Question about Cameras
Olympus faults WHEN I TURN ON MY OLYMPUS E-PL3 I GET THE MESSAGE PLEASE CHECK THE STATUS OF A LENS. WHAT CAN I DO?
  • 4090 Answers
SOURCE: OLympus FE-280
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
Please rate our help to keep the service online ++++Thanks for using FIXYA
Posted on Sep 23, 2009
  • 130 Answers
SOURCE: Why does my lens close automatically after i turn on my Olympus Digital Camera D-500???
Does it beep or do anything other then turn off? what does it do in play mode? Does it have a good memory card in it? hold the memory door down tightly and try it. Akalines on these older smart media card type cameras just dont cut it they need ALOT more power then you think. NiMH rechargables are the only thing i would recomed using anymore. Dont listen to the tv NiMH are what you need. If you notice on the memory door when it open, there is a little plastic tab that stick out. This tab goes into a little slot on the camera, that slot pushes a button that tells the camera when the door is open and closed. These buttons can sometimes cause problems. So make sure the batteries are NiMH and the door is fully closed with some pressure on it. Also see what it does in playback mode. If it stays on fine in playback mode it may have a lens problem. The mechanism for the lens to move in and out could be jammed
Posted on May 06, 2006
BillB-SA
  • 2761 Answers
SOURCE: My Olmpus fe-360 wont turn on. The lens won't
Your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then wipe both ends of the batteries and place them back in the camera. This cleaning clears the problem about 90% of the time. If it doesn't work for you, your batteries may need to be replaced, or the camera may have a problem that requires professional repair.
If this response helped, please take a moment to post a rating for me. A "Very Helpful" would be greatly appreciated.
Posted on Nov 23, 2009
  • 11967 Answers
SOURCE: Zoom Error with my Olympus SP-550uz
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 04, 2010
  • 11967 Answers
SOURCE: Olympus FE-280 8 megapixel Lens won't open.
Posted on Jan 18, 2010
Olympus all weather 760 errors 5f08 5f0a 5e02 Blue error message lens will not retract makes burring sound help please
The sound your camera is making, is probably the slipping from the gears, grinding them down, because something is blocked. Even when you can't see any blockage. Please don't leave the battery in, to avoid more damage. Contact a certified Olympus repair centre, or visit your dealer with the camera.
Sep 17, 2014 | Olympus Stylus Stylus 760 µ Digital 760...
Why doesnt my olympus fl-lm1 not flash?
usual suspects for a dead flash are burnt capacitor, or burnt bulb. Any dark spots or burnt hair-ish smell on the flash? Unfortunately most things are made to be replaceable not fixable. Might try a local camera store...
Aug 09, 2014 | Olympus FL-LM1 Flash for E-PM1/E-PL3...
Olympus 5020 lens stuck, turns off after power
Please check if the digital camera batteries in it are effective,if the battery have compatibility problem ,no strong enough power or voltage,the refered satuation maybe happen.Change the olympus battery for a new one ,then try again. After use some years ,the olympus battery life usually end.
Jun 02, 2010 | Olympus FE-140 Digital Camera
When I switch on my camera the lens just keeps going in and out like it is trying to turn itself on and off can you help please Olympus FE-280
The firmware will need to be upgraded. It is a fault with all digital cameras these days. Company will repair it for $50
Jul 10, 2009 | Olympus FE-280 Digital Camera
Zoom Error message
The problem you are describing is a problem with a sensor in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $167.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Apr 23, 2009 | Olympus SP-550 UZ Digital Camera
Olympus stylus 710
Contact Olympus support
This may ge a generic failure and the camera will be replaced.
Anyway they are the folk who know.
Aug 08, 2008 | Olympus Stylus 710 Digital Camera
Olympus FE-190 lense
If the internal lens barrel gets knocked out of alignment it will cause that condition. If the camera senses that the lens is not in the proper position or not moving, it will turn back off rather than cause more damage. Pushing on the lens barrel to try to fix it will usually cause more problems than it already has. It has to be disassembled to be repaired.
at this point you may also want to check on your warranty status.
Aug 05, 2008 | Olympus FE-190 Digital Camera
Olympus E-300 Evolt - LCD Screen doesn't come & SSWF light stays on
My camera is working again, but the problem is not completely solved. What I did was to put on the old lens, take out the battery then turn on the camera and finally put on the battery again. And now it works. But the problem with the new lens (Zuiko digital 40-150) continues.
Jun 30, 2008 | Olympus EVOLT E-300 Digital Camera
Olympus mji 700
It has to go back the Olympus for replacement or to seller if less than one year.
Sep 02, 2007 | Olympus MJU 400 Digital Camera
Olympus stylus 600
look for a small pinhole on the camera body. insert a pin with power on to reset the camera
May 25, 2007 | Olympus Camedia C-740 Ultra Zoom Digital...
Open Questions:
Cameras Logo
161 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
