Ram again Hi i have been checking out info on my acer aspire t180 and it says that the maximum amount of ram it can handle is 4gb of ram, my motherboard has 4 slots for ram but my pc only works when i only use 2 of them and crashes when i use 4. From what i was reading my motherboard should be able to handle 4gb of ram. any answers?
    Scholar:
  • 81 Answers
Go to your google search bar and type in SIW, download and run it. In the left hand column, scroll down to the hardware section and click on memory. It will tell you how much you have and how much your motherboard is capable of handling.
Some boards like my Dell 8400 will take 4GB and use it all but the motherboard only recognizes 3GB, so if your unsure you might be able to go to the computer manufacturer website, go to support, type in the info for the computer you have and they should tell you what that board is capable of.
Hope this helps, good luck
Posted on May 20, 2009
    Problem Solver:
I have a acer aspire t180 also and i have 4gb of ram memory
4 x 1gb cards
Posted on Jul 29, 2009
What is the maximum memory on a Gateway MX8734 laptop?
Hi Anon
the Gateway MX8734 motherboard has two memory slots each capable of handling a maximum of 2gb of ram.
So, 2gb is the largest single ram module, and 4gb is the largest total amount of ram.
If you are uncertain if your motherboard is capable of handling a 4gb ram upgrade then check with the memory suppliers first.
In practice I have always found that the performance difference between 2gb and 4gb of ram is slight.
Aug 14, 2014 | Gateway Computers & Internet
I have an Acer Aspire T180 and would like to upgrade the memory and add a wi-fi card. can you advise what cards I need to purchase?
Memory:
Looks like the Aspire T180 takes DDR2 533/667/800 memory. This is pretty easy to upgrade. Check to see how many memory slots your computer has (Probably 4, might only have 2). You should probably just replace what you have with new memory.
I recommend this memory:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
It is 2x 2GB modules. 4GB of RAM is a good amount of RAM to have, you will see a noticeable performance increase.
WiFi:
I would recommend a USB wifi adaptor. It is easy to instal and most ones work well, even the cheap ones. Just stick it in the back of your computer and forget it it's even there.
http://www.newegg.com/Product/Product.aspx?Item=N82E16833130066
I recommend this one, I have been using it for 2 years and have had no problems.
Apr 26, 2011 | Acer Aspire T180 PC Desktop
How do I add ram to my acer aspire 5742
Please note: Never touch the gold pins of the memory chips and earth yourself out before you start to discharge any static build up. Installing the RAM is just a case of unscrewing the relevant plastic panel on the base of the laptop, gently pulling apart the white handles that hold the current RAM chips in place, slide out the old and then slide the new chips into place making sure that they go in the same way round as the old ones came out. Gently push down on the RAM chip once its seated correctly and you should hear the white handles click when the module is in place.
There looks to be several different variations on the 5742 model so I'd recommend finding out the exact laptop model number and amount of RAM currently installed before purchasing an upgrade. From what I can tell your model comes with either 3Gb or 4Gb of DDR3 SDRAM 1066 MHz with the motherboard accepting a maximum of 8Gb but you really need to make sure that you've got exactly the right type of RAM or your laptop won't even get to the BIOS after installation before it starts beeping at you.
You should also be aware that specific versions of Windows have a maximum memory limit so you could go to the trouble and expense of installing a pair 4Gb modules only for the operating system to use just 4Gb. More info on 32bit and 64bit operating system memory limits can be found at this link.
Apr 12, 2011 | Acer Computers & Internet
I HAVE 6 GIGABITE OF RAM,HOW CAN I MAKE USE OF ALL THAT IS THERE?
You can't. According to the specs listed for your computer at Acer, it's max is 4GB.
Memory 256MB DDR2 533/667/800 SDRAM expandable to 4GB
Ray
Mar 10, 2011 | Acer Aspire™ T180 PC Desktop
Can I upgrade the ram on the acer aspire 5630 notebook?
Yes, you can.
You can upgrade your Acer Aspire 5630-6760 Notebook (DDR2-533MHz) Laptop to up to a maximum of 4GB Memory, the system has 2 (2 banks of 1) to install Memory. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Nov 25, 2010 | Acer Aspire 5630 Notebook
I have a acer aspire t180 gb7z pc and i would like to know what is the maximum ram speed i can upgrade to
You have 4 slots, capable of handling 4GB of memory but CAUTION: most machines come installed with 32 bit Windows OS. To maximize memory you must have 64 bit Windows OS. With 32 bit system, its probable that 1GB will be all your machine will handle.
Oct 18, 2009 | Acer Aspire™ T180 PC Desktop
Want to add memory all 4 spots are used
If all of your memory slots are used, you will need to remove the memory that is currently installed in order to increase your RAM. It appears that the T180s were originally configured with 256MB, but they are expandable to 4GB. If there are 4 slots (I couldn't find any documentation with images), you can use a maximum size of 1GB modules for each slot. Just remember that if you are using a 32-bit operating system and you upgrade to 4GB of RAM, you will not be able to use all 4GB. The BIOS will report 4GB RAM, but the operating system will only see approximately 3.4GB.
Jun 07, 2009 | Acer Aspire™ T180 PC Desktop
Laptop ram support....
windows xp will support 2gb
Wndows Vista is 4gb
please rate this fixya
Jan 25, 2009 | Acer Aspire 5610-4648 Notebook
Hi i have acer aspire 4530 laptop..it has 1gb of ram but as its too low i wanna upgrade the ram..so i wanna ask tht how much maximum ram will my laptop support....i wanna upgrade it to 4gb ram.will it...
According to Acer your system can support a max of 4 gb RAM. It has 2 slots so you would need 2, 2 GB RAM modules. Hope this helps & please remember to rate my answer. Thanks.
Jan 25, 2009 | Computers & Internet
Computers & Internet Logo
174 people viewed this question
David Payne
David Payne
