Question about Toshiba Televison & Video
I cant get it off cable, to Ant. i have no manuel
Toshiba 46G300U 46" i have no manuel so i'm having a hard time working tv, cant get it off cable mode please help
    Sergeant:
  • 290 Answers
Pres "Menu" then "setup" then "installation" then "terrestrial" then "Iinput configuration" then the "Ant\Cable" and finally left or right arrow to set the input type and then move to "Done" button. Also, Manualowl.com has a copy of the manual in PDF form.
Posted on Jan 01, 2014
ARTGIRTNY575
  • 96 Answers
SOURCE: toshiba 42HP66, HDMI problems
Your Cable box might need to be reprogrammed. Call the cable company and they will drive you thru the steps to program it, this way you will get the channels. This process might take you 30-45 minutes.
Artgirlny
Posted on Jul 12, 2008
mistersony
  • 320 Answers
SOURCE: No Video for my cable tv. Audio works
You have the TV connected to the cable box with an HDMI cable, I'll bet. The problem is with the cable box. If you unplug the cable box and plug it back it it will reboot and proabably work. You should connect the cable box to the TV using component cables and you won't have this problem again.
Posted on Nov 11, 2008
SOURCE: toshiba 46 HD TV-1/2 Screen going out
I have a Regza 46XV648U. And sometime my sound will sound like a Echo Chamber, i can turn it off and the sound will be alright for some time.
Posted on Aug 22, 2010
  • 4 Answers
SOURCE: i have a samsung 46
Get a HD cable box from your cable company. If you already have one, be sure it is conected to the TV with either an HDMI cable (best) or component cables (next best). The HDMI cable should look similar to a USB cable for a computer, only a good bit larger. The component cables would look like standard video cables but they are colored red, blue, green at both ends. If it is hooked up with either of those, you'll need to call a service techinician from the cable company to check your signal levels, as they are likely too low, especially if the tech that did your install was inexperienced or just lazy.
Posted on Nov 03, 2010
SOURCE: vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Posted on Jan 25, 2011
I have a toshiba 42HL196 tv and i am trying to connect it to an external antenna. I cant find a channel scan option in the setup menu. The menu on my tv is not the same as the toshiba video.
First check the current source. Press the Input button on the TV (second from the left) or on the remote (below 9) until the correct Antenna input (Ant 1) is selected. Make sure that the antenna is connected to Ant 1 (the RF connection closest to the back HDMI ports). You only use Ant 2 if you have a coaxial (RF) cable connection. Then press Menu and then try the Setup menu again. You should be able to access the Installation menu and Terrestrial sub-menu now. Change the Input Configuration for Ant 1 to Antenna before attempting to Program Channels.
If this doesn't work, try resetting the TV to the factory settings. You'll have to access the Menu, go to the Installation sub-menu and then select the System Status and then System Information. Select Factory Defaults and enter the PIN. See the manual for the default PIN if you haven't changed it. Then confirm the reset. The manual is available from the product support page: http://support.toshiba.com/support/modelHome?freeText=2841536 . The direct link to the manual is http://cdgenp01.csd.toshiba.com/content/support/manuals/userguides/su2846615/42hl196_om_e.pdf . See page 29 for the PIN. Then try accessing the Terrestrial menu and scanning for channels.
I hope this helps.
Jan 31, 2017 | Toshiba Televison & Video
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
Does my toshiba have a built in converter
The Toshiba 46G300U TV has a built-in Digital QAM, ATSC & Analog NTSC TV tuner.
Apr 01, 2013 | Toshiba 46G300U TV
How do i change the the antenna from cable to antenna
which of these TVs is yours?
