Question about Kicker KX600.1 Car Audio Amplifier
Protection mood it is stuck in protection mood. ground is fine power lines are fine as well as remote line. changed out the fuses just in case but I still cant get the amp to reset
  • 655 Answers
Hello john_hart,
Check the speaker wiring too. If one of the speaker wires is shorted or grounded, the amp will go into protection mode.
Hope this helps.
Posted on May 21, 2009
Infinity Basslink. I wired and connected everything and sounded amazing. I removed my center console to construct a box to put the Basslink in. When I was putting the Basslink sub into the box (tight fit)...
I would get a test light and see if the remote line is still working. Otherwise, yes you probably fried it. Doesn't take much in car audio to fry an amp.
Jan 17, 2014 | Infinity BASSLINK Car Subwoofer
Protective mood
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty. Hopefully its not toast. .A thumbs up would be greatly appreciated if this answer is helpful to you. protective-mood-zb4bomd1rt4qms0dqd12kkt2-2-0.jpg
Jan 16, 2014 | Car Audio & Video
Protective mood on boss 1600 watt amp
Disconnect all speaker connections and rca cables. Leave power, ground and remote wires intact. Try turning on again. If you still have a protection light your amp is faulty. Hopefully you have warranty . Might be time for an old s .A thumbs up would be greatly appreciated if this answer is helpful to you. protective-mood-boss-1600-watt-amp-zb4bomd1rt4qms0dqd12kkt2-2-0.jpg
TRUCK DRIVES LIKE IT IS IN LOW, WAS STUCK IN 4X4
Is the system still stuck in 4WD ? You can try driving ~ 50; in reverse, place into park and try shifting back into 2WD mode. This is the old procedure, but some times helps with the sync gears ( if they are getting worn ) on the Shift on the Fly action into 4H.
If this does not work, start the truck ( take precautions, park, parking brake on, chock wheels, etc ) and have someone watch the front vacuum disconnect motor. could be the transfer case is changing back to 2WD, but the front axle is not unlocking the front hubs ( will make the truck feel strange, pushing the dead axle ).
The vacuum shift motor, is #10 in the picture below.
Close up of what it looks like :
If this is not moving, check for vacuum on the vacuum lines to it, the pink vacuum line si the @D mode, the Light Blue line is the 4WD operation. Check with a vacuum gauge.
If the vacuum is not at the vacuum disconnect motor, check the solenoids on the firewall.
Could be a cracked vacuum line to the disconnect motor, or could be a cracked vacuum line to these from the vacuum reservoir behind the battery box.
If the vacuum is fine, check that the vacuum solenoid is getting ground ( the GEM - Generic Electronics Module supplies ground to the solenoid, the power is always there ). If the Solenoid is not getting ground, the contact plates in the transfer case would be suspect ( not signalling the GEM that the mode has changed ).
Feb 16, 2011 | 1997 Ford F150 Regular Cab
Don't have any dash lights or tail lights , changed light switch, dimmer switch and body modual did not help and all fusses are good all grounds are good, any new idears would be a great help
Welll.... It's time to use a test light. Take the main fuse out and test all the wires on it for power. Determin which wire is driving lights (tail lights) and i would hot wire it to either a power wire from the dash or from the Tail lights. This just might fix everything.
Please leave a good feedback for me on here.
Thanks
Hope this helps.
Jan 06, 2011 | 2002 Buick Park Avenue
When i put on power protect light come on
If the amp is in protect mode, it probably has shorted output transistors. To eliminate other possible causes, do the following. Disconnect all speaker wires from the 'amplifier's speaker terminals' and disconnect RCA/signal cables from the amp. If it powers up normally, the speakers/wiring need to be checked. If it still shuts down (goes into protect mode), the amp almost certainly has shorted output transistors and will need to be repaired. If the amp only shuts down when it's driven to relatively high volume, you need to confirm that you have sufficient power supply voltage. With your multimeter set to DC volts, the black meter probe on the ground terminal of the amp (not on the point where the ground wire connected to the vehicle) and the head unit on (so the amp will have remote voltage applied), touch the red probe alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts on either the B+ or remote line, you need to check the wiring feeding whichever line is too low. If 'both' the B+ and remote turn-on lines are low and your battery is fully charged, you may have a bad ground connection.
Dec 15, 2010 | JBL BP1200.1 Car Audio Amplifier
My protection mode red light comes on right when i put the fuse in my power line, even when my cars off!!! is it that my ground is bad? ineed some help!! oh ya, lol, its a ela300.1 bazooka amp!
Check your ground most definitly!, Replace it if needed. Check your remote wire and power wire as well. And if none of this works, then you are having internal issues.
Aug 26, 2009 | Bazooka ELA300.1 Car Audio Amplifier
Brand new Amp, LED Protection lit up
If you have a good ground and 12+v on both the B+ and remote terminals, it's likely a DOA amp. Return it to the place of purchase for repair or replacement.
Jun 10, 2009 | Visonik V204XT Car Audio Amplifier
Problem
Start removing wires from the amp, one by one (except for the +12V, Ground, and remote) until the amp seems to work fine. Usually, this type of issue is due to a speaker wire shorting to something it shouldn't be touching. Check the "non-amp" end of all the wiring to make sure they are solid and correct.
Apr 04, 2008 | Volfenhag ZX-8300 Car Audio Amplifier
Kicker KX600.1 Car Audio Amplifier Logo
197 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
