Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
Windows 7 freezes and mouse changes shape
Clean of viruses, no issues with bad memory, had to re-install the OS due to a serious crash, but after re-installation, the computer frequently freezes and suddenly the mouse will not be what it is supposed to be. While moving around the desktop it will be a cursor for text, the "I" shape, and when mousing over icons it turns into the classic waiting "o" shape. After a while the PC will freeze and nothing will get it out of that state short of a hard reboot. What is going on?! I checked my CPU, Memory, Motherboard codes comeback clean! I am starting to think i am not as much a PC professional as i originally thought.
  • Kael
    Kael Jan 02, 2014
    Cleaned up my Registry files like Glenda suggested with a Registry cleaner. Weird that a brand spanking new OS install would have over 900 errors but it seems to be working with no hiccups now. Thanks.
    Novelist:
  • 288 Answers
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Posted on Jan 01, 2014
  • Kael
    Kael Jan 01, 2014
    You may be onto something there. I don't Overclock though my system IS made for it. I did recently install a new cooling system so i could look to make sure it didn.t loosen up during the move from the first floor of the house to the second.
    Brigadier General:
  • Microsoft Master
  • 3,400 Answers
KAEL, YOU HAVE TO LITTLE MEMORY (RAM) OR TO MANY
PROGRAMS.
  • Kael
    Kael Jan 01, 2014
    This is very doubtful. I reinstalled my OS so the only thing installed is Anti-virus, Drivers, and Steam so i could use my Stress Test program. The PC has 24GBs of RAM.
  • Lars Olsson
    Lars Olsson Jan 01, 2014
    if you have sp1 and all updates,updated drivers a good anti-virus and steam looks guilty.
2 Suggested Answers
  • 286 Answers
SOURCE: Low hard drive memory due to invisible files using 90% of available space (apparently?)
Mind if I be a smart ass for a minute? The problem is you bought windoze vista instead of XP. Vista is pretty bad. Sorry.
If I were in your shoes, I would backup anything important, reformat the drive and reinstall the crappy Vista software (if you must).
If you decide to reformat, may I recommend that you devide your drive into two partitions?
With a 130G hard drive, I would make two partitions. A 30G Boot partituon (c: drive) that you can store your O/S (Vista) on, and a 100G partition (d: drive) for everything else.
When you do this, you only have to back up your boot drive, and since it's only 30 G you don't need as many CDs/DVDs/room on an external drive. Also, if your boot drive becomes corrupted, you only have to restore that one drive from your backup.
Norton Ghost is a perfect utility for doing backups like this since it will make the backup on bootable CDs or DVDs.
Posted on Feb 14, 2008
Laptop random shutdown: Safe-mode; Linux
Did u dual install Linux and 7 on 2 different Partitioned Drives?
Is it only linux with the problem or is windows playing up to?
possible a bad install of linux as a OS?
Try uninstalling linux (leave windows) and partition the hardrive (making 2 different drives i.e. C and D on a single Physical Hard Drive -- its just divided into 2 parts)
and try running Linux from a single clean hard drive and leaving Windows seperate.
that MIGHT solve ur problem. gl.
Mar 17, 2014 | Computers & Internet
Appleworks crash
may i know how old is your unit...? and is this the first time you experience this problem on that unit...?
Jul 24, 2008 | AppleWorks 6 for mac
Nextech mouse through usb continues to install successfully, then freezes while trying to move about my laptop! No, it is not that the Lptp is working in the background, leaving the mouse to freeze th
Step 1:
For a standard trackball mouse, unplug the mouse, turn it over and then twist the retaining ring counter-clockwise to remove it. Remove the trackball inside the mouse. Clean the trackball with warm water and dry carefully. Clean the rollers inside the mouse with a cotton swab dipped in rubbing alcohol. Replace the trackball, then secure it with the retaining ring. Clean the outside of the mouse with rubbing alcohol and a cotton ball. For an optical or wireless mouse, clean the bottom of the mouse and the surface it sits on with a damp cloth. Solve Hardware Problems Make sure the mouse is connected properly. The connector will either be USB or PS/2. A PS/2 connector is color-coded green and can only be inserted in one direction. Check for any bent or broken pins or damage, then carefully plug it in, making sure the connection is secure. Reboot the computer. Connect the mouse to another computer, then reboot the PC. If the mouse works after testing it on another computer, the problem is most likely with your PC or operating system. Also, try a different mouse on your computer. If there is no PC freeze, your mouse is probably malfunctioning. Switch to a different USB port. Sometimes mouse freeze will occur if the mouse is connected to a USB hub. Connect the mouse directly to one of the USB ports on your PC. Try different ports until you find one that works. Replace the batteries. If you have a wireless mouse, replace the batteries with fresh ones. Also, try using a different kind of mouse pad. Sometimes surface imperfections can interfere with the operation of a wireless or optical mouse. Install more RAM or memory. If your PC doesn't have enough memory, PC mouse freeze may occur when you are running resource intensive programs. Installing more RAM will help your PC run more efficiently. Solve Software Problems Check for device conflicts. When you install another device on your computer, it can sometimes conflict with a PC mouse. Remove any new hardware and drivers you may have installed, then reboot the computer. Reinstall PC mouse drivers. In Windows, open "Control Panel" then "System." Select the "Device Manager" tab, then scroll to and select your mouse. Uninstall any drivers that are listed. Unplug the mouse and reboot the PC. Plug the mouse back in, reboot the system, then allow Windows to reinstall the drivers if prompted. Remove viruses. PC mouse freeze and other serious problems can be caused by viruses lurking on your system.Set the program to run a complete scan every 24 hours. Also make sure the virus definitions are updated regularly. Turn off video acceleration. Sometimes video acceleration can cause PC mouse freeze. Go to "Control Panel," then click "Display," and then "Change Display Settings." Click the "Advanced Settings" button, then the "performance" tab. Set the acceleration slider to "None," then reboot. Repeat the process moving the slider up one notch until you have the maximum amount of acceleration with no mouse freeze
Feb 18, 2013 | Computers & Internet
Aliens Colonial Marines crashes the PC on start up
Blue screen can mean many different things. Corrupt software, OS, even bad hardware. Start by uninstalling anything that was installed prior to the problem started.
