Question about RCA D61W135D 61 in. TV/DVD Combo
Samsung 1080i 52 inch
We have been having multiple problems with our Samsung TV and the latest problem the repair shop can't seem to correct.  When the TV has been off for a while, it has a very loud snap when it is turned on.  Once on it seems fine.  There have also been instances where it will continue to snap every few seconds until you turn it off and turn it on a few times.  Any assistance you can provide would be most helpful... thanks!
    Problem Solver:
  • 7 Answers
This sounds like a high voltage discharge is occurring! Ask your repair guy to check the PTC and all the chassis return circuit black leads and the integrity of the connections to the discharge "spring" across the back of the picture tube. It could also be caused by poorly connected or incorrectly seated wires from the EHT transformer to picture tube pcb. These are dangerous voltages ( 20000 + volts)we are talking about, under no circumstances should an unqualified person attempt this kind of repair, also as after checking all connections, the final test must be with the set open in darkness for observation purposes.
Good luck with this one
Anthony
Posted on Oct 19, 2007
2 days ago, a narrow black horizontal line appeared in the middle of the screen.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - I'm experiencing thin black lines from the top of the screen to the bottom. ... my lcd tv has multiple lines are horizontal it starts from the right and fades too the left, ... Samsung LN55a950 - Horizontal lines on right side - Forums - CNET
Jun 11, 2015
Samsung 52" LCD TV black lines - Forums - CNET - CNET.com
Jun 10, 2015
More results from www.cnet.com
Plasma TV Repair Horizontal Lines - How to Diagnose ...
? 2:49
https://www.youtube.com/watch?v=h4XWCxUsSVU
Sep 2, 2014 - Uploaded by ShopJimmy.com
I have thin horizontal black lines on the top and bottom areas of my TV. .... Hi, I have a 2011 64-inch 3D Samsung PN64D8000 Plasma TV.
how to fix horizontal or vertical lines on lcd tv - YouTube
? 4:52
https://www.youtube.com/watch?v=k2QpYJp6MU8
Apr 12, 2014 - Uploaded by cr4zyw3ld3r
Hi my LG 47ln5700 tv set has thin greyish black horizontal lineson one side of the .... I hope this works good with Samsung LCD as well....
Dec 19, 2015 | Samsung HP-R5072 50 in. Plasma HDTV
The picture seems to have gotten bigger and now the tops of their heads are cut off
When this happens you can try the wide/picture format/view mode button on your television's remote control first. If your remote does not have one or if this does not correct the problem check the resolution on the cable box next. If your television displays 720p make sure the cable box is set for 720p, or 1080i if the television supports that resolution. First you have to make sure your tv in on the right input not the tv tuner input. Then use the hdzoom# button on the cable remote. If you have a satellite remote it might say format or aspect or you might have to go into the cable box/satellite receiver menu and choose 1080i crop or 1080i stretch to get the right picture size.
Feb 12, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Multiple pictures in one
This tv have a problems known as convergence problems,it dead.The Convergence board the 2 STK Convergence ICS and some or all it resistors are dead.These parts must replaced to solved the convergence problems.The shop will cost $300-350 for parts and labors.
Jul 03, 2010 | Samsung PCH521R 52" Rear Projection...
MY TV HAS NO POWER I CHECKED THE FUSE IT SEEMS
hello have you checked the glass fuse inside the tv it will be in the power supply beware if replace the and blows again the you have a dead short circuit
regards
shaun
Apr 09, 2010 | Samsung HCN4226W 42" Rear Projection...
Xbox360 shorting out TV
could be its not plugged in correctly
Oct 27, 2009 | Microsoft Xbox 360 Console
Convergence problems at 1080i resolution
With TV off ON Front Panel board Press and hold vol-&ch- at same time untill set comes back on you should now be in Service Menu ,try adjusting convergence then.
Feb 09, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hooking samsung htz310 into insignia 52 inch flat screen
From what i learnt you learnt to connect tv to system with hdmi and a  optical lead..
Jan 20, 2009 | Samsung HT-Z310T Theater System
RCA D52130 52 in. Won't Display High Def
Hi!
I doubt you'll look at this 2 years later, or even have the T.V.
I have the same TV and was able to view ps3 and xbox 360 games in 1080i, but it's a little tricky. First, let me say that the ps3 is probably not the best system to try using 1080i in unless you have a 360 to help trick the tv into working.
Xbox 360
You need to first set the video to 1080i. This will make the screen display in a bunch of horizontal lines most of the time, but if you keep toggling it on and off, it eventually works. To avoid having to sit and swap between the two modes, it's easier to first set it to 1080i and confirm the setting, then go back into the settings, select 720 (first option above 1080i) and cancel as soon as the video mode changes. 95% of the time this will make it display correctly in 1080i mode. If you turn the tv off and back on, it will sometimes reset to the horizontal lines. If you restart the xbox, it will reset to horizontal lines most of the time. With the ps3, you can set it to 1080i and keep toggling it until it works, but when the game launches it can screw up again, so it's best to have the xbox on and ready with a component switch so you can fix it with the xbox then switch back to the ps3. I think the cable that comes with the tv for HD input (the component plugs don't work, they only support 480, but the vga looking input supports 1080i) - the cable is just poor quality and can barely handle the signal. I've been trying to find a better quality cable with no luck.
Hope this helps other people with this ancient beta HD input canadian tvness.
Dec 30, 2008 | RCA D52130 52" Rear Projection Television
Samsung 52 inch dlp tv purchased in 2003 will not handle 1080i signal from brighthouse hddvr. states no signal detected thanks howard
Be sure you are using the correct component input
This model has three component inputs and only one (the third from left) will work on 1080i signal the first two only handle 480i and 480p
This tv will not operate with 720p signal
supertek57
Jun 17, 2008 | Televison & Video
Tv problem
have the power supply checked out it may be weak
Oct 04, 2007 | Samsung PCH521R 52" Rear Projection...
RCA D61W135D 61 in. TV/DVD Combo Logo
126 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
