Question about Fujinon Cameras
Fujinon xt17sx4.5brm-k1 zoom dip switch settings
This zoom lens continually zooms in when I'm not even touching it. I need the settings on the DIP switch chart. Thanks
  • 37 Answers
SOURCE: Frozen zoom lens
Sounds like there is a misalignment internally. This will probably need to be repaired at a shop.
Posted on Nov 03, 2007
t00nz
  • 4738 Answers
SOURCE: Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 17, 2008
Roynice152
  • 88 Answers
SOURCE: dropped camera jammed zoom lens on nikon 28-85 lens
You have impact damage, the gears in the lens are out of alignment.
www.cameradr.com
he is a friend of mine who can fix this for you.
Posted on Jan 09, 2009
  • 362 Answers
SOURCE: Sigma Zoom 20-200mm Zoom 1:3.8-5.6
The first thing I would do is clean the external lens surfaces then take some pictures. You may find that the blemish has no effect on picture quality. If that is the case, I would do nothing.
If it does affect your photographs, you will need to take it to a camera repair man. What ever you do, do not attempt to disassemble the lens yourself. You will not be able to get it back together and only add to the cost of repair. Check the cost of repair against the replacement value of the lens on E-bay and then make your decision.
  • 146 Answers
SOURCE: Nikon 18-55 zoom lens doesn't autofocus
You might like to check if the A/M slider switch on the lens by the Nikon label is set to A.
It sometimes gets moved accidently.
Set to M the lens will not autofocus.
Posted on Jul 04, 2009
Faulty zoom operation
This is normal. If you hold the zoom for an extended time the lens is slower than the indicated zoom. Forcing the lens to continue to its zoomed direction.
Apr 14, 2014 | Panasonic Lumix DMC-FZ18 Digital Camera
My canon rebel xsi won't take a picture with the .18-55m lens zoomed in
Clean the contacts on the lens? Your lens maybe defective need service?
Apr 08, 2012 | Canon EOS Rebel XSi Digital Camera
Test chart tamrom
Front and back focus tests are good to run. You need to do it for each prime lens (fixed focal length) you have, and at your favorite focal lengths for wide angle zoom lenses too. That means on this 17-50, you would pick wide 17mm and zoomed in 50mm, and several others between. If you pick 25mm and 35mm to test, you would end up with 4 potentially different adjustments. These would apply only at 17, 25, 35 & 50mm. If you shoot at say 20mm focal length, and assume it's the same as 17 or even 25mm, you may be wrong. Too much back or forward focusing is a problem with the camera body usually - not the lens.
I'd pay attention to the lens. Look for cloudiness on the edges of the glass, scratches and fungus on glass, wetness or oil on the aperture blades, specs of dust inside the lens, etc. All of these things take away value from the lens, as they can adversely affect the image or shorten the useful life of the lens. You check these things by looking directly through the lens (not on the camera) and look at a dark background - then a light colored background to help show dirt and dust inside.
The only other thing is to look at actual images taken with the lens. Enlarge the pictures to 100% or more. Look for fuzzy edges, purple fringe edges, colors. You will see all of these issues the more you zoom in. You have to decide what it acceptable to you and what is not. Expensive lenses capture great color, are very sharp and have minimal purple fringing on hard edges (high contrast areas) in pictures.
Jan 30, 2012 | Tamron Test Chart For Tamron Af 28200mm...
Hi I bought a pro-spec 70-210 lens for my Sony Alpha. When you go to zoom out it doesn't twist. You can pull it straight out...Is this how it should work? The rest of my lenses all twist out
Yes. It's a push pull zoom action.
One touch zooms as used on 35mm film SLRs used to have the same mechanism, the zoom ring twisted as well to achieve focus but now that most lenses are autofocus that's unnecessary. So you have a lens which just retains the push-pull, a far more natural action in my opinion and usually faster than a rotating zoom. Once you get used to it I think that you'll prefer it.