You next options are to do a clean OS install and start over. From there you could start testing for bad memory.
These are tuff, tedious, and time consuming to get fixed. Most people end up wiping the system and starting over. gl
Feb 13, 2013 | Acer America Acer AM3450-UR10P...
Cursor freezing
Remove viruses.
hope this helps
Oct 09, 2012 | Sony Vaio VGN NS20E Laptop Car- Air DC...
I have a dell inspiron 531s. it is freezing off and on. it would work well for a day then it would just freeze, not responding to the mouse or keyboard. i have reformated the hard drive change the memory...
I had the same issue. I upgraded to Windows 7 and things did work allot better but the hanging still occured. I ran system mechanic and found there was a drive problem. This was repared by the program.
The problem occured again last night and the system will not boot past the dell splash screen. I am thinking it might be the motherboard that is a fault. Mine is out of its 12 month warranty, so no way to get Dell to investigate further. Also check the systems logs after the hang happens and see if there was something logged that caused the hang.
I hope this helps?
Regards,
Lannon
Jan 01, 2011 | Dell Inspiron 531s Desktop Computer
I bought this laptop 2 1/2 years ago. The laptop did it jobs very well until 2 weeks ago... It happened randomly, the whole system is getting to freezed states instantly. I can't move my mouse, nor the...
Well firstly, you know apart from viruses,a fair few sites hold malicious code even in video or image form so thats your freezing problem ,most probably,your best bet would be to have it looked at if you cannot manage it further.Manufacturer will have diagnostic equipment /cables/analyzers etc.
At a guess it sounds like a motherboard component.chip failure perhaps which is not necessarily non-user servicable--maybe try a better search for manufacturers site pdf for for you model.
Linux distros are free and auto install ,if you have not luck with windows bang up a linix distro and see what their diagnostics tell you on boot up,things may become clearer-----good luck
davey snake!
Oct 16, 2010 | Toshiba Satellite A305-S6864 Notebook
I need to format may hard drive due to viruses ...i have a windows 7 starter os. how do i format it?
You will get the detailed information to format the Hard Drive and install the Windows 7 Operating System in the below link:
http://www.sevenforums.com/tutorials/1649-clean-install-windows-7-a.html
Hope this helps.
Jul 07, 2010 | Microsoft Office Professional 2007 Full...
Desktop freezes and can't do anything!!!!!
Freezes and crashes are generally caused by some sort of instability in the computer system.
The following is a list of specific problems that can cause instability along with what to check when troubleshooting each.
Viruses can cause instability.
Run a virus check on the computer to look for a possible virus.
Conflicts can cause instability.
Check the Windows Device Manager to see if there are any yellow exclamation marks or red Xs beside the listings for device classifications. If there are, contact Tech Support.
Buggy or damaged software applications can cause instability.
If the system is less stable when certain software programs are running, shut down those programs and see if the problem continues to occur. If the problems stop, chances are that those software programs are causing the problems.
Buggy, outdated, or conflicting drivers can cause instability.
Check manufacturer web sites for updated device drivers for the various devices installed on the computer system, such as: printer drivers, modem drivers, video drivers, sound drivers, USB device drivers, etc.
Update one driver at a time and see if the system stabilizes. If this doesn't work, it may be a hardware problem, so contact Tech Support.
AC problems can cause instability.
Check to see if the computer system is plugged into an overloaded outlet.
Make sure the computer system is plugged into a surge suppressor.
The installation of new devices can cause instability.
There are three typical symptoms that point to this problem:
The computer system fails to boot, freezes during a boot, or freezes during an operation for no apparent reason.
The system fails to recognize the newly installed device.
One or more software applications fail to function as expected after an upgrade.
Some Tips for Dealing with Freezes and Crashes
Keep track of the hardware and software that is added to a computer.
The addition of new hardware and software can often cause problems to occur.
Research the compatibility of new hardware and software with the existing computer system before purchase and installation.
The older a PC, the more likely it is to crash.
When a computer freezes or crashes, chances are that changes made after the last save and when the freeze or crash occurred will be lost.
I suggest to you do the follow:
Start up your computer and before windows load hit F8, then select SAVE MODE
On SAVE MODE, uninstall all innecesary programs or recently installed, Clean your computer, and be sure that your computer is not virus or spyware infected.
After that reboot and work normally
This will be fixing your problem.
If the problem after that continues is probably then that your have some hardware issue.
Thank you for using FIXYA
Don't forget to rate my help!
Pablo :-)
Oct 14, 2008 | HP Pavilion dv1000 Notebook
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
94 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
