be the V.A.T.S. system and by another that it is the IGNITION CONTROL MODULE.
Make sure the battery cables are clean and tight on the battery. Check to see if the wires to the starter are tight. Try starting it in neutral to make sure the safety switch is being make. Also hold it up into park and try.
Mar 22, 2010 | 1995 Buick Park Avenue
Security light stays on and occasionly something runs down battery overnight .since i lost my keys with remote opener these problems have come up. this car is a 1994 buick park ave ultra.
One of the door pin switches is faulty, Interior light must be staying on and draining the battery. If you don't see the dome light staying on possibly the trunk switch is bad.
Oct 12, 2009 | 1992 Buick Park Avenue
Need the location of the horn fuse for 1995 buick park ave ultra
For the right side the fuses are
1 Door Locks, Trunk Pull-Down, Fuel Door Release
2 Power Antenna, Lock Switch, Trunk Release
3 Horns
4 not used
5 Cruise Control, Misc. Engine Controls
6 Fuel Pump
7 Injectors
8 Powertrain Control Module, Pass-Key II
9 Not used
10 Not used
11 A/C programmer
12 Not used
The order for the fuses go up in down in columns. First row 1-4 etc.
Jun 24, 2009 | 1995 Buick Park Avenue
1998-2002  Park Avenue Door Lock & Alarm Interface Logo
837 people viewed this question
Top Buick Vehicle Parts & Accessories Experts
Marc Taylor
Thomas Perkins
Thomas Perkins
Jeff Turcotte
Jeff Turcotte
Are you a Buick Vehicle Part and Accessory Expert? Answer questions, earn points and help others
