Question about APC Computers & Internet
Ids 816 battery was replaced but it still show battery low
Does the AT&T 944 have caller ID? It also says low battery constantly.
if you are not paying for caller ID then it will not show you that information . low battery tellsme you need to replace the hand sets battery. and we can not age the phone here
Mar 03, 2016 | AT&T 944 Corded Phone
Problem with phone
Call the phone company and ask them the question they should help or come around and fix. Regards Billy
Oct 11, 2017 | Samsung Prostar 816 Keyset Display...
Does the prostar 816 plus have caller id?
It does have caller ID however you need to check that your call carrier is supplying inbound CLI. check on your handset that it is set to show this by pressing TRANSFER 119 then use the volume key to set it to show name or number first. check out http://www.abbeytelecom.com it has loads of Samsung DCS programming and training videos, I posted one as a example for you
Feb 03, 2011 | Samsung Prostar 816 Phone
INHERITED PROSTAR 816, TRYING TO FIND USER MANUAL TO PROGRAM SPEED DIAL
It's not called a Prostar in the UK but is known as the Samsung DCS 816. The follow clip will show you how to add to the system speed dial directory. But you can find 60+ handy clips at www.AbbeyTelecom.com
Nov 11, 2010 | Samsung Prostar 816 Phone
My LCD Prostar 816 shows the Speaker light flashing rapidly. When I click on it, it takes me to an Internal Page screen. I can clear out of that, but I get the flashing Speaker light again. This happened...
Aflashinf speaker key indicates that the phone is fowarded.It's either call foward all calls or call foward on busy.
To cancel call forward all calls, press #11 (with the handset in the cradle), then press your own dss button or dial you own extension number (21-36), and press #.
Canceling call foward on busy uses the same steps but uses #12 instead of #11 for the first step.
May 03, 2010 | Samsung Prostar 816 Phone
My office has the Prostar 816 phone and the manual is not detailed at all.. I needed to know how to change the time (due to time change) Our manual says #55 etc etc... Help me please!
To change the time on a prostar 816 you first need to be at a display set (doesn't matter what the extension number is).
with the handset down, enter #20 the screen should say MMC DISABLED
1) enter in 1 2 3 4 1 # (that enables programming2.gif)
2) enter in #55 the screen should say YYMMDDWHHMM
3) enter in the year, month, day, day of the week, hours and minutes(the day of the week values are 1= mon. 2= tues. etc.)
press # when finished.
Nov 12, 2009 | Samsung Prostar 824 Keyset Telephone
Are there any models of the prostar that support caller id?
No. The Prostar 816 is a 1994ish analog system. It was replaced with the DCS digital systems and they do support CID. The phones are not interchangeable.
Carl
Sep 22, 2009 | Samsung Prostar 816 Phone
Caller ID?
No. I think the Prostar was mid 1990's manufacture. It was replaced with the 50si and DCS family. IIRC the 816 phone is not compatible or ugradable to any of the newer product.
Carl
Sep 08, 2008 | Samsung Prostar 816 Phone
Samsung Prostar 816
The battery is dead and will not maintain system programing after a power outage. If the battery is not replaced this problem will occur everytime the power goes out.
Mar 19, 2008 | Samsung Prostar 816 Phone
Some of the buttons don't work and the Hold function doesn't work
The Prostar 816 phone system can only use Prostar 816 phones. There is a rare larger Prostar system that can use other Prostar phones along with the 816 but typically was only installed in situations where more than 16 phones were needed. If you are looking at non-prostar phones like the Samsung DCS 12 then they certainly will not work.
Oct 20, 2007 | Samsung Prostar 816 Phone
Computers & Internet Logo
43 people viewed this question
Top APC Computers & Internet Experts
Jax Planet
Jax Planet
Are you an APC Computer and Internet Expert? Answer questions, earn points and help others
