Question about Transcend Electronics - Others
I have a Transcend JF V10 Flash Drive. This is not detected by my laptop running Win 7. The same flash drive is detected in my samsung smart tv. I have another transcend 4 gb flash drive, which is detected by the laptop. What is missing in the laptop that is causing it to only ignore the 8 gb pendrive.
    Champion:
  • 221 Answers
Click Start, then type device manager in the Search box, then click Device Manager.
Expand Universal Serial Bus controllers. Right click a device and click Uninstall. Repeat for each device.
Once complete, restart your computer. Your USB controllers will automatically install.If your problem still exists do the following:
Click the Start button, type power plan in the Search box, then click Choose a power plan.
Next to your currently selected plan, click Change Plan Settings.
Click Change advanced power settings.
Click the box to expand USB Settings, then expand USB selective suspend settings.
Click Plugged in, then click the drop down menu and select disabled.
If you're using a laptop, click Battery, then click the drop down menu and select disabled.
Click Apply, then click OK.
Posted on Jan 01, 2014
  • 94 Answers
SOURCE: Transcend JF V10 16 GB
checkup on ur usb configuration
and os related issues
Posted on Apr 03, 2008
SOURCE: transcend 4gb pen drive not getting detected
Hi i have a transcend 4gb pendrive that does not get detected on my comp having win XP. i also tried plugging it to a different computer. when i check in device manager it says unknown deviceHi i have a transcend 4gb pendrive that does not get detected on my comp having win XP. i also tried plugging it to a different computer. when i check in device manager it says unknown deviceHi i have a transcend 4gb pendrive that does not get detected on my comp having win XP. i also tried plugging it to a different computer. when i check in device manager it says unknown deviceHi i have a transcend 4gb pendrive that does not get detected on my comp having win XP. i also tried plugging it to a different computer. when i check in device manager it says unknown deviceHi i have a transcend 4gb pendrive that does not get detected on my comp having win XP. i also tried plugging it to a different computer. when i check in device manager it says unknown deviceHi i have a transcend 4gb pendrive that does not get detected on my comp having win XP. i also tried plugging it to a different computer. when i check in device manager it says unknown deviceHi i have a transcend 4gb pendrive that does not get detected on my comp having win XP. i also tried plugging it to a different computer. when i check in device manager it says unknown device
Posted on Nov 06, 2008
  • 11 Answers
SOURCE: Transcend jet flash showing write protected message
hey, i was having the same problem with the same flash drive... there are two ways how you can fix it..
1. try formatting using cmd
Go to start-->run and then type cmd and press enter
now the command window will open
in that type format X: (x being your drive)
This should work fine if not try the second method
2. Go to this website and download the recovery tool software which is exclusively for transcend flash drives.. click the link below to so to that site..
http://www.transcendusa.com/Support/DLCenter/index.asp?axn=SRH2&ModNo=107&ItemID=TS16GJFV30&Controller=#5
Download the recovery tool software under the topic software and install it in your system.
Now connect the flash drive in your pc and run the recovery tool application.. This will format your flash drive
Posted on Feb 02, 2009
SOURCE: transcend 4gb pendrive not being detected in Win XP
ok plz purchase New USB card and add in ur motherboard and solv ur problem....... ......
ok
Posted on Mar 19, 2009
  • 79 Answers
SOURCE: transcend JF V30/4GB pendrive not detected??
1. try transcend drivers http://driverscollection.com/?file_cid=39278936334676929bc3679940f
2. Please find the utility which will help you to recover the trancsend Flash USB drives, if gone bad.
Find the utility @ http://www.esnips.com/web/USBfiles/
All you need is the Valid Serial No of the USB flash drive.
Refer the Link to find where the Serial No could be for your drive.
http://www.transcendusa.com/Support/GetSerialNo.asp?FldNo=3&LangNo=0&PType
3.contact them for support :support email id: techsupport@transcendusa.com
Posted on Aug 07, 2009
Transcend jf v30/64gbmy pen drive is not detected in my computer
Flash drive not detected, it means there is damage to hardware.
Damage to hardware, there are two types
1. Cracked solder.
Solution: Open flash drive casings, heat the tin solder.
2. Resistor (R) broken
Solution: Open flash drive casings, replace the resistor.
Hopefully this information helps
Nov 04, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
When i format transcend 8gb jf v10 it says disk is write protected. I'm not able to add data or format it please help..
I have purchased 8gb Transcend Pen Drive When i Connected the drive in computer a message shows "Please insrt a disk into drive". I have checked in several computers but the problem is same. Although the disk is detected but not shows the capacity when trying to open this message displayed. I have change the drive letter from my computer "Manage" option but the problem is same. What can i do?
May 14, 2010 | Computers & Internet
MY PENDRIVE JF V10 (4GB) FROM TRANSCEND WEN INSERTED SHOWS AS REMOVABLE DISK BUT WHENEVER WE DOBLE CLICKING , IT SHOWS AS YOUR DRIVE IS NOT PROPERLY FORMATTED . WHAT I CAN DO ? IS THERE ANY ONLINE RECOVERY...
Hi Friend,
Please follow the below steps
Step 1: Try to right click and Scan for Virus
Step 2: If it detects any virus please remove it and then try to open
Step 3: Even after that it doesn't open then we have to format the Pen drive
If you have any clarification please feel free to reply
Regards,
Ayyasamy
Mar 18, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
My transcend pen drive is not shown on pc. what is this problem?
i have transcend JF V10 pen drive. it is not showing on computer but it is visible on safely remove icon. is my pen drive corrupted or it is a software problem? what is the solution?
Dec 02, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
"insert a disk into drive"
right click my computer
manage
in right panel double click storage
double click disk management(Local)
right click on the pen drive shown and click format
Oct 03, 2009 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Windows 98 SE Driver for Transcend Jet Flash V60 8GB #TS8GJFV60
hi, i srinivas, i am using dual booting of win 98 & windows xp operating systems. when i am using my transcend pendrive in win xp which is easily working, but in win 98, how can we install perpect drivers for my transcend pendrive.
so please give the solution to solve my problem.
Jul 13, 2008 | Electronics - Others
Mar 27, 2008 | Transcend (589307) Media
Electronics - Others Logo
187 people viewed this question
Top Transcend Electronics - Others Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Transcend Electronics - Other Expert? Answer questions, earn points and help others
