Question about Digi Sansonic FT-300A tal To Analog TV Converter Box
Rc65 code for digital stream converter - Digi Sansonic FT-300A tal To Analog TV Converter Box
Tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
Tip
DirectTV RC65 Remote Manual
Tivo DirectTV RC65 Remote Control Manual
Have you lost your TIVO Direct TV RC65 Remote Control Manual?
Would you like a digital, searchable, pdf version for reference on your computer?
The TIVO Direct TV RC65 Remote Control Manual is available for download here.
In it, you will explanations of is buttons and features, and directions for setting the remote up for use as a Universal Remote, controlling all your other AV components.
Directions for entering DVR programming codes are here.
Instructions for using the RC65 Code Search function to find remote codes are here.
I hope that helps.
I need code for digital stream box for a trinatron tv
Faq - digital stream technology, Inc. ( digital stream ...
www.dsconverter.com/index.php?p=5
Can I use my Universal Remote Control to operate the converter box? ... Do I need a special antenna to receive digital or high-definition TV? .... Note: If you want to reset the remote back to the beginning of the TV code list, clear the memory by ...
Installation - digital stream technology, Inc. ( digital stream ...
dsconverter.com/index.php?p=3
Connecting the DTV Converter Box to your Analog TV Set with RF cable · - Connecting the DTV Converter Box to your Analog TV Set with Audio/Video cable
Digital Stream Analog Pass-through DTV Converter Box
www.amazon.com/Digital-Stream.../B001TO3L8Y
Amazon.com, Inc.
Rating: 3.4 - ‎131 reviews
Digital Stream Converter Box Remote DTX9950 ... RCA DTA-800B1 Digital To Analog Pass-through TV Converter Box ... I think the bad capacitor is something like a 16 Volt capacitor, and you have to replace it with a ... remote(I was able to find the code for my old JC Penny TV), a seperate button for channel signal strength, ...
Amazon.com: Customer Reviews: Digital Stream Analog ...
Amazon.com, Inc.Digital Stream Analog Pass-through DTV Converter Box ... the code for my old JC Penny TV), a seperate button for channel signal strength, ... My brother somehow found out that there have been many of these Digital Stream boxes that were .... button that you can program into your tv (mine is a 1990's 11" Sony Trinitron).
Jan 14, 2016 | Sony FD Trinitron WEGA KV-32FS120 32" TV
RCA TV Converter Box DTA800B1. Codes for roku tv
For a Cablevision cable Provider the remote controller Model Number is UR2-CBL-CV04 and its remote device unique codes for Roku TV become 031, 081. To get a Charter Cable Provider the remote control Model Number is usually UR4U-MDVR-CHD2 and its remote control codes for Roku TV be 11756, 11602. The user on find their respective remote controller code, have to activate their Roku account using enter Roku activate code to get started on streaming their recommended shows.
For a new Cox Communications Cable Provider the remote control Model Number is URC-8820-MOTO and its remote control codes for Roku TV be 1756, 2360. For the DirecTV Cable Provider the particular remote control Model Number will be RC65 and its remote control codes for Roku TV be 11756, 10818. For a Dish Network Cable provider the handheld remote control Model Number is 21.1 IR/UHF and its remote control codes for Roku TV be 535, 556.
The ONN Cable Supplier the remote control Type Number is ONA12AV058 in addition to its remote control rules for Roku TV are 3851, 3201. Once the consumers remote controller are programmed with the respective codes then the user also have to activate their Roku accounts using enter Roku activate code to start out enjoying their preferred streams.
Hope you find your own appropriate code for your cable providers. For any help on adding the RCA Roku TV codes call our technical support staff members through toll-free numbers +1-855-804-1313 or visit them at roku.com/link
Dec 16, 2014 | RCA (DTA800B1) Video Converter
Looking for the direct tv RC65R remote control code for the RCA LX40FHD41YX9 HDTV
RCA TV codes for the DirectTV RC65 are:
11547, 11447, 10047, 10051, 10093, 12187, 12002, 11958, 11953, 11948, 11922, 11919, 11917, 11781, 11347, 11247, 11147, 11047, 10774, 10747,
10679, 10278, 10174, 10135, 10090, 10038, 10029, & 10018.
Instructions for entering the codes are here.
Instructions for searching for the proper code instead of trolling through that list are here.
If you'd like a digital manual for your RC65, click here.
I hope that helps.
Mar 31, 2010 | RCA L40FHD41 40. in HDTV
I need remote code to control my GPX DVD model D108S with my Directv controller model RC65.
GPX DVD codes for the DirectTV controller RC65 are 20699 or 20769.
Instructions for searching for the proper code if those two don't work, or for other devices, are here.
I hope that helps.
Mar 06, 2010 | GPX D108S DVD Player
I have a sylvania LC320SLX tv and cannot program it with a DirecTV RC64 remote. I saw on your fixya.com site that 11864 works with a DirecTV RC65 remote and wondered if you have tried it on the RC64?...
These codes control Sylvania TV with the RC65, & I suspect they work with the RC64: 11864, 10171, 11271, 11314, and 11394.
I hope that helps.
Feb 12, 2010 | Sylvania LC320SLX 32 in. LCD TV
Can't program rc65 directv remote to control hr21-700 receiver
I believe the codes 00001 and 00002 are valid for all DirectTV receivers.
I hope that helps.
Jan 25, 2010 | Directv HR21-700 DTV Receiver
RC65 won't connect to TV or Blue Ray
Instructions for Code Searching with your RC65 are here.
I hope that helps.
Dec 19, 2009 | Directv RC32RFK Remote Control
Digi Sansonic FT-300A tal To Analog TV Converter Box Logo
24 people viewed this question
Top Digi Televison & Video Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Digi Televison and Video Expert? Answer questions, earn points and help others
