My electrical jug does not go off when the auto swich is off
Do you have a base for Morphy Richards jug kettle. no. 43161
we do not as we are not the manufacturer or a rep of said company .
Jul 04, 2016 | Morphy Richards Kitchen Appliances -...
Where are my water PUMPS
I don't know but if you are talking about the Astra Innovative Electric Battery-operated Home 5 Gallon Jug's water pump, it is in the top section.
Aug 16, 2014 | Astra Innovative Electric Battery-operated...
Hi, I have a Bosch Private Collection Kettle. It is over a year old and has until recently been working fine. However, lately I do not feel that it boils to a high enough temperature for a long enough...
Some types of kettles use a separate power base to heat up the kettle jug. If this is the case with yours, turn the jug upside down and look. Also look at the parts on the base that touch the kettle jug contacts. If you can see the electrical contacts; mine were built on spiral rings for differing temperatures; try cleaning them with Brasso and a Q-tip (cotton swab) wiping the contacts several times to remove any tarnish and then use clean swabs to remove all traces of Brasso metal cleaner. Fill the kettle jug up to the maximum fill line and put the boiler on the maximum setting... boiling water. If the water doesn't boil... you have a more serious problem. Buy a new boiler as it isn't worth having someone fix it. Mine worked like new after I cleaned the contacts. Never immerse the jug contacts in water!!!
Nov 25, 2012 | Bosch Private Collection Jug Kettle steel...
I want to swich on my cell, But when i swich on my phone,it take auto swich off. What I will do now?
1ST OF CHECK THE POWER BUTTON IF IT PRESSED DOWN, IF NOT ALL YOU HAVE TO DO IS TO FLASH THE PHONE.
Jan 11, 2011 | Nokia 5130 XpressMusic Red Unlocked Import...
I have a gas grill with a side burner and three burners to grill with. When I turn on the propane then light the burners, the flame is tiny...and the regulator ices up looks like freon on a car air...
The newer jugs have a safety device that is wank. Remove the connection to the jug and open all valves to clear out any pressure. Close all valves and slowly open the jug a tiny bit and retry.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jun 05, 2009 | Kitchen Appliances - Others
Rust coloured spots on insie of kettle
We buy DeBruce Polish at debruce polish.com, this stuff really works.
Mar 19, 2008 | Sunbeam 3211-2 Electric Kettle
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
