Question about Cell Phones
Change IC owner
How to change it..
Ic-80Ad screen color change
Change LCD or see in option about color.
Mar 01, 2014 | Icom Ic-80Ad - Ic-80Ad Vhf/Uhf Dual-Band...
How to resolve a problem "sim card not inserted".
ITS INSERT SIMS PROUBLEM
FIRST CHANGE YOUR SIM
CHEK CONNECTION
PACKING
CHECK SIM SOCKET
RESOLD IT
THEN SIM ICS PROUBLEM HIT SIM IC
CHANGE SIM IC
JUMPER SIM IC
OR CHANGE IC
Oct 22, 2010 | Nokia 2760 Cellular Phone
My phone 6300 had not work sim card i change sim ic but no solve
hi if you have already change your sim ic and after doing this it doesn't work then you have to contact nokia service center they will help you
May 18, 2010 | Nokia 6300 Cellular Phone
My bluetooth device detects other devices only when held closely
that is the problem from the bluetooth ic
u need to change the ic
contact nokia service centre to change the ic
May 06, 2010 | Nokia N95 Cellular Phone
TV changes from input setting to channel 3 when turned on.
you need a service repair, on that ckt there's an IC function as memory IC replace that part and all your program well be stored. can found that ic most likely near switch botton area 4 or 8 pin IC.
Mar 03, 2010 | Apex Digital PF2025 20" TV
Nokia n70 is not displaying on screen i change the screen and flash it also but still no display.
Its often happen.Change IC display.It's a glass IC and the places are up the OMAP IC.you can find 2 small IC made from glass. Tray to change one or both IC.I'm sure it can fix your problem.I hope it help.
Oct 15, 2009 | Nokia N70 Cellular Phone
Nokia n91 keypad ic
u should change the key pad or change the panel
May 22, 2009 | Nokia N70 Cellular Phone
How to use nokia 3250 if screen is broken
Mostly the blank lcd on 3250 dont need to change lcd.but the problem usually from emif IC(IC display).if you have an experience in phone hardware try to change it.But if you don't,take to service center because change IC display more cheaper than change lcd. so chek it up first.
Oct 23, 2008 | Nokia 3250 Cellular Phone
N70 network
simple, reset your settings or soft reset but first backup your phone memory when finished get your mmc and resetnit....
Dec 07, 2007 | Nokia N70 Cellular Phone
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
