Question about Alcatel Cell Phones
My alcatel phone won't charge
Battery won't charge
MY ALCATEL ONETOUCH WONT CHARGE I PUT THE CHARGER TO CHARGE AND IT WONT CHARGE AND BATTERIE IS TO DEAD TO TURN ON
Is the battery good? Is the charger putting out the correct voltage or for that matter any voltage, check both.
Nov 04, 2016 | Alcatel Cell Phones
I have recently bought my alcatel pop and was so pleased with it, but now i can t get it to charge or turn on, can you please help?
Please try the below steps:
1.Try another charger
2.Remove your battery and try to charge/turn on phone while connected to verified working charger
3.try another wall outlet
Let me know what happens so that I may further assist you.
Jul 22, 2016 | Alcatel Cell Phones
On the Alcatel a206g, how can I tell when the battery is fully charged? Does the light change color?
When the battery is fully charged the image of a battery
will display on the screen with 4 bars.
link to on line pdf manual
Alcatel A206G User Manual
Jun 02, 2016 | Alcatel Cell Phones
Is there another way to charge my alcatel 995 if charging port is broken
Yes! Buy or borrow another Alcatel 995 phone and remove the battery from the broken one and insert it into the replacement and charge then swap into the broken one!
Dec 26, 2015 | Alcatel Cell Phones
My alcatel onetouch phone isnt powering on & i even tried charging it
When charging does it display a graphic logo on the screen to indicate charging is happening? One of two things can be possible here. One your phone needs to be reset, or two the internal battery is beyond dead. Phone's shouldn't be charged longer than 4-6 hours typically. Leaving it longer will kill the life of the battery. It is possible after overcharging a battery the charger will act in reverse and drain the battery instead. If your phone requires a hardware reset. This is found in the manual. Typically it's a multi-button sequence pressed or held during power on. If you do not have a manual, you can either search online for it, or contact your service provider.
Aug 13, 2015 | Alcatel Cell Phones
My alcatel a382g phone will not turn on after it has been charged
Try taking the battery out... leave the battery out for 10 mins. Insert the battery again and see if it will turn on.
Another option... if you have a car charger... plug it into that and see if charges. Could be the charger.
Jul 15, 2013 | Alcatel Cell Phones
ALCTEL 880A PHONE WILL NOT TURN HAVE REMOVED BATTERY AND REPLACE STILL WON,T TURN ON THAQNKS DENNIS I HAVE HAD IT A WEEK
Make sure none of the buttons are stuck down. If all buttons seem normal, and you're sure the battery is in right, and charged, return it for repair/replacement.
Jul 05, 2011 | Alcatel Mobile Phones Composite Device...
Cell Phones Logo
131 people viewed this question
Top Alcatel Cell Phones Experts
Gene
D. E. Hev
Jeffrey Thomas
Jeffrey Thomas
Level 1 Expert
Are you an Alcatel Cell Phone Expert? Answer questions, earn points and help others
