Question about Sony Televison & Video
Too much orange
The color is mostly orange and no matter how we adjust any of the settings we can't make it look normal .
    Top Expert:
  • Sony Master
  • 74,887 Answers
Too much orange color, denote the absence of blue. Check all the solder terminals at the video output card for any loose solder terminals. Re-solder all the suspected solder terminals, by applying a little more solder, to each subjected terminals at this broad. This boar can be located at the back of the CRT, will directly plugged on to its neck. Check all the solder terminals to CRT base socket in this board too. If you wish to get some details, check the site linked here. http://electronicshelponline.blogspot.com/ Pull up older posts.
Posted on Jan 01, 2014
MY PHILIPS DPTV 335 HAS A GOOD PICTURE BUT ITS GOT A HEAVY RED TINT NO MATTER HOW MUCH I ADJUST IT.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
May 01, 2011 | Philips 55PW9363 55" Rear Projection...
Intellesence cant correct wavy color ghosted images on my screen. attempted to manually adjust and line up the colors blue will adjust but red will not.
Projection TV sets have two very common problems listed below.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 25, 2010 | Philips 60PW9383 60" Rear Projection...
Cant adjust the color on the tv
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
Apr 18, 2010 | Samsung HCM5525W 55" Rear Projection...
The picture doesnt seem to be clear and it has a green tint
The most likely cause is shorted convergence chips and possibly a few pico fuses.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony,Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer Hitachi,Mitsubishi,Zenith and others.
You can get a convergenece repair kit with instructions from the links below.
*Screen Looks 3-D
*Colors wont align
Problem #2
You can see some more examples and find a fix herebb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 17, 2010 | Hitachi 46F500 46" Rear Projection...
I have too much red/orange in the picture
Convergence problems are very common on all Projection TV sets including Sony2_bing.gif,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer2_bing.gif, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
Apr 13, 2010 | Televison & Video
Its to red no matter what
  • Screen Looks 3-D
  • Colors wont align
Problem #2
Apr 11, 2010 | Philips 50P8341 50" Rear Projection...
Objects are doubled and colors are distorted
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
Jan 11, 2010 | RCA R52WM24 52" HDTV Projection Television
My monitor's color is mixed with the color yellow
There is an option on the monitor to reset colour to factory default. Just bring up the on screen menu by pressing the left most button at the botton. Use the button next to this to highlight the colour settings which I think is the 5th or next to last option down. You will then see the option to reset colour and various other factory default settings. Happy computing
Jul 21, 2009 | Samsung SyncMaster 940N Flat panel Monitor
Color is weird.
Component Video Jack was loose.
Dec 14, 2008 | Sony KP-48V45 48" Rear Projection...
Color
Most likely a bad CRT,not worth fixing......T.
Oct 10, 2007 | Sony KV-36FS16 36" TV
Televison & Video Logo
29 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
