Question about Harman Kardon FL8350 5-Disc CD Changer
Error message when trying to load discs, none are recognized
Disc load problem
DVD players need a finilized disk. When the program finilizes the disk, it's writing the TOC which is where the players go to find the files.
Mar 12, 2014 | Toshiba RD-XS34 DVD Player/HDD Recorder
Discs won't play.
please change laser unite then solve your problem
Jul 16, 2009 | Sony DVP-NS575P DVD Player
DISC LOADS TO 80% THEN SAYS ERROR
You are correct chances are that its your new computer are slim to none. It would help if you posted what kind of error message you are getting as there are many many different ones that would help solve the problem.
My suggestion is that you make sure to clean the disc very well, as a scratch/damaged disc may be the cause of the error.
Hope this helps some, if you continue to have problems post the error message for further help.
Thank you for stopping by Fixya! Please leave a positive rating if this solution helps.
Mar 15, 2009 | EA - Electronic Arts The Sims Double...
Disc error message when load DVD
Are you loading to play or to record?
Commercial DVDs should play.
DVDs for recording may not be recognized by your drive. First make sure that the disc is blank. You must insert a blank disc of the proper format: DVD-R or RW, DVD+R or RW. Even with the proper format, some brands may not behave the same way as other brands.
Dec 24, 2008 | JVC XV-N320 DVD Player
C:13:00 Error Message with data already on CD?!
I have this exact same problem, and I'm about to smash my camera its making me so upset.
Apr 28, 2008 | Sony Handycam DCR-DVD101 DVD Camcorder
Disc Error message
UNPLUG UNIT AND LEAVE OFF FOR 1 MINUTE. THEN PLUG BACK UP AND RESTART
Mar 17, 2008 | Sony RDR-GX300 DVD Recorder
Error message - incompatible disc
I BUT A JVC EVERIO BURNER AND I CANT BURN MY VIDEOS FILES I insert the Disc in the Burner, it tries to recognize the disc and then comes up with , DISC ERROR CHANGE DISK
Jan 29, 2008 | JVC CU-VD10
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Toshiba dvd rom sd r6012 isn't reading the DVDs
Try some factory CD and DVDs and just try to get them to open in Windows (not play in a media player program). If you get errors on every disc you try, it may be your CD/DVD hardware packing in.
If it reads some CDs or DVDs and not others, particularly media discs, you may be having software driver problems, otherwise, it is likely hardware.
Try inserting the disc and spinning it up while resting the laptop on its side, or even upside down. If it reads sideways or upside down, the CD/DVD reader hardware has gone and cannot probably be prepared (this is a symptom of physical controller failure and is ot fixable by normal means).
Good luck...
Nov 12, 2007 | Sony VAIO GRZ660 Notebook
Harman Kardon FL8350 5-Disc CD Changer Logo
26 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