By contrast, most modern zooms have what was considered in 35mm terms to be an old-fashioned twin touch zoom: one ring was turned to zoom the lens and another was turned to focus it. This sometimes meant that after zooming you had to refocus; your push pull zoom will likely have a more technically demanding constant focus zoom action, there will be an additional manual focus control as well, but it's very much a minor secondary control used only when your AF has broken or is switched off.
I hope that my reply has been of use to you, please return the favour by rating my answer.
Mar 03, 2010 | Sigma 70-210/4-5.6 UC II AF Zoom Lens for...
Just need a manual foor Nikon One.Touch Zoom 90s
Description: Sleek and stylish, the exciting new Nikon One-Touch Zoom 90QD offers real zoom power in a lightweight, easy-to-use design. The One-Touch Zoom 90QD has a sharp, clear, 2.5x zoom lens with a 38-90mm range and a macro mode for shots as close as 11 inches. The One-Touch Zoom 90QD features a built-in automatic flash with five versatile modes (auto flash, anytime flash, flash cancel, slow sync and red-eye reduction). The active infrared autofocus, infinity focus (for landscapes and faraway subjects), real-image zoom viewfinder and fully automatic exposure control all help to ensure clear and balanced photos.
7444ca6.jpg Depth 2.1 in. Film Type 35mm Width 4.6 in. Height 2.5 in. UPC 018208018789 Battery Type 1 x 3V Lithium Battery (CR-2) Weight 7.84 oz. Self Timer Yes Camera Type Point and Shoot Focus Type Autofocus Minimum Focus Distance 1 ft. ISO Range - Automatic Setting ISO 100 - 800 Red Eye Reduction With Red Eye Reduction Zoom Size 2.4 Auto Exposure Yes Min Aperture f10.5 Waterproof No Max Aperture f4.8 Zoom Lens With Zoom Lens Zoom Range 38 mm - 90 mm
User Manual can not be found up to now. Very soon will be available.
Jan 26, 2010 | Nikon One Touch Zoom 90S 35mm Point and...
Is there a chart that explains the range of a lens. I have a Canon EOS and want to buy a zoom lens to shoot birds, wildlife etc. I don't know how far80-200 MM shoots. I know it's sounds like a dumb ?'s -...
Multiply the mm by 1.5 to get the actual range on a digital camera for any particular lens. Example...80-200 is actually 120-300mm. Then, to give you an idea of how that will look, every 50mm is like a 1x power on a pair of binoculars. Example...120=2.4 power, 300=6 power.
Sep 22, 2009 | Canon Digital Rebel / EOS-300D Digital...
Zoom ring is loose and drops/slides on its own
Yes, this happens even when the lens is brand new. Some other lenses have a Zoom lock to prevent it. What I did was to slip a flat rubber band around the black area just behind the zoom ring, the area where there is s white mark or line, with the band ring just touching the zoom ring. The rubber band should be fairly tight, but not too tight. When the zoom ring revolves, the rubber band touching it gives it just enough friction to prevent it from turning. You can adjust it to give as much friction as you want. Hope this helps. Jay
Oct 02, 2008 | Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Zoom Lens
Hello, DCR-PC7E in order to repair this error you should replace the switch block part number: 147383111. Best regards, Arpi
Apr 19, 2007 | Sony Handycam DCR-HC40 Mini DV Digital...
Zoom lens
Oh I'd love to be able to see this one. OH well. What batteries are you using? If they are ordinary alkaline, then you should get a set of NiMH rechargable batteries. (As strong as you can find) If the problem continues, taale the camera into Nikon and send your friend the bill.
Apr 01, 2007 | Samsung Digimax A400 Digital Camera
Zoom problem
Ive seen this three times and everytime its been something differant. Fist was the rocker switch was jammed. easy fix as dirt was in there. Second was a small serface maounted capacitor in the zoom interface circuit. An third never found the problem as we thought it was a limit switch in the lens itself but the customer never paid for a new lens assy so we didnt order it. Good luck
Jun 21, 2006 | Canon XM1 Mini DV Digital Camcorder
Cameras Logo
111 people viewed this question
Top Fujinon Cameras Experts
Are you a Fujinon Camera Expert? Answer questions, earn points and help others
