Question about GE Refrigerators
My GE refrigerator control panel has locked and will not respond
5 Suggested Answers
  • 3 Answers
SOURCE: GSH25JSRF SS Issue with water/ice delivery
I had the same problem as do thousands of people with this same fridge. The mother board is bad and needs to be replaced. It is easy to do yourself and the part costs less than a service call.: Unplug the cord from the wall, remove the panel from the back of the fridge (it is about the size of a small shoe box lid) You will see the mother board (ice, water, light, and compressor control unit). It is an electronic circuit board. There are about 5 or so plugs going into the board. Remove the plugs and the retaining screws and search Ebay for the part#WR55x10552 GE Power Control Board. I found one for $74, popped it in, and everything works better than new!
Posted on Mar 21, 2009
AGUSYUSTIARA
  • 116 Answers
SOURCE: Temperature and adjust refrigerator panel does not work.
problems exist in its electronic control panel that is damaged, this problem should be solved by replacing one block electronic circuit in the control panel. damage is usually caused by a memory of the troubled program. actually if you know you can fix the electronic control panel of the electronic circuit itself, simply replace the IC EEPROM or memory alone. follows with Cristal oscilator usually must be replaced too
Posted on Jul 24, 2010
  • 2328 Answers
SOURCE: I have a GE refrigerator model GSS25QGMD CC and
there's a computer board or mother board that's in the back of the fridge,pull it out away from the wall and when you look at the back you'll see a square cover with some screws holding it in place,this is where the board is,everything runs through this board and i've been changing alot of them,G.E. has had problems with the boards,unplug the machine,remove the cover,then with a pair of needlenose plyers you have to pinch in the tabs on the 4 white plastic holders,one at a time and when you pinch it pull on the corner of the board and it will slide off one corner at a time,after you get the first one you'll get the hang of it,when you have the board of the holders pull off the gray or blue color connector on the bottom and pull off the other bottom wire harness so you can move the board over and pop the new board into place on the holders,if you look next to the harness wires where they connect to the board you'll see like j1,j2 just look at it on the old board and then slide it onto the same number on the new board,they are almost in the same place but a couple are in different spots so just wire them the samw way you took them off,read the paperwork that comes with the board,it will tell you that if there's a wire in one of the harnesses,i can't remember what one i just know by doing it i think it's j1 and if there's any wire in the second hole to cut it,you have to cut the wire if it's in the hole that it tells you about,i'm sorry i can't remember the correct one but it will tell you on the instructions,i haven't cut one out in a while,usually on the older machines so you most likely won't have to do this,once you have the board in and grounded with the cover on plug it in and i'm 99 percent sure this will be your problem.the part number is the common board WR55X10942 and it's around 150 dollars.if you look at the back of the old board you might see the burn marks where the board failed.good luck with your machine and i hope i explained this to you so you will have no problems changing out the board.
Posted on Aug 12, 2011
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: frigadidaire refrigerator control panel not working
    Sounds like there is a defective or faulty control panel or control board. Contact your manufacturer or the dealer you just purchased it from.
    Posted on Aug 30, 2012
    The control panel on my jenn air fridge model # jfc2089htb is not responding and I cannot adjust any setting. Fridge is stuck at 44f and freezer -1f
    A simple reason could be the control panel is locked (child/safety lock) - look for a small lock symbol in the display.
    Oct 30, 2016 | Refrigerators
    Control Panel failure GE Adora refrigerator
    disconnect from the mains, count to 10 and plug back in.
    Oct 16, 2015 | Refrigerators
    RT50 control panel not responding
    It still sounds like the child lock is on since that prevents accidental setting changes on the refrigerator's control panel.The following will NOT work if the child lock function is activated: Freezer Temp Button Fridge Temp Button Power Freeze Button Power Cool Button Ice Type Button Water Button Ice maker Water OR it may be in Cooling Off/Demo Mode. Cooling Off/Demo Mode is a feature used by retailers to display the refrigerator without running the compressor. If your unit is not cooling, and the bars are constantly scrolling up and down the temperature, check your manual for reset advice
    Mar 31, 2014 | Samsung Refrigerators
    Profile GE PS123Sc about 6-7 yrs old. Freezer side seems fine. Fridge side is too warm, but is cooling (about 40F). Fridge side lights are intermittent and control panel at top is intermittently dark or...
    Sounds like a bad motherboard and probley need control board. You can put in self dianoss. Press all the buttons on panel for 5 seconds. This will start the program. It will check all sensors. Come back with codes and I will help you. Wait to hear from you. I hopes this helps. david_gra582
    Aug 27, 2011 | GE Profile PSS26NGS Side by Side...
    GE Profile refrigerator panel on front has stopped responding to requests for ice. It give water, but no ice. Any ideas on what is needed?
    Yes, we will need to check the wiring from the motherboard to the dispenser controls. Also we need to test the door switch. The door light switch works two ways by turning on light when open and turning on dispenser controls when closed. Sometimes the door switch is bad. I have a link and will work with you to solve this, Let me know, Thanks, Sea Breeze
    Apr 18, 2010 | GE Profile PSS26NGS Side by Side...
    Electronic Panel not working.
    could have a bad board they are expensive,you might want to call someone in to do this ge is having alot of problems with them
    Nov 02, 2009 | GE PFS22SBSSS Stainless Steel French Door...
    Temperature control panel beeping
    There are 3 models with this model #,so not sure if your has lock.
    If it does and still changes,contact ge and tell them what is happening,maybe they will send you out a new control panel,if the warranty expired,depends.But it doesn't hurt to try.
    This feature allows you to lock the controls
    so the settings cannot be changed.
    To lock the controls:
    Set the controls to the desired settings.
    Press and hold the lock pad for
    3 seconds.
    When the controls are locked, the indicator
    light will come on and the control settings
    will not be displayed.
    To unlock the controls:
    Press and hold the lock pad for 3 seconds.
    After unlocking the controls, the settings
    will be displayed, the lock indicator light
    will go out and the settings can be changed.
    Apr 14, 2009 | GE PTS22LBN Top Freezer Refrigerator
    How to unlock control lock on ge monogram side by side
    shoud be amatter of pressing abutton and holding in for 3-5 secs to unlock. look closely at the control panel it should indicate which button(s)
    Jan 24, 2009 | GE Refrigerators
    Refrigerators Logo
    26 people viewed this question
    Top Refrigerators Experts
    Sal DeAngelo
    Charles T Nevin
    Charles T Nevin
    Andrew Taylor
    Andrew Taylor
