I need to manually turn the TV to ch 3 and cannot because it skips it from 4 to 2.
I need to manually turn the TV to channel 3 and cannot.
  • 864 Answers
Enter "3" or "03" on the remote and press OK/Enter.  If the channel-skip feature is set on for Channel 3 you cannot get to it using the up/down buttons.  Go to the setup menu to disable the channel-skip for Channel 3 if you want to tune it with up/down buttons.  If you have no remote you should be able to access the menu from buttons on the front of the TV. (They may be inside a door or panel.)
Posted on May 20, 2009
I have a Symphonic model ST420FF along with a Phillips Universal remote. The tv used to work oerfectly but then the channel changed (we have a charter cable box hooked up). Now when I try to change the...
Can you use the menu buttons on the TV to navigate to the control panel to automatically or manually add channels? That would be a start to make channel 3 exist again.
Sep 20, 2014 | Televison & Video
How can I set the channel BACK to CH 3 from CH 4
1) Set your TV to channel 3.
2) Insert a pre-recorded tape into this unit.
3) Press the OUTPUT button on the DVD/VCR so that the VCR OUTPUT light is lit.
• If noise appears on the TV screen, press the VCR/TV button on the remote control.
4) Press the PLAY button once.
5) After a few seconds, press the PLAY button on the DVD/VCR for 3 seconds.
• The RF output channel will change to channel 3 from channel 4 and you will see a playback picture.
• When a picture does not appear on the TV screen, repeat step [4].
6) Press the STOP button to stop playback.
Nov 17, 2007 | Emerson EWD2004
Sanyo vwm390 vcr
That might be the TV output channel. I found these instructions in a Sanyo manual:
How to set the DVD+VCR's RF output channel 1. Set the TV to the VCR channel (3 or 4) depending upon the selected channel. 2. When the DVD+VCR is turned off, press and hold CHANNEL (V/v) on the front panel for more than five seconds. It will turn itself on and "RF03" or "RF04" appears in the dis-play window. 3. Press CHANNEL (V/v) on the front panel or CH/TRK(v/V) on the remote control to change the RF output channel (CH 03 or CH 04). 4. Turn off the DVD+VCR.
It might solve the problem!
Jan 01, 2014 | Televison & Video
When I can get Channel 3 on my Sanyo TV, I cannot get Channel 2-3 or 3-4, or visa versa. If I can get can get Chs. 2-3 and 2-4 then Icannot get Ch. 3. I used to be able to set something or other to switch...
Hi, check the tv tuning menu for channel 3 - it may have been set to "Skip"
This can be proven if your remote has numeric keypad.
3 will be accessible through this but not through program + or -
Mar 19, 2010 | Sanyo Televison & Video
Hi problems seting up vcr to tv ,cant get a good picture through video and channel 3 on tv losses picture when video is turned on
there should be a switch in the back of the vcr to change to broadcast channel.
either ch3 or ch 4
switch to channel 3 and test.
then switch to ch 4 and test
make sure the tv you are attaching to is ON channel 3 or 4
Oct 12, 2009 | Samsung Televison & Video
Cannot get lower channels
this is a chennel SKIP fuction . set any ch. to out of the tv memry .so you are reset this ch. pls open tv menu sysem and select edit ch. function .
if your tv ch.no.4 is blocked [skip]. set edit ch no:4 see this ch. is SKIP ON if yes then reset to v- or v+ [or arow key] to set SKIP OFF see this ch. no:4 is view perfactly
if your problum is not solve. pls infom me with your tv brand name and Model no.
Oct 07, 2009 | JVC AV-27230 27" TV
How do i change my tv to channel 3? It is skipping this channel and goes from 2 to 4?
Instead of pushing the channel up or down button, manually input either 3 or 03 or 003 to get to ch. 3.
Oct 06, 2009 | JVC Televison & Video
Olevia tv erased all channels accidently
BEVERLYQC::
How do you " accidently erased all my chanels " from a tv??
Was the TV connected to a 'cable box' ?
Was the TV conected to 'air waves' or antena input.?
If the TV is attacned to a cable box, temperly remove the cable box INPUT wire, attache an antenna to the IMPUT AND AUTOSCAN WITH THE REMOTE CONTROL
If the TV cannot 'autoscan' in 'air wave' reception...goto menu and set input channel to ch.3 or see if there is a switch in the back that can change to ch.3 or ch.4
You should get all the 'air wave' chanels which will include ch.3 & ch.4
Oct 22, 2008 | Olevia LT42HVi 42 in. LCD Television
#4 & #5 buttons do not work on my remote. Channel 55 wont come in either on my tv
I had that problem 2 my channels disapeared one by one and some will skip yes...
I always use on my remote controll :
1 menu
2 Ch tuning
3 auto
and then wait untill it has found all the channels
Oct 02, 2008 | Orion1934 19" TV
Magnavox with pic tube tv skips over channel 3..goes from 2 to 4
You are right about the auto-programming, but Magnavox no longer has the original remote.
For my answer to be right, you must have posted this question to the EXACT CORRECT model # of your Magnavox TV - 27ms343s:
Press TV on your Verizon remote, and then press "0" and "3"
If that fails:
Press MENU to see the TV’s on-screen
menu. In the menu, use VOL.+/_ and
CH.+/_ to make adjustments or selections.
You can press MENU on either the
remote control or the front of the TV to
access or remove the menu.
Jun 14, 2008 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
314 people viewed this question
Top Televison & Video Experts
Electro Med Services...
