Question about Singer ESP2 Electronic Ironing Press Variable Steam ESP-2, 24x9€ Board, 7 Times Hand Iron Surface, 100 Lbs Pressure, 300ml Water Tank, Auto Off, 22Lbs
Singer steam iron will not heat
Switch turns on lights and alarms but will not heat
3 Suggested Answers
SOURCE: my singer magic press 4 iron comes on but the plate will not heat
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
Posted on Nov 05, 2009
heatman101
  • 43501 Answers
SOURCE: singer steam press csp-1 iron
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Posted on Jul 14, 2010
Singer magic steam press 7
singer magic 7 is used carefully as it is closely to iron so check if wires are connected correctly
Jan 22, 2014 | Singer Electronic Steam Press Iron
Singer 7467 wheel won't spin, unless little bit if I do manualy by hand...
do this
If the iron heats but steams improperly, inspect the soleplate and clean the vents (see below) and flush sediment out of the steam chamber (see below).
If the iron produces too much or too little heat, test the electrical cord . Also test and, if needed, adjust calibration of the thermostat
If the iron does not spray properly, inspect and clean the nozzle (see below).
If the iron leaks or spits, clean the steam vents, nozzle, and tank.
If the iron sticks to fabric, clean or repair the soleplate. If the iron stains fabric, clean the soleplate, clean the tank with a commercial cleaner, and use distilled or filtered water.2_1_2013_6_01_09_pm.jpg
Jan 31, 2013 | Singer 7467S - Confidence Sewing Machine
My singer magic press 4 iron comes on but the plate will not heat up. I turn it on one day and it just would not heat up.
Jun 18, 2009 | Singer CSP1 Iron
Singer steam press csp-1 iron
heatman101
Mar 03, 2009 | Singer Electronic Steam Press Iron
Breville ir23 steam iron
My electronic steam press has been performing perfectly until yesterday. I can not longer get it to turn on? Any suggestions? carolb745
Jun 17, 2008 | Singer Electronic Steam Press Iron
No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Jan 03, 2008 | Euro-Pro Steam Generator EP8001 Iron
No Steam
Your iron will only steam when it has reached the desired tempeture. When the yellow/orange light comes on and the dial has been set for cotton or linen it should steam, when you lower the top and push the steam lever
Nov 01, 2007 | Singer CSP1 Iron
Heats up but no steam coming out.
take down the iron and clean it the holes at the bottom of the iron are clogged up.good luck.
Sep 10, 2006 | Euro-Pro Steam Generator EP8020 Iron
Singer ESP2 Electronic Ironing Press Variable Steam ESP-2, 24x9€ Board, 7 Times Hand Iron Surface, 100 Lbs Pressure, 300ml Water Tank, Auto Off, 22Lbs Logo
Top Singer Irons Experts
russ davis
ray gallant
L Pfaff
L Pfaff
Are you a Singer Iron Expert? Answer questions, earn points and help others
