Question about Bosch Cooktops
Bosch f2 error
One of the rings in on my hob is blinking F2. What does this mean pls?
2 Suggested Answers
caroldon
  • 17130 Answers
SOURCE: bosch five ring hob ignition
It can be for another model if this is the ignition unit. Please confirm with your supplier before it can be tired as they might allow you to exchange if this order was misplaced. Please quote the part number or model of the oven.
Posted on Nov 11, 2011
I have an EKI 807.2 Glass hob. I can't turn the heat up on more than one ring without E flashing on all the Rings followed by 6
Are you sure it is properly wired? For 1 phase 230v:
1= power earth
2-3 intersected = N
4-5-6 are L1-L2-L3 that should be conected together to L
Kuppersbusch is not very cooperative about what their error codes indicate, but E6 seems to be a (low) voltage issue, so you might too check the cabling to the outlet, measure the voltage with a multimeter when you successively switch on elements
Dec 22, 2015 | Kuppersbusch Glass ceramic induction hob...
Bosch five ring hob ignition
Nov 11, 2011 | Cooktops
Only the two back rings are working on the hob - connected yesterday. Any ideas ?
Hi Mark,
Have you solved your problem.... because I have the same issue!!! please help me... :-)
Aug 01, 2011 | Bosch 24 in. PIE675T01E Electric Cooktop
Bosch Ceran Schott hob. Number in top left corner
We have this exact same problem, and I've not managed to track down a manual (we rent and the landlord is on holiday).
I've tried holding down all buttons for a time, combinations of buttons, and turning it off at the mains, but no joy.
Did you ever solve this?
[submitting this as 'post solution' but there is no button for 'say you have the same problem'!]
May 27, 2010 | Bosch Cooktops
I have a kenmore gas range and on the display is says EO F2
The "F2 - E0" error code means "Shorted keypad".
Remove power from the range, open the control panel and unplug the membrane switch ribbon from the control board.
Reconnect power to the range and observe for an hour.
If the error code reappear - replace the control board.
If not - replace the membrane switch.
If I get the model # I can help you pind the right parts.
Good Luck and please rate 4 thumbs for the free answer
Apr 17, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
The oven was on at 350 degrees. All of a sudden the oven increased the temperature and displayed ER F2 error on the display. What was in the overn was instantly burnt.
If you have a Kenmore or Dacor, Thermador, Amana Caloric, Westinghouse, Admirals, or if you have some retagged oven from this brands, F2 is temperature runaway, usually a bad temperature probe.
On Admirals you may need to test the relay board.
Try disconnecting power (trip circuit breaker or disconnect power cord).
If the error is still there, test if the probe has continuity, then eventually replace it.
On Whirlpool ovens F2 is a faulty keypad assembly.
To get a technician to do the repair call the support number listed on the manual.
Dec 15, 2009 | Cooktops
Hob is locked
Press the 'Oven light' for about seven seconds...
Jun 06, 2009 | Bosch 24 in. PIE675T01E Electric Cooktop
Bosch ceramic hob
hold down powerboot for 4 seconds to switch off child lock
May 30, 2008 | Bosch 24 in. PIE675T01E Electric Cooktop
Miele KM5753 Induction Cooktop - Error 30
I have a KM5753 with FE31 and it remains after a breaker 1 minute re-set as per instruction booklet - anyone seen that one?
Mar 01, 2008 | Cooktops
Cooktops Logo
108 people viewed this question
Top Bosch Cooktops Experts
Paul Carew
Jay Finke
Jay Finke
steve morris
steve morris
Are you a Bosch Cooktop Expert? Answer questions, earn points and help others
