Reset ipod factory - Audio Players & Recorders
Bought a used iPod, it's a older one. And everytime I try to down load it wants previous owners email password. How do I change this to my own information?
You could factory reset the iPod but you will loose all data on it. Once the iPod comes back from reset and go through the configuration setup you can chose a new passcode.
Step 1 Press the Sleep/Wake button on the top of your iPod and press the Home button at the same time.
Step 2
Hold both buttons for 10 seconds.
Step 3
Release the buttons when you see the Apple logo appear on the display. Your iPod is now reset to its factory defaults and you will be guided through the initial setup process. After resetting your iPod, you'll need to sign in using your Apple ID and set up iCloud usage.
Aug 23, 2014 | Audio Players & Recorders
What is a master reset
A master reset is a reset to the factory settings that was originally on your device. For instructions on resetting your iPod to factory settings, click here:
Restoring iPod to factory settings
Aug 11, 2014 | Apple iPad Tablets & eReaders
My ipod 8gb is stuck on the connect to i tunes
First, hard reset your ipod.
Turn your iOS device off and on restart and reset
Or factory reset
Can restore my ipod to factory settings without using itunes Yahoo...
If you have a problem with getting itunes on your laptop and you want help with that, where are the details?
May 10, 2014 | Apple iPod touch
My ipod is disabled for 22,854,642 minutes
If you'd rather not wait the time for the iPod to reinstate then reset to factory settings and you can use the iPod again sooner...
To reset it factory settings.
Plug iPod into your computer. Press and hold the Power Button and Home Button at the same time. It will power off, but don't let go. The apple symbol will come up, but still don't let go. You will then see the symbol to connect to iTunes.
Let go and follow steps to restore to factory settings.
The iPod return to life but you will need to download all you applications and music/videos
Sep 19, 2013 | Apple iPod touch
Resetting the ipod to new
Sep 30, 2012 | Apple iPod touch 4th Generation
I need to reset my i pod touch
I'm posting two links for you: one for unlocking a your ipod, and the other for resetting your device to factory settings.
Good luck Forgot passcode for your iPhone iPad or iPod touch or your device is... Restoring iPod to factory settings
Sep 03, 2012 | Apple iPod touch Second Gen (8 GB,...
How can i re program my ipod?
You don't have to reprogram anything with an ipod, the software are giving you problems, you can reset it back to factory settings(default settings) ie. "Restoring iPod to factory settings". All your data will be deleted upon reseting to default settings. Reference link from Apple
How to reset iPod
If you don't know which iPod is yours, have a look at this list.
LINK
Hope it helps.
Jun 04, 2011 | Audio Players & Recorders
I need to know how to reset my ipod because for some reason I can't get in itunes it want even let me create a new account all it keep saying is sorry can not connect to itunes so i already tryed to reset...
1. Read this this from Apple "How to reset iPod" @ http://support.apple.com/kb/ht1320 , and
2. Restoring iPod to factory settings @ http://support.apple.com/kb/ht1339
Since you cannot acess to your code, you have to reset your ipod back to factory default, but all your data on your ipod will be lost!!!
Hope it helps.
Jul 05, 2010 | Computers & Internet
How to unlock ipod
there are two options by which you can unblock the ipod. Follow any of the procedures tomorrow.
Unlock with the Primary Computer
  1. Plug the iPod into the primary computer linked to that iPod, the first computer you synchronized it with unless you have designated another computer as the primary computer.
  2. Open itunes and sync the iPod as normal.
  3. Remove the iPod, following the normal removal procedure. The iPod unlocks automatically as you remove it.
Unlock by Restoring
  1. Restore the iPod to factory settings if you do not have access to your primary computer. This erases all of the data you have stored on the iPod.
  2. Plug your iPod into the new computer you want to be the primary computer. Open iTunes and click on the "Restore" button.
  3. Reload your data, if it is available and sync your iPod. Remove it following normal procedures.
or
Is this your first time using the iPod since buying this from ebay? There are two ways on how you can do this:
1. By connecting it to the primary computer and syncing it with iTunes. Please take note that this needs to be the primary computer you have connected it with.
2. If it is not, then your final resort would be to do a factory reset of the iPod. This will delete all files, music etc on your iPod and will restore it to factory default. You need to use the iPod updater to reset it.
Good luck.
Jul 08, 2010 | Apple iPhone 3G
Resetting I-pod
Plug your IPod into your computer. Once Itues loads up select your ipode and press the restore button. That will reset your IPod back to factory settings.
Jun 24, 2008 | Apple iPod nano 3rd Generation
293 people viewed this question
 Grubhead
Grubhead
