Question about Air Tools & Compressors
Repair retractable hose reel - Air Tools & Compressors
2 Suggested Answers
willinois
  • 77 Answers
SOURCE: Craftsman 3/8 in. x 50
Unreel the hose all the way out. Unscrew brass fitting at reel. Screw on new hose with fitting tape. reel up new hose. You're done. Good luck.
Posted on Jan 12, 2011
How to repair leaking elbow inside Yardworks garden retractable Hose reel
pull it apart and replace the rubber "O" ring around the shaft
Nov 23, 2015 | Garden
How to repair leaking inlet connection on the reel inside a yardworks retractable hose reel
sadly there is no repair parts for these pitch it and buy a new one all we can do .
Can the hose in the retractable carrier be replaced? How do I do it?
You can replace that hose by fully extending it and locking the reel. At that point you should be able to unscrew the hose from its connector. A replacement hose can be screwed on in its place.
One alternative, if the reel's hose connector isn't inside the spool area, would be to just cut off the hose at the break, then buy a replacement hose end (with barb fitting to match your hose) and a small stainless-steel hose clamp. They work really well when you get one that's correctly sized for your hose. They're hazardous out at the "business end" of the hose, though - they can cut your hands.
Aug 04, 2014 | Toolshopusa Retractable 25' Air Hose
Cord won't retract on exectrical cord reel
The most common cause is the the cord has been extended past its limits (fully extended) and can't be pulled any further to pull the latching mechanism far enough to release and allor the winder to do its think. (I used to manually force it to move further by using a screwdriver. Pushed the coil a bit further over (as if more cord was being extracted), just to the point where the latch could release.
There's a troubleshooting guide on the Reelcraft website. Perhaps it can help.
Reelcraft Reel Support Hose will not retract
Jul 28, 2014 | Reelcraft Retractable Triple Tap Electric...
Holman retractable hose reel won't retract garden
it is possible the rewinding spring broke .
Jan 07, 2014 | Karcher Hose Reel
How do I fix Frontgate retractable hose reel
If the problem with your Frontgate retractable how is that it simply won't retract, on the assumption that the hose hasn't gotten off the coiling wheel and become tangled, and that there isn't a problem with the hose distributor - which runs off a rubber drive belt, or some other mechanical problem, it is possible to re-tension the spring on a retractable hose.
The principle of these retractable hoses is similar to the energy that is stored in the spring when you pull the starting cord on your lawn mower - which then retracts the cord when you release the pull handle. With the hose completely recoiled, using the blade of a screw driver, you can pry off the triangular cover on the left-hand side of the unit. You'll note four Phillips head screws which secure the round, black, plastic plate to the body of the caddy. If the tension is already "out" of the spring you can remove these screws and nothing will happen. If there is some residual tension remaining, the plastic plate may rotate clockwise a couple of turns when the last screw is removed (it won't spin like an airplane propeller, so don't worry . . .).
To re-tension the spring, I used a crescent wrench and opened the jaws so that the width matched the gap between the two slots you'll see in the plastic plate, and inserted the wrench into the two slots (the wrench will be at a right angle to the plate, at this point. Then, while holding the crescent wrench in place, I used a metal bar, and inserted it through the hole at the other end of the wrench (for better leverage), and turned the plastic plate counter-clockwise five full turns. Then, while keeping the tension on the plastic plate, re-insert all four Phillips head screws, and fully re-secured the plastic plate.
If the inner spring isn't damaged, this should restore the tensioning to the hose reel, as the spring will be further tensioned then automatically, as the hose is uncoiled - which will then be the stored energy that recoils the hose.
Chris D.
Severn MD
Sep 13, 2013 | Frontgate Retractable Hose Reel Post -...
Yardworks retractable hose reel will not pull out from base
I don't have a solution but the other contributors are a pack of useless ***** and who shouldn't waste people's time with their pathetic mis-spelt answers.
Jun 24, 2012 | Vacuums
Got longer hose how do i adjust the spring
Reel are made for a size 25' 50' Etc. what you want to put 30' on a 25' REEL.?.
Jan 15, 2011 | Toolshopusa Retractable 25' Air Hose
Craftsman 3/8 in. x 50 ft. Air Hose Reel, Retractable how to replace hose
Jan 07, 2011 | Suncast Air Hose Reel GCWAR50R
Ratchet/click stops do not work,but spring still reels in,no rust or dents in any part
catch pawl in the reel is shot. I used to work in places where this happened. The only solution is tie the hose off on to a stationary object.
The only other solution is replace the reel..
May 10, 2009 | Toolshopusa Retractable 25' Air Hose
Air Tools & Compressors Logo
172 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
