Question about HP DeskJet D1460 InkJet Printer
Reset cartridge any time blink the power suitch,and donot impresion
E5 error and all leds blinking
Follow these steps since E5 means cartridges are not properly installed i.e. if you have not changed the cartridges prior to this point.
If you have replaced the cartridges, then remove them first & after cleaning the electrical contacts replace them again.
Otherwise do the following
First power off the printer. Next, while holding STOP/RESET button, power on the printer.
While holding POWER button, release STOP/RESET button. Then push STOP/RESET button twice.
Wait about 20-30 second until the LED shows "0′. Then push STOP/RESET button four times.
Finally push POWER button twice. Last step is to turn off the printer by pressing the POWER button one last time.
Nov 12, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
How do I reset my 3-in-one?
* Disconnect the unit from the computer. Take the cartridges out. Unplug the power cable from the back of the unit.
* Press and hold Cancel and Paper Type buttons together while connecting the power cord back to the unit.
* Turn on the unit and verify the result.
If the issue perists, please repair your unit as this is a hardware issue.
:) Dr Tony
May 13, 2010 | HP PSC 1510 All-In-One InkJet Printer
Green light blinks continuously, printer will not print. Has always worked well until now. Cartridges are in place, printer has paper, is connected to power and to computer. Is there a reset?
One or both print head are defective.Open cover put out color cartridge then close cover.If blinking stops replace color cartridge.If blinking continues put out black cartridge and put in color.If blinking stops replace black cartridge, if not stop replace both cartridges.
Sep 29, 2009 | HP DeskJet 3650 InkJet Printer
Will not reset, light blinks 8 times
Hi there you can try this
Start with the printer OFF
1. Hold down RESUME and then hold down POWER
2. Release RESUME
3. Press RESUME twice, then release POWER
4. Let green light blink until printer is done futzing
Select function with RESUME press POWER to execute:
presses - light color - function
Number of presses - light color - function
0 presses - green - Test print (or exit service mode on i960)
1 press - orange - EEPROM info print (plus grid nozzle diagnostic on i950)
2 presses - green - EEPROM initialize
3 presses - orange - Reset waste ink counter
All The Best Pineworks
Jun 04, 2009 | Canon I990 InkJet Photo Printer
Can I reset the drum units on the Okidata c5100, first time reset
Drum units are different than toner. Drums are expensive but need to be replaced between 30,000-40,000 impresions
Mar 16, 2009 | OKI C5100 Laser Printer
Hp psc 1500 constnatly blinks check printer cartridge and does no
According to this HP document, the problem is with the ink cartridge(s):
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00308379&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
You may want to try a reset:
Reset the HP All-in-One Follow the steps below to reset the All-in-One.
  1. Turn off the HP All-in-One by pressing the Power or On/Resume button.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Plug the power cord back into the HP All-in-One.
  4. Turn on the HP All-in-One by pressing the Power or On/Resume button
copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 22, 2008 | Office Equipment & Supplies
No ink impresion after cleaning the waste in pads....
Hope it will work
Reset ip2000
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal..
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jul 14, 2008 | Canon PIXMA iP2000 InkJet Printer
The printer apear to be dead!
Buttons and lights on the printer Two buttons and three lights are located on the front of an HP Deskjet printer.
  • The lights tell when the printer is working or when it needs attention.
  • The buttons help control the printer.
Buttons and lights Purpose c00123886.jpg POWER button and light Push the POWER button to turn the printer off and on. When lit, the light shows that the printer is turned on. c00123889.jpg RESUME button and light The light blinks when there is a problem with paper. When the problem is corrected, press the button. c00123892.jpg Print cartridge light The light blinks when there is a problem with a print cartridge. When the problem is corrected and the top cover is closed, the light will stop blinking. Troubleshooting blinking printer lights Blinking lights Reason c00123895.jpg
All lights are off. The printer is off (asleep).
Press the POWER buttonc00123886.jpg to turn the printer on.
The printer should turn on automatically when a print job is sent to it. c00123898.jpg
The POWER (top) light is on. The printer is idle.
The POWER (top) light is blinking. The printer is busy printing.
Allow enough time to print. When a document has many fonts or graphics or uses complex color such as a color photo, it takes longer to begin printing. c00123902.jpg
The PRINT CARTRIDGE (bottom) light is blinking. Possible causes:
  • The front cover is open. Make sure the front cover is completely closed.
  • The print cartridge is missing. Make sure the print cartridge has been installed correctly.
  • The print cartridge is broken or incompatible. Lift the front cover, and wait for the print-cartridge cradle to slide out. Check the part numbers on the print cartridge:
Black: 51645A
Color: C1823D,
If the print cartridges are compatible and correctly installed, they may be defective. Try replacing the print cartridges.
If none of the above suggestions fix the problem, and, if the error message still occurs, it may be a hardware failure. Call the HP Customer Support Center.
Jan 20, 2008 | HP DeskJet 710c InkJet Printer
Cannon BJC 80
5 times try this:
1: Unplug Power Cord
2: Hold POWER and RESUME buttons
3: Plug in Power Cord
4: Release buttons after the printers starts up
5: Hold CARTRIDGE and RESUME
6: Press POWER
7: Release all buttons after the beeps
8: Press CARTRIDGE 16 times
9: Press RESUME
10: Unplug the Power cord
3 times, probably something wrong with the cartridge.
Nov 21, 2007 | Canon BJC 80 InkJet Printer
Will not print at all
You can try restoring the printer to factory settings..and try agian it has worked most of the times for me..Let the catridge be in the printer when you do this..
Oct 27, 2007 | HP DeskJet 960c InkJet Printer
HP DeskJet D1460 InkJet Printer Logo
37 people viewed this question
Seeker5211
Seeker5211
