Question about Hitachi 65F59 65" HDTV
TV..everything works...but screen goes red...I smack it, it goes back to normal, but then back to red.
My hitachi 67' tv has a problem. The screen will glitch favoring the color red. If there is a word on screen it's doubled, if there is a face or figure its doubled. Anywhere there is light example candle, fire, etc, it is red. It is very akward to explain this problem but see if this helps...when I turn the tv on its fine but then after 2-3 min it will turn to that color red...if I smack the side of the tv it goes back to normal, but eventually the red takes over again.
  • Jim Goldsmith
    Jim Goldsmith May 11, 2010
    Due to the "smack" cure I would say you have a circuitboard trace that has a cold solder joint look at your circuitboard with a magnifying glass for a dull instead of: bright solder joint after you remove the back cover and, "smack" it again if this doesn't help please give me the chassis#
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 123 Answers
It soinds like a convergence problem, i would try haveing someone take a look at it
Posted on Jun 14, 2009
Have a 50fx48b Hitachi TV, screen flickers, gets wavy and goes to horizontal line, smack top of tv and it goes back to normal.
This problem is a couple of bad caps in the vertical and horizontal sweep area, just can't remember which. It use to be a 220uf cap that needs changing.
Feb 28, 2011 | Hitachi 50FX48B 50" Rear Projection...
Have a 50fx48b Hitachi TV and screen flickers and then goes to small wavy horizontal line. smack tv and it goes back to normal.
If your TV looks 3D, warped, or distorted it likely has a convergenge problem.
If however it just looks dull, washed out, redish, greenish, or blueish or if it looks like objects on the screen have halos the fluid in the lens has soured.
You can search google for parts or you can get the parts with repair instructions from sites such as www.TvRepairKits.com
Hi i have a hitachi tv, serial no:v71100318. the tv hasnt worked properly for the last few weeks, i switch it on the standby light is green blue screen comes on then the screen goes off and standby light...
sorry but the serial number doesn't tell anything about a set, the model is what you need first, it could be lamp but don't know the model
Feb 13, 2011 | Hitachi TVs
My picture is now always a pink to red shade on my
unplug your TV look on the back for a three controls marked red / blue / green "screen" turn / tap on them; watch the screen when you find the "dirty" control clean it with "TV tuner cleaner spray"
Mar 20, 2010 | Hitachi 57UWX20B 57" Rear Projection...
Green hue
Unplug the TV from the wall and plug it back after 45-60s should fix the problem. However, it will come back from time to time so the same procedure will reset the video board. You'd want to upgrade the firmware on the ATSC tuner as well because old firmware was built before the final standard and when the TV goes digital in June 2009, it wreak havoc on all older HD TV. Go to hitachi website and download new FW for your TV. Copy the FW to an SD card and follow procedure from Hitachi to upgrade. It works wonder for my TV after the upgrade.
Sep 22, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Hdtv has a red screen
Looks like you got some convergency issues there, I would consult a local repair place like www.teexp.com put in your zip code and see if they service your area and TV.
They can also give you a estimate on how much it will cost to get it repaired.
Jun 12, 2009 | Hitachi 57S715 57" Rear Projection HDTV
Screen color problems
try the magic focus.maybe it will work.
Jan 31, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
Channel changer locks up
Make sure you have the tuner set for digital channels only. then redo the channel search.
May 06, 2017 | Hitachi 57F500 57" Rear Projection...
Sony KV-32S66 Picture Rolling Up/Black Horizontal Lines
the problem there is a loose connection on the board,you said that you smacked the right side of the tv and it goes normal.there are parts that should be resolder on the board in order to back into normal operation.
Oct 22, 2008 | Sony KV-32S66 32" TV
Hitachi 65F59 65" HDTV Logo
235 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
