Question about Refrigerators
Westpoint upright fridge freezer making loud noise
Once in a week it is making a loud noise. when we turn it off for 1 hour and turn it on no noise for a week
HVACRH20
  • 237 Answers
SOURCE: My fridge makes loud popping noises
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Posted on Dec 23, 2006
SureWereMad
  • 7 Answers
SOURCE: Loud noise in freezer
maybe it has had it time! worn out! or ye could get someone to look at it!
Posted on Oct 16, 2007
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
  • 15 Answers
SOURCE: My ge profile fridge won't stay cold. the fridge is at 45 deg.
First things first - pull the fridge/freezer out from the wall, and look at the bottom.  You should see a metal coil somewhere - it probably needs to be cleaned.  Next, somewhere around the compressor (the big bulky thing in the bottom of the freezer) should be a fan blowing on the coil - make sure it is running.  That MIGHT have been the buzzing noise you describe - dirt on the fan blades or the fan hitting something.  Additionally, you can check the fan on the inside of the freezer - if it is stuck and/or not working, the air won't circulate properly, and you'll get pockets of different temperatures in your freezer.
Best of luck!
Posted on May 26, 2009
hiltonjug
  • 612 Answers
SOURCE: Frigidaire side by side freezer - LOUD noise...
It sounds like the evaporator fan is hitting ice that is built up on the evaporator coil. When it's making the noise, open the freezer door and see if it stops.
(Most models are wired so that the evaporator fan cuts off when the freezer door is open.)
Check the inside back, lower panel of the freezer for ice built up or frost on it. If there is, you have a defrost problem that is most likley a bad heater. It's located around the coil inside the freezer behind the panel you will be looking at. The defrost problem would explain the freezer not freezing ice cream.
Posted on Nov 12, 2009
Testimonial: "I turned off the freezer side and it defrost for a few hours. Then I turned it back on and its working fine for 2 days now. "
Upright whirlpool freezer make loud noise when it comes on
This noise is the fan motor going bad because a bearing is worn out. You need to replace the fan motor before the compressor goes out.
Aug 28, 2014 | Whirlpool 19.6 cu. ft. Upright Freezer...
Noise blower motor
leave unplugged... water will stay hot.
Plug in for 1 hour to make tank of hot water
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
Jan 18, 2014 | Water Heaters
My LG 693 LTR fridge freezer model no P247STSL is freezing the food in the fridge and building up ice in the fridge on the left side of the drawers on the wall on the side of the freezer, sometimes the fan...
The reason why fan is making loud noise is because of the ice built up on the coil because of freezing.
You can check your drain line to see if it's clogged and clean it out .
There are several video on you tube showing you how to clean drain line.
Hope this help
Jun 02, 2017 | GE PSS25SGN Side by Side Refrigerator
My fridge is making a very loud noise coming from the rear and bottom of box.we have already shut it off for four hours it stopped making noise for a couple of weeks,but now started again,we shut it down...
THERE IS A FAN IN THE BACK OF THE FRIDGE , INSULATION GETS LOSE AND HITS THE FAN. REMOVE THE LOSE ISOLATION OR WHATEVER IS HITTING THE FAN.. I THINK THIS IS THE PROBLEM..JAY THE POOL PUMP MOTOR REPAIR GUY IN LONGWOOD FLORIDA
Jun 27, 2011 | LG Refrigerators
Whirlpool 20 cu ft upright frostless freezer model EVL201NXRQ. About 2 weeks ago i could hear what is sounded like the fan was making a steady loud running noise. Now the freezer has completely quit. Is...
Difficult call there as whirlpool has a strange manor especially with the larger units. I had a callout on a double door whirlpool unit once and the compressor wouldn't come on but i couldn't find anything wrong. Anyway, i decided to leave the fridge untl the next day giving it a chance to possibly come on. About 5 hours later the customer called and said unit running very well and no more problems. Basically leave on for a few hours and see. If no output then call a tech .The testing procedures need equipment and electrical info..
Feb 18, 2011 | Whirlpool 19.6 cu. ft. Upright Freezer...
WESTPOINT upright freezer...alarm light blinking
Sir,
I need to know how to adjust WESTPOINT UPRIGHT FREEZER WVR-300W temperature? There is alarm light blinking every time and the temperature is not changing from 4c!!!! Thats mean, the freezer
Sep 29, 2010 | Haier HSE12WNA Top Freezer Refrigerator
When I turn on my fender hot rod deluxe 40W, even before plugging in my guitar, it crakles and makes noises constantly. I've had it for over 5 years and I play it maybe 1 hour a week. Is it a tubes issue?...
This is likely either a tube issue OR one with capacitors.
You need to characterize the loudness of the noises versus the settings of the controls as part of troubleshooting...
You can try tapping each tube with a pencil to see if one in failure will reveal itself.
Jun 16, 2010 | Fender Hot Rod Deluxe Guitar Combo...
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