Originally supplied with models: 19AV600U, 19C100U, 19SL400U, 22AV500U, 22AV600U, 22C100U, 22SL400U, 26AV500U, 26AV502R, 26AV502R/U, 26AV502RZ, 26AV502U, 26AV52R, 26AV52U, 26C100U, 26C100U1, 26c1100u, 26SL400U, 32AV500U, 32AV502R, 32AV502RZ, 32AV502U, 32AV50SU, 32AV52R, 32C100U, 32C100U1, 32C100U2, 32CV510, 32CV510U, 32DT1U, 32E200U, 32RV530U, 32SL400U, 37AV500E, 37av500u, 37AV502R, 37AV502U, 37AV52R, 37AV52U, 37CV510, 37CV510U, 37E200U, 37RV525R, 37RV525RZ, 37RV52R, 37RV530U, 40E200U, 40E200U1, 40E200U2, 40FT1U, 40G300U, 40G30U, 40RV525R, 40RV525U, 40RV52R, 40RV52U, 40XF550U, 40XV640U, 40XV645U, 40XV648U, 42AV500U, 42RV530, 42RV530U, 42RV535U, 46/40/55S41U, 46G300U, 46G30U, 46RV525R, 46RV525U, 46RV530U, 46RV535U, 46RV53CU, 46SL412U, 46XF550U, 46XV640U, 46XV645U, 46XV648U, 52RV, 52RV530U, 52RV535U, 52RV53U, 52XF550U, 52XV645U, 52XV648U, 55G300U, 55HT1U, 55S41U, 55SL412U, 19AV600UZ, 19SL410U, 24SL410U, 32C110UM, 32FT2U, 32SL415UM, 40E210U, 40SL412U, 55G310U, 42RV525R, 32C100UM, 32DT2U, 40E210U1, 65HT2U, 32RV525RZ, 46RV525RM, 40G300U3, 46G300U1, 32C120U, CT90302 Programming Instructions and Codes, CT90302, 75022871, 75017678, 32E20U, 37E20U, 40E20U, CT90325, 75028874, 24SL410UM, 32C110U, 32SL410U, 32SL410UM, 40E210UM, 46G310U, 32C110U1, 32DT2U1, 40FT2U, 32C10U, 19L4200U, 24L4200U, 32L4200U, 40L5200U, 46L5200U, 50L5200U, 26C100UM, 40E200UM, 55HT1, 50L2200U, 39L1350UC
Jan 12, 2013 | Toshiba Ct90325 Remote Control
Toshiba lcd ant cable problems
1) you must repair the ant cable, see if the cable is open or break test with VOM, this can produce erratic problem.
2) you have the options to go to the repair shop TV for fix.
3) clean the contacts antenna TV, for dust, dirty or oxide.
4) repair any broken wires and solder.
5) of course you have the probably problem of some problem inside of TV example, TUNER, i-f,video detector, AGC. test it see the diagram
God bless you
Jul 12, 2012 | Toshiba CF36G40 36" TV
I can't hook up my sony wireless headphones to my new tochiba tv
there is no headset jack on the Toshiba 46g300u. It is a bummer. If you add a sound system for $200 bucks or more, they usually come with a headset jack. I sure wish this tv came with a jack, I mean, how can it not?
Jul 05, 2011 | Toshiba 46G300U TV
How(or can) do you display the time on a Toshiba 46G300U, I just bought one and cannot find a way to display the time when needed???
i have the same toshiba and if you look carefully in the manual there is NO clock in this model mine was purchase in last october in canada
Jan 01, 2011 | Toshiba 46G300U TV
Tohsiba 46G300U. What type of video/movie files can be played directly from the USB input using the televisions media player?
none you need a dnla certified storage with server function or a connection to your home network to your pc read pages 51 to 56 of the owners manual for details good luck from POPPER951
Dec 08, 2010 | Toshiba 46G300U TV
Can't get PIP to work on my Samsung LCD 46"
its talking about the analog tuner in your tv. split the cable before it hits the box plug the cable strait into your tv if there is more than one coax connector on your tv you will need a second two way splitter run one into ant a and one into ant b yo will not be able to use pip and hd at same time you can only do pip with the analog tuners built into you tv
Mar 17, 2009 | Zenith Z36X31D TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
