Question about MSI K9MM-V Motherboard
Shut down problem - MSI K9MM-V Motherboard
    Brigadier General:
  • MSI Master
  • 3,400 Answers
EXPLAIN BETTER.
Posted on Jan 01, 2014
Which parts should be changed to solve the problem not to automatically shuts down
It depends on why it is shutting down. Is it overheating? Is it full of dust or pet hair? Does it shut down normally showing you a shut down screen or does it merely turn off. If it turns off, then I would check fans and heat pipes. IF it shuts down with a shut down screen you would want to check your windows install.
Oct 16, 2016 | Computers & Internet
Shut down automaticaly
Not much to go on, "shut down automaticaly" on battery or AC or both? A computer will shut down, or hibernate, if thats what you mean, that's a power setting? If a computer overheats it will shut down automaticaly to save the components from heat damage. If there is dust in the fan and vents it will shut down. If it is not getting sufficent air flow from vents on the bottom of the laptop through the vents on the side. One option is a Laptop Cooler.Is it shutting down when you are on it? When it's left unattended? Respod to this post for further assistance.
Nov 19, 2012 | Unknown Toshiba Satellite P755-s5385 15.6...
I am having a problem with shut down the computer.After shut down command it displays windows will shutting down and hangs but will not shut down i need to press the power button to shut down(My computer...
Something is not closing on exit. Try running in safe mode, then shut down. If it shuts down then something is loading and present in the taskbar which isnt closing down.
Dec 19, 2010 | Computers & Internet
Hi guys I have a Toshiba Laptop Model TE2300 on shut down a screen comes up saying END PROGRAM- SAMPLE this stops you shutting down what is the problem and can it be fixed thankyou Kind Regards Mark
the end programs means that some program is running while you are shutting down you have close all the program before shutting down you can just click end program or wit for the process to end by itself to know which program is running while you close press CTRL+ALT+DEl click the file you will see the program which are running go to shut down and click shut down its shut downs and the end program stops coming
Nov 14, 2010 | Toshiba Tecra TE2300 Notebook
Shuts down going down the road shuts off completely
vehicle shuts down while driving down road and does not start backup for at least 20 minutes, could be a bad crank sensor. if bad it will start and run fine, but it will keep shutting down until fixed.
May 16, 2010 | 1997 Nissan Pathfinder
Shut down computer but some lights stay on
Your are not "shutting down" the laptop. It is going into "Stand-by" mode.
#1:
When you want to shut down,
select [Start]
then select "Shut down" and not "Stand-by"
The power button will also work.
#2:
Press the power button and nothing else.
The laptop will log you OFF and "shut down"
Nov 08, 2009 | Toshiba Satellite A135-S2386 Notebook
I cannot shut down or restart my PC using the start menu prompts. The only way to shut her down is a hard shut down (manually turn her off).
There is a program that is failing to shut down in general, which is delaying the computers ability to shut down.
The next time you shut down, make sure you have no programs open. Then, while attempting to shut down, wait until Windows pops up window asking you to close a non-responsive program. When it does, take note of the program that it mentions, then close it and see if Windows shuts down. Note: sometimes this takes a really long time.
Try re-installing the non-responsive program and see if your computer can shut down normally again.
Aug 07, 2009 | Acer Computers & Internet
E-machine computer will not shut down
When you say "it will not shut down", are you referring to clicking on start and then shut down?
You could try forcing a shut down by holding the power switch down for about 5 seconds.
Jan 18, 2009 | E-Machines eMachines Desktop PC
MSI K9MM-V Motherboard Logo
55 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
