Question about Epson Stylus CX5000 InkJet Photo Printer
Paper will not feed
When I unpacked the new printer, I noticed that the flat plastic spring-loaded panel in the back of the paper feed tray behind the paper was sprung forward, and I assumed that the spring action was to push the paper into the feeder roller.  However, after I turned it on, added ink, and was preparing to print, the spring-loaded panel behind the paper was now resting backward and would not spring forward to push the paper into the feeder roller. The spring is apparently still there, and is springy slightly, but just doesn't push the panel far enough forward to place the paper against the feed roller. Epson replaced the printer, but the same problem exists with the new one. Is there a solution?
Thanks
    Brigadier General:
  • 10,406 Answers
> Epson replaced the printer.
I think that you have been "unlucky" to get a replacement-printer with the same problem as the first printer. Get them to replace it, again.
Check that there is nothing "extra" inserted into the printer to stabilize the moveable parts during "shipping" -- such "padding" must be removed before using the printer.
Posted on Aug 23, 2010
Printer jams only when I put paper into the tray, and not when I feed the paper manually
in your paper feed tray there is a paper separation pad which is setup on a spring.just scratch it with some fine sand paper and clean with IP solution.
May 27, 2012 | Brother HL-2040 Laser Printer
My HP 2575 Photosmart all-in- one will not feed paper. Message says out of paper when it is full of paper
there is paper feed sensor inside the printer. make sure it is there and not broken off. the sensor is in the back center of the paper tray, and is spring loaded. if you can't find it, shake the printer with the paper tray facing down to see if a black piece of plastic falls out. the printer will also have this error when the printer cannot pick up the paper. clean the rubber roller with "rubber renew". you can use rubbing alcohol but rubber renew is recommended. the roller is often full of dust and fine paper debris.
Nov 15, 2009 | HP Photosmart 2575 All-In-One InkJet...
Brother Laserjet 8860dn printer not picking up/feeding paper
The paper is not feeding from the paper tray. The loud click is alarming, but not the problem. Check the adjustments in the paper tray. The left and right guides should be snug, but the rear guide should give between a 1/16 inch and a 1/8 inch of free play.
To check, press the purple lever at the right front of the tray. The leading edge of the stack of paper in th etray should rise out of the tray so that the top piece of paper can be fed into the drum assembly. If the stack does not rise evenly, or will not rise, the rear adjustment is the problem.
You can inspect the springs in the paper tray by removing the plastic cover that is above the white translucent roller in the tray. To do this turn over the tray and release the catches with a little screwdriver. I do not think there is a missing spring. While you have the cover off clean the lnt from behind the roller.
Oct 01, 2009 | Brother MFC-8860DN All-In-One Laser...
Large spring found in back paper tray, now paper wont feed thru.
You must open case first, dismantle paper feeder, and refit it. For printer diagram, try to find at printersiam.com.
Aug 10, 2009 | Epson Stylus C86 InkJet Printer
Brother MFC-8840d ADF feed problem
Hi, the left hinge is spring loaded to keep the lid open. This applies a lot of pressure on the pivot point of the hinge (steel pin/plastic hinge) that elongates the plastic holes and raises the lid from the scanner. As the paper leaves the scan window, a ramp next to the scan window sends the paper up to the tray, just past that ramp under the lid is a lip that guides the paper to the tray. With the hinge stretched, the lip is too high and catches the end of the paper at the rear only, and jams the paper. If you press on the cover (with the new hinge) and it does not catch then you have installed a bad hinge. Also ensure that the top part of the hinge is on the guide pins under the cover.
Jul 29, 2009 | Brother MFC-8840D All-In-One Laser Printer
HP LaserJet 1300 Printer.
feed the paper in the tray then push the button next to the orange light should fix it hope this helps regards Jim
May 26, 2009 | HP LaserJet 1300 Printer
Have just installed a new HP Deskjet D4360 Printer. Everything is correct except that the paper-feed is not working and although there is paper in the printer an on-screen notice says 'Out of paper' The...
Sounds like you may have too much paper in there. Try just puting a few sheets in, turn it off and turn it back on and see if it doesn't load. Also check internally on the printer, if this is a new printer that you jsut unpacked there may be tape or something inside the printer (like where the toner goes or in the paper drawer.
Apr 30, 2009 | Office Equipment & Supplies
Cassette error
On the control panel for the printer, there's a Feed Switch button that's easily touched by accident. Ensure the Feed Switch is set to the paper source you're using (e.g. either the back or front). The graphic of the printer next to the Feed Switch button will light up to indicate the paper tray it's attempting to use.
Dec 15, 2008 | Canon Pixma MP500 All-In-One InkJet...
It says to load paper in the MP tray
Pull down the front cover where it says Brother, the manual feed input is behind that panel (above the main input tray)
Nov 19, 2008 | Office Equipment & Supplies
Paper jam
I too have this infuriating problem and the reason has already been pinpointed very well it is indeed the front rubber pinch cam not grabbing the paper well. I have approached this problem from another angle... under the front sprung loaded flap on the paper tray
there are two compression springsapprx 1/2" in dia. Gently prise apart the 2 flap pivot (on the extended arms) to gain access to the springs ,pull out the springs and either replace them with slightly stronger ones or pull the existing springs apart to retension them and pop them back (long-nosed pliers or tweezers) this will restore the spring tension lost during use with the rubber pinch cam.
Jabba0737
Mar 10, 2008 | Samsung CLP 300 Laser Printer
Epson Stylus  CX5000 InkJet Photo Printer Logo
141 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
