Question about Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series - Sens - A - Speed Walk Behind Mower - 10685
Toro Tecumseh mower won't start or stay running
Can get the mower to start by removing the air filter and blocking the air intake. I tried the adjustment screw on the side but cannot get the mower to start any other way.
  • Jim Parker
    Jim Parker May 11, 2010
    When you put your hand over intake, you are choking it. Does the choke not work?
    Jim
  • LeeatCSE May 11, 2010
    Does the engine have a primer bulb? What is engine model and spec number?
  • 1,040 Answers
Sounds like you need to clean the carburetor. If you need tips on how to do this, just let me know.
Jim
Posted on May 31, 2009
  • Jim Parker
    Jim Parker Jun 06, 2009
    Did this solve the problem?
    Jim
I have a 8h.p.Tecumseh tvm195 it doesn't want to
Replace spark plug. Replace air filter. Fill oil. 30w. When plug is removed pull rope several times to blow out cylinder. With air filter removed spray starter fluid into air intake hole of air filter, try to start.
Ensure fresh gas only is in gas tank. Always add Stabil to gas. If no start clean carb or replace. carb.
Jul 10, 2013 | Garden
Toro 6.5 tecumseh won't start
replace your spark plug. it takes a Champion J19LM. If you left fuel in your tank over the winter then drain your tank and your float bowl. Add clean fresh fuel and it should go if not you need to clean your carb
May 17, 2012 | Toro Power Lawn Mower
The lawn mower won't stay running. It starts up without a problem. I mowed the lawn for about 45 mins and the mower sounded like it was out of gas. It has plenty of gas in it. If I tilt it, by...
Sounds like the automatic choke to me. When it acts up next time, remove the air filter, and observe the butterfly valve on the carb. Hold it open with a screwdriver, and see if it starts and runs. I have found that wireing the thing wide open solved my Toro problems. The mower is still under factory warrenty however, so you can always take it back! Hope this helps my friend!
Sep 09, 2011 | Toro Power Lawn Mower
I prime my tecumseh engine three times as stated. The lawn mower still will not start. How do I investigate to figure out what is wrong? I have taken it to a repair man twice. After I get it back it will...
This sounds like a fuel delivery problem. Maybe remove the carb and tear it down and then soak it overnight in a cleaner after removing all the moving parts...not real hard normally...then let dry and reassemble...If this doesn't improve the fuel delivery problem, maybe get another carb for it....Make sure the air filter is not plugged up, blocking air flow to the carb itself..just something to make sure of at first.
Jul 17, 2010 | Toro Lawn Mower With Toro Power Tools
Engine starts but immediately stops
Engine starts but stalls out. Plug cleaned and air filter removed.
May 25, 2010 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 Tecumseh Recycler won't stay running
I have the same mower and problem. Found out the issue was the carburetor. Pull the Carb and do a quick cleaning. Order the replacement kit prior to working on. My bowl o-ring was shot and I couldn't get a seal after cleaning it out.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Engin will not stay running dies
No fuel filter but there is the air filter. Try removing the air filter and starting the mower. If this works replace the air filter. If not, then check the engine's carb. Engine was made by Tecumseh. There aren't many parts to a Tecumseh carb so replacing the few parts (gasket around bowl, float, needle and seat) isn't a lot of trouble.
Jun 13, 2009 | Garden
My Toro lawn mower (Tecumseh engine) is quitting on me.
defective check valve pull the tank and remove the fuel line replace the small inline filter on hose.
May 24, 2009 | Garden
Lawn mower carburetor
It is a tecumseh , remove screws from intake pipe to block
mark holes for linkage don't stretch springs.
Remove bottom bowl nut it is reg thread so turn counter clock wise . parts needed 631021b bowl gasket and needle and seat,
36786 intake gasket,
632547 2 o rings,
36905 air filter .
Use a can of carb cleaner auto zone spray all holes even the one
on the bowl nut , take out center plastic main nozzle out put on the new o rings put back in , some time the nozzle will brake part 3 640019 .
Remove seat can use comp air or make tool out of paper clip don't
scratch the side when pulling out
Good luck
Feb 02, 2009 | Oregon Scientific Oregon Fusion Blade For...
Tecumseh Lawn Boy Push Mowers Insight Silver Powered Series -  Sens - A - Speed Walk Behind Mower - 10685 Logo
842 people viewed this question
Top Tecumseh Garden Experts
Mike Squire
lnbn1975
itsman
Are you a Tecumseh Garden Expert? Answer questions, earn points and help others
