Question about LG Microwave Ovens
E10 error what is error e10 plz provide solution
What causes error code F1 in my Electrolux convection microwave EI303BM60MS?
Thank you for your inquiry, Leanne!
From the information you have provided your Electrolux microwave is displaying an error code of "F1". I am showing that an "F1" error code is not valid. I would recommend resetting your microwave and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not correct your issue and you continue to experience an "F1" code please reconnect. -Matt
Apr 27, 2015 | Electrolux Microwave Ovens
Error message econ
I appreciate your post, friend!
Based off the information you have provided your Electrolux built in microwave is displaying an error code of "ECON". I am showing that this is an invalid error code. I would recommend you perform a reset on your microwave and you can do that by disconnecting the power cord for roughly ten minutes. If that does not help correct your issue I would suggest contacting a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Mar 16, 2015 | Electrolux EW30MO55HS Built In Microwave
E4 error message
The E4 error code is a result of a malfunctioning defrost sensor. If the error code is on the right then it is the defrost sensor in the upper chamber.
Attached is a link to Avanti service and parts. Provide them with the model number of your wine cellar and they will be able to provide you with a price and information on the part needed for repair.
http://www.avantiproducts.com/index.php?page=contact
If you have the owner's manual or are able to speak with a service technician through Avanti, then this can be a diy repair.
Sep 06, 2013 | Avanti WCR5450DZ
We keep getting an error code "F 12" and have no idea what it refers to
Is the oven heating? I looked at all the comercial microwave oven codes but this does not show up, but if memory serves me the f-12 code is lower magnerton circuit failure, note not necessarily the magnetron, possibly the capacitor or a gritty joint to the mag from the lv side.
http://www.microwavespecialties.com/pdfs/E10-2010-08%20Pro%201%20Error%20Codes%20and%20Flow%20Chartpdf.pdf
Sep 15, 2011 | Panasonic Pro NE1257 Microwave Oven
Error E:02 comes up
Hi nic_marlon,
The meaning of the error code depends on what brand of your machine is. If you can provide it to me I can give you accurate information. On Westpoint this error means you have a temperature sensor error. The sensor is damaged or faulty.
Hope it helps.
Thank you for using Fixya.
May 08, 2011 | Microwave Ovens
Call engineer and E-10 on display on amana commercial URFS518S Micro wave oven could you please tell what the fault is and how i can cure it. Regards.
E10:
An attempt has been made to program the oven for more time than allowed.
1. Press STOP/RESET pad.
NOTE: Maximum cooking time is 60 minutes except when cooking with full
power (100%). In case of full power (100%), maximum cooking time is 20
minutes.
If that doesn't work, leave it unplugged for maybe an hour then try again.
An owner's manual that may work for you is here.
Oct 21, 2008 | Amana Microwave Ovens
Model 767w
First of all, it should still be under warranty since it's less than a year old.
If so, I would contact LG at the number on the owner's manual and check with them.
They should be able to send an authorized servicer and repair it at no charge.
Otherwise, the E10 code usually indicates a problem with the control board or keypad.
This can also happen if moisture gets into the controls, either from steam, spray cleaners, or being in an unheated building such as a garage or shed.
Nov 08, 2007 | Microwave Ovens
LG make Combimode microwave oven not working
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(http://www.fixya.com/wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Dear Friends,
The Main Board error codes indicate for most of occurrences that the board itself has not passed the start up checks that are built in but there are cases when this is due to peripheral like door safety switches, shorted elements etc. While it is quite worth to explore this yourself if you are a techie and feel confident, please do not attempt if you do not know for sure what you are doing. And yes- DISCONNECT THE POWER PLUG BEFORE YOU ATTEMPT TO REMOVE COVERS and keep it disconnected till the work is over.
Check care fully for the looseness in all the connectors that go to the main board behind operating panel and the door switches, thermal cutouts and magnetron itself. you need not to know about these components, you are just looking for loose connections. If you find any - try to unseat and then seat them firmly. This alone will solve more than 50% problems. Pay attention to the green flat ribbon like cable that comes from inside of operating panel and goes in on large blue socket of main board. You need to pull a blue long tab on the socket itself away from board before you can disconnect the cable, and push it back after cleaning side surface of cable and putting it back in previous place. If this cable is loose, some or all buttons of panel will not work.
There are instances of complaint that the microwave platter starts rotating with or without the sound of internal cooling fan when door is opened - in 99% cases it is upper door switch - it's actuator - dark brown tab which comes out when the door is opened is failing to come out fully. You may attempt to set it right yourself if you are a good hand in repairing small components or obtaining exact replacement is not difficult from repair shops. Its technical name is micro- switch and you either will need to tell the size and no of wires coming out of it or the best is to remove the same and show it in the shop to get exact replacement. In my case the internal leaf spring needed stiffening and it worked fine. Similarly other door switched also cause unexpected things but usually it is small problem.
Although if you leave power plug connected and power on during nights, and fine one fine midnight that the appliance is making sound, usually it does not mean the microwaves are working inside. It could be opposite of the thing described above. But - why to leave it on during nights? Best practice is to unplug it when not in use. This will certainly protect your appliance from voltage surges that are known to damage electronic appliances often.
One reader quoted non functioning of panel switches when a through wet cleanup was attempted- It is nothing but some how water or soap solution got inside the layers of panel switches which happens to be membrane type. Some switches may start functioning (usually the upper ones when water moves downwards due to gravity) after some time . The best possible safe solution would be to remove water by gently using a hair dryer on outer surface to heat it up so that the water in internal layers evaporates slowly bringing all buttons to previous level of functioning. Take care not to heat-up too much or the plastic panel may deform - use a 6 inch distance at medium heat setting and your patience. It might take a while but half an hour work is worth against replacement. If you are more confident- you may attempt to peel off delicate layers of switch board, clean them and reassemble back using thin double sided tape. Mind that even though you are not removing cover, appliance is to be disconnected from mains first.
Hope it helps.
Basant
Dec 02, 2006 | LG LTM9000 Microwave Oven
Microwave Ovens Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
