Question about Sony TA-E9000ES Amplifier
Hi guys. Having a problem with my NAD T163 Surround Sound Decoder. Popping in front left and right speakers when changing audio selection. Works well other than that. Please give me some suggestions w
Popping only when changing audio output selection and works fine under all other conditions.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sony Master
  • 924 Answers
Could be DC voltage on the speaker output line, but this will generally keep your receiver audio output turned off completely. Could be a bad muting transistor or microprocessor IC(computer within your NAD). If you are interested in having your NAD repaired, please visit my website at audioserviceclinic.com.You may contact me there. Thank you..
Posted on Feb 02, 2015
2 Suggested Answers
  • 54 Answers
SOURCE: Power LED blinking - no sound
Check windings on input and output of main power transformer.
Make shure no open windings.
Good Luck
Big Red
Posted on Nov 03, 2007
NAD T-763 receiver. cannot get surround sound. all speakers work. should the 7.1 and or surround be connected to the receiver and what else. stereo works fine....two front speakers, in stereo mode. ...
Have you looked at the manual? There is no internal source that would produce 7.1 audio other than the test tones. Attach a multichannel source according to ITS manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/NAD-T763-Receivers-manual/id/8043bh646/t/2/
Apr 19, 2011 | NAD T763 Receiver
Subwoofer
go to audio set up and configure the system for 5.1 or higher sound output.then only all the speakers ll work
Jan 03, 2008 | Yamaha RX-V640 6.1 Channels Receiver
I have a Fisher RS-909 Surrond Sound amplifier. It has no "sub out" jack. I had the sub-woofer working in the past by wiring it as shown in the manual. The problem is that the system was in...
Alright i had a chance to look over things, this is how you are going to hook up the sub. first we'll be connecting the surround sound unit to the sub woofer.
surround sound unit sub woofer
left front: positive (+) <-----to------------->(+) left speaker level in
negative ( - )<- - -to- - - - - - ->( - ) left speaker level in
right front: positive (+) <-----to------------->(+) right speaker level in
negative ( - )<- - -to- - - - - - >( - ) right speaker level in
now that the surround sound unit is connected to the sub woofer you will need to connect the front surround sound speakers to the sub woofer.
sub woofer front surround sound speaker
left speaker level out (+)<-----to--------> (+) left front speaker
left speaker level out( - ) <- - - to- - - - ->( - ) left front speaker
right speaker level out (+)<-----to--------> (+) right front speaker
right speaker level out( - ) <- - - to- - - ->( - ) right front speaker
Alright now that the wires are all over the place and plugged in
turn everything on and see how it sounds. let me know if everything is working as it should. if you need help with anything else or if something does not seem right please feel free to contact me via e-mail or phone
Mark Woodring
Feb 13, 2011 | Audio Players & Recorders
Lux Audio 5.1 home theater speaker & Yamaha HTR 5540 AMP
configure ur PC (both OS audio and third party sound driver) for surround sounds. control panel- sounds and audio devices - speaker settings - advanced - speker settings. so this done. make sure u select the 6 input channel - the button is on the right edge near the volume knob. near the vol button there are two buttons for selecting input type with up down arrow. from that u can select the input type this will be indicated on the top front indicator. but with the 6 input channel selected all selections are preceeded. if u select stereo mode u will have left/ right audio only.
make sure u connect the input right. connect from computer to 6 channel input. main, surround, center and sub-woofer.  connect the spekers to main (L/R), rear(surround) (L/R), center and sub woofer to terminal marked sub woofer ouput. this done select like i said before the 6 channel button. that should do it.
Mar 13, 2010 | Yamaha HTR-5540 Receiver
1 front speaker and 1 surround speaker won't work on cable selection
theres probably a problem with the right channel cable or plug that connects the tv to the reciever, or the tv is set to mono audio.
May 17, 2008 | Yamaha HTR-6030 Receiver
Connecting a logicK TV LCX2 to a Yamaha Surround sound system YSP 1
Not entirely sure what the problem is. You should have Two RCA outputs (left and right) from the TV. These plug into the surround decoder, it decodes the dolby and provides 4 or more outputs for speakers. If I have misunderstood you then please comment before rating badly
Oct 07, 2007 | Televison & Video
Speakers not working proprerly
This may be in the sound card settings itself. Even though you may have adjusted the Windows settings {if thats what your using} the sound card needs to also be set up for surround. Some sound cards do not support 4 speakers or surround sound systems. Go to Device Manager and find your sound card and manufacture then check there technical support page for info.
Sep 07, 2007 | Audio Players & Recorders
Sound not coming from left side surround sound speaker or my right side front speaker
it is highly likely that you're TV is outputting mono sound, hence the left channel only. check your physical connections to the TV and the balance / channel volume on the television as well.
May 01, 2007 | Onkyo HTR500 Receiver
No sound from Front Speaker
take amp to a workbench, have a test speaker in hand, touch the speaker wires to each channel to see if all channels work. take each speaker to the amp and temporarily hook one at a time to see if any speaker is bad. if you eliminate the hardware, you know it's the wires in between.
Mar 02, 2007 | Mission 700 Main / Stereo Speaker
NO surround sound coming from our harmon/kardon speakers when set up to our onkyo tx-sr601 receiver. wires connected in correct areas, front left, right and center speakers work, subwoofer works. setup for...
So your saying that you have no rear channel. Some recivers use a single stereo output ic for both sides on the rear speakers. you could have a defect with this IC . Anther thing Im sure you check3ed the obvious ie : the switch is on suround sound? If there is a front to rear fader is it in the middle? Good Luck
Jun 04, 2006 | Onkyo TX-SR601 Receiver
Sony TA-E9000ES Amplifier Logo
114 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
